Im gonna hijack this thread and ask for a personal recommendation. Currently on koni/eibach but im looking for an upgrade. I like to hit the track at least 8 times per season. My car isn't a daily driver but it is driven on the street a lot.
I have heard nothing but good things about KW V3. Currently my top choice.
Ohlins R+T
KW CS 2 way
I think the CS will be too aggressive for my car. Curious as to what you guys think.
Coilover Recommendation
This is helpful. Thanks. Mind sharing why you went with Ohlins vs. TCK?
Jesse
1. Ohlins reputation.
2. On paper they met my requisites (high end damper, springs that work with stock mounts IE no heim joints, designed with street use in mind)
3. Wanted to sample them for myself so I can speak firsthand, rather than just repeat forum hyperbole.
4. I don't like overlap in my cars and since my E36 has TCK DA's already, I wanted this E46 to be a different driving experience.
Fast forward to now that I have sold off a few of my M cars, and soon parting with the E36 as well, I am trying to consolidate the best of all my cars into a single E46; that wholeheartedly includes the way the car drives with TCK's. And given that i've been underwhelmed by the Ohlins anyways, i've literally been waiting a full year now for TCK to get E46 DA's back in stock. I don't regret buying the Ohlins but will not look back that fondly either.
Many thanks. My car is street only. Would you feel that the TCK SA kit is sufficient for a street only car, or is the DA kit worth the extra on the street?
JesseLast edited by jvit27; 09-21-2020, 02:04 PM.
Wow this thread took off. OP here.. you guys scared me off and I stuck with Dinan/Koni Yellow. Still love the ride and I’m fine with the ride height. Nice to see some active discussion on the topic though.
Long since worn out stock without camber plates is not a high bar starting point to compare to :P
FYI, i am nearing the limits on these coilovers but that’s not without extensive work and seat time. The limits will be the rear springs, tires, and ultimately valving ( tbd ) assuming other maintenance is done.
Originally posted by jk715 View Post
I wouldn’t call them crap since my PB improved by 3 seconds with just the ST XTA coilovers compared to stock. Camber adjustments alone made a 2 sec difference which come with the coilovers. I’m not saying they’re the best but for the price, I’d like to see another setup that can increase the cars limits the same.
As for spring rates, i agree that the rear progressive springs are crap and should be replaced with linear 6” 2.5” ID 500# - 700# springs.
I understand the stigma with stance boy coilovers but these are not in that category.
I'd argue you lower the limits of your car putting crap like that on. No offense. Just those spring rates alone are alarming. There's a huge spectrum between stance-bro coilovers and going "full aero, slicks, and mcs 2-ways" so I'm not sure what the logic in that is.
But at the end of the day, if you like it, then you like it.
Originally posted by jk715 View PostDifferent strokes for different folks. If you're looking for a budget friendly street ride, shock/spring + stock hats is your best option. If you're looking for double duty there are other options for around the same price. Of those, i'd recommend the st xta. Sure, there is a limit in performance with budget coilovers and when I reach that limit is when ill slap on the full aero, slicks, and mcs 2-ways.
With a lot of effort and some fabrication, the Ohlins can be made to be a great dual purpose (street/track) setup. The TCKs are much better out of the box and in terms of... ease of getting them set up and working properly. It's pretty hard to install TCKs and not have them be great.
... but the Ohlins are coming off my car this winter...
Originally posted by jk715 View PostNo one mentioned ST XTA's. Great value coilover for double duty, needs some work (adjustable endlinks, rear springs) for a decent track setup. Comes with plates, decent valving for double duty, linear front springs 450lb/in (unlike KW's) and progressive rear ~479lb/in (source: ST), fixed endlinks.
