CF Sunroof Delete Questions
  • bigjae46
    Ah ok, interesting. Yeah i recall the S2R fiberglass panels were going for under $300, IIRC something like $279? That's almost half the cost of the AJ Hartman CF piece though, cant say its not a significant price difference. Unfortunately seems like S2R went tits up, and is no longer available
    A mold has a service life. One possibility is their mold was no longer usable.
    Inflation is real. Probably could do a FG panel for $280 a year or two ago. Right now...no way in hell.
  • BigRussia
    The savings is minimal if you go with fiberglass. Most of the cost is in the time to prep, layup and finish the part. While FG is about 1/5th the cost of carbon, the amount of cloth used is probably less than a yard.
  • bigjae46
    Not sure if this is the de-facto sunroof delete thread here on NAM3F, but figure it's the best one to bump with my question; is the AJ Hartman CF delete panel still the best one today in mid-year 2022?
    Im ready to place an order but wanted to see if any other non CF options have as good as fitment and quality in anyone's experience. Seems like S2R is no long around so thats no an option. AJ Hartman is currently listed at $499, while CF is awesome I dont mind sacrificing 1lb. to save a few hundred bones on a FRP piece that could go towards fixing the used sagging slicktop headliner I have to restore as part of this sunroof delete project.
  • BigRussia
  • gixxer
    If not sticks then shoves!!! Whatever works...
  • gixxer
    This is how I approached it:
    Then smoothed it with the edge of an old credit card.
    Yep, found that post in
    Hey Guys, I had a ton of work done on my car over the winter including a bunch of welding that I cannot do. A “while you were in there” thing I had done was a sunroof delete panel and removal of the headliner (because, well, track and a humongous dome) during their work. This is one of those things I kind of wish I had just
  • gixxer
    Originally posted by SandeepM3 View Post
    Here is a second panel from AJ I had to get for my next car. Also perfect fitment. When installing and letting the sealant (and I also use adhesive) dry I used sticks to apply pressure to each corner and long edge to insure it dried flush and didn't sag.
    Click image for larger version Name:	20210103_154647.jpg Views:	0 Size:	137.3 KB ID:	130492
    That *is* a flush, tight fitment !
    I will need to come up with like those sticks to do similar applying of even pressures. Thanks for sharing that.
  • Estoril
    AJ hartman panel is perfect fit. The outside appearance is very dependent on the skill of the person applying the silicon sealant.
  • SandeepM3
  • eacmen
    Originally posted by gixxer View Post
    Thanks.
    AJ Hartman it is !
    I'm just banging my head against the wall because i just recently had B and C pillars removed. A pillars are fairly straightforward, although i'm certain i'll break something (clips) along the way.
    Sorry can’t help you much there. I was stripping the interior for a track build.
  • gixxer
    Thanks.
    AJ Hartman it is !
  • eacmen
    That's good to know. Following panel removal video seem helpful.
    I did find m3 weights thread in this forum, very useful.
    Thought it would be good to have a thread were we can keep track of what certain parts on the car weigh. I'll start with what I got from the rear seats. Post up the things you've weighed and I'll update this post. Interior Front Seats Front seat (black nappa/power/heat/latch): 51.5 lbs Front seat (m texture/power/bolster/lum
    I'm just going to see for myself by weighing the front seats vs the recaro pp with hardware's.
    To those that have the AJ Hartman CF sunroof panel, did the panel gave a good flush with the rest of the roof line?
    From the various installed pictures of this panel, the roof line seem to be more or less flushed.
    Trying to see if CF wrap the whole roof would be pointless because of panel not flush with the roof line.
    Thanks.
  • gixxer
    CSL liner is about 3.5lbs, assuming you put everything else back on - pillars, sun visors, etc, you only basically save on the glass and the cassette/motor itself.
    Remove the glass first, separately from the cassette (4 screws), makes it a lot easier to remove everything by yourself.
    Doing roof vs just the panel, I heard nets another 7-10lbs, so not huge.
    https://nam3forum.com/forums/forum/m...ht-data-thread
    To those that have the AJ Hartman CF sunroof panel, did the panel gave a good flush seating with the rest of the roof line?
    Thanks.
  • mrgizmo04
    would a mere sunroof delete alone (saving of ~70 lbs or so ???) be "worth" the effort to reduce similar center of gravity height similar to csl roof?
    Weights listed on some sites are incorrect.
    Doing a sunroof delete panel is only a saving of about 32lbs.
    -Sunroof roof liner 3.5 lbs
    -Lights, pillars, sun visors, rubber seam for sunroof glass, oh shit handles, clothes hooks, sunroof motor - all 8 lbs
    -Sunroof glass 14 lbs
    -Sunroof cassette 16.5 lbs
  • Nate047
    Yea you probably won't really notice a huge difference, but if you WANT to notice it in your mind, you will "feel" it. As someone said above though, if you're doing seats, and if you do lightweight wheels too, that's a solid little chunk of weight gone right there. All from the highest point of the car, and from the rotating mass on each corner, plus the fact that seats hold you better and will lower your center of gravity a little bit too, all of that together will make a big difference on the ole' butt dyno and confidence meter.
