The "Post Your Wheel Setup" Thread
looking for ideas... getting some body work done to the track car and looking at 18x11's all around. other than the flow APEX wheels, does anyone else know of other manufacturers that make wheels that'll fit with minimal spacers?
Arc-8 Gloss black 18x10 with 275/35 Square setup
- Likes 3
thanks! I was going by the Apex wheel fitment guide which states:Originally posted by DESMDR3 View Post
You should be able to fit them with stock specs. Before I got coils/camber plates, I was at -1.7 degrees camber and it was fine 👍🏼
Front & Rear: 18x9.5” ET28 with 265/35-18 tires or 275/35-18- 265/35-18 requires at least -2.5 degrees of front camber.
Wheels: BBS CH 19" Bright Silver Finish
Front: 19X8.5 ET35 (CH004)
Rear: 19x10 ET20 (CH017)
Tires: Hankook Ventus V12 Evo 2
Front: 245/35 R19
Rear: 275/30 R19
- Likes 5
What valve stem are you using?Originally posted by Tbonem3 View PostHmm I guess I never posted my new set
OE CSL w/ 235/265 MPS4s
15mm front, 5mm rear spacer (10mm will just kiss at the rear, so I have to dial out the toe-in)
You should be able to fit them with stock specs. Before I got coils/camber plates, I was at -1.7 degrees camber and it was fine 👍🏼Originally posted by binary View Post
What camber settings do you need to run for ET28? Did you need or do you have camber plates? I am researching TE37s and trying to figure out what I need to make them fit.
