The "Post Your Wheel Setup" Thread
  • Gt4
    I was just gonna install the same width tires on the 17" and the same brand/model of tire and then throw the 17" and 18" on the same scale to compare.
    I just look weight on Tirerack and same tire in 275/40/18 is 1lb heavier than 275/35/18.
    IMO any wheels/tires setup around 45lbs on rear axle is good. Lighter on front axle when staggered is even better
  • EthanolTurbo
    While wheels are going to be lighter, tires are going to be heavier due to bigger sidewall. Let us know the weight difference with tires mounted.
    You can see tire weight on Tirerack website in Tire spec’s
  • Gt4
    Managed to find and buy a very hard to find variant of Volks RE30... 17x8.5 and 17x9.5 in BMW offsets. Going to take off my 18" RE30s in same widths to see if the 17" offers a noticeable performance and ride quality increase. Each wheel is under 16 lbs so hopefully will drop 1.5-2 lbs per corner. Mostly got these as street wheels to enjoy a fat sidewall and as little wheel weight as possible.
  • EthanolTurbo
  • Gt4
    Bought Bimmerworld TE16 wheels from a member here. They look better in person than pictures IMO. Really like them. Going to respray them in silver.
  • Tbonem3
    That's almost the correct E46 M3 set. The rears should be the 10"ET25, not 10.5" - maybe double check with seller.
    If it is the 10.5", they'll still work, but I don't think a 2" stagger is ideal. 245/275 would be best imo.
  • Lee_Enfield
    I'll ask this here since it's relavent.
    Guy has a set of BBS CH-R for sale States will fit E46 M3, just want to confirm. My car is pretty much stock. Not looking to change anything up too much at the moment.
    From his add they are:
    Front: 19x8.5 et32
    Rear: 19x10.5 et25
    Might be a decent deal.
  • Cubieman
    I like these 18" sportline 8's for the offsets/weight, but want the finish of a CSL/ZCP.
    Going to start looking into painting options or possibly just buy some new ZCP's, too bad the fronts are so narrow but it's a 99% street driven vehicle so likely a non-issue.
ID:	196567 Click image for larger version
ID:	196566 Click image for larger version
  • liam821
    Originally posted by y2k_o__o View Post
    Did you use any concentric hub? The wheel bore and our wheel hub size are different
    Yes, I used a 72.6mm ID to 73.1mm OD hubcentric rings. They're super thin but was necessary to fix the wheel shake at 80mph.
    This is what I ordered: https://www.amazon.com/gp/product/B00F3QUA6U
  • PurelliCondoms
    Here’s something rare-ish most of you guys haven’t seen in awhile. Goes perfect on my car. Needs a bit more spacer in the front and rear and a tiny bit more low, but good enough for now.
    Hard motorsport Centerlocks18x9 et35 265/35/18 square Hankook RS4. 12mm spacer in the rear. Needs a 20R and 12F.​ Click image for larger version  Name:	BB7F0EFC-6B39-41ED-8BAB-05D3B47AF425.jpg Views:	0 Size:	123.6 KB ID:	196484 Click image for larger version  Name:	A6F72A9F-C3D0-45BE-ACDF-DE15B5A67C4D.jpg Views:	0 Size:	58.4 KB ID:	196485
  • Boost
    out of curiosity, why aren't you guys with the 359Ms running 245/275?
    I was more or less 50/50. A few small factors:
    1. Wanted to play it safe when it came to rubbing in the front. The 359Ms are wider than the E46 ZCPs (8" vs 9" up front) and I wasn't sure how aggressive I'd be going on suspension. And my fender liners were brand new. And I hate rubbing..
    2. Per Ian's tire sizing thread, the difference in circumference is marginally less (maybe like 1/4 inch iirc) between the 235/265 low pros than the 245/275 low pros.
    3. The smaller rubber was cheaper and had a quicker ETA at the time
    Moving forward, I might try the 245/275 (with or without +5 sidewall), or go a little lower to get rid of the bit of fender gap I have right now. Or both..
  • ldmiller78
    So I had 2x LSB. Unfortunately one was totaled but here are the old and new setups
  • Cubieman
    Originally posted by Mtrace View Post
    Click image for larger version Name:	IMG_8986.jpg Views:	0 Size:	267.3 KB ID:	194805
    Arc8R in Brushed clear, 18x10 ET25 275/35/18 square with 12mm spacer in the rear
    Nice, any close up shots? I considered these wheels, also looked into the polished finish but if I remember correctly the polished finish wheels were not offered in the same offsets as the others for some reason.
    Nice wheels in any event!
  • Casa de Mesa
    Originally posted by Lee_Enfield View Post
    Those are the rims I want as well. I like the look a little better then the E46 comp rims. Been keeping an eye out for a set.
    Yeah that does look pretty great.
  • tnord
    out of curiosity, why aren't you guys with the 359Ms running 245/275? I have the same width/offsets and those tire sizes with no rubbing, but might not be as low. I'm thinking about upgrading wheels to TA16, or some BBS option but I do really like the design of these. There's something about the radius of the fender arches and the radius of the concavity matching up that appeals to me. I just scrolled through this whole thread and was surprised I didn't see a single TA16 setup.
    Apex EC7
    18x9 +31 245
    18x10 (or are they 10.5? I don't remember) +25 275
    Click image for larger version  Name:	A6BEEAE9-4051-4F30-9333-0E62086FFE8F.jpg Views:	0 Size:	105.5 KB ID:	194860
