Originally posted by mdefalco25
The "Post Your Wheel Setup" Thread
It doesn't take much at all to run this setup. It fits like a glove. I have had those exact wheels for several years now. 19x9 +35 with a 5 mm spacer in the front (basically +30) wrapped in 245/35 and 19x10 +25 rear with 10 mm spacer (basically +10) wrapped in 275/30. Car is slammed on eibach coil overs with no front or rear camber and front has zero rub. My rear fenders are rolled and it only rubs if I am exiting a steep driveway at a sharp angle. In regular driving, it has never rubbed for me. Again my rear fenders are rolled but I am also running 10mm spacer in the rear. My ride height is at 13" center cap to fender front and rear. fronts wont rub even with a passenger but rears will rub with a passenger on either side (with 10mm spacer). I used to love the way it looks but nowadays it is just too aggressive for my taste and soon I will be switching to a more conservative look with CSL reps 8.5/9.5 and raising the car. I'm going after a thick side wall with a mild drop look vs the stretched thin sidewall slammed look. If I don't like black CSL reps then ill go back to these same wheels and run 255/35 and 285. Black M359s just suit PY so well !
- Likes 3
Max out negative camber front and rear with the stock hardware, lowered suspension and no more than a 245/275 street tire.Originally posted by mdefalco25 View PostCan anyone chime in on what it’ll take to run this setup? Camber settings, fender modifications etc.? Really like this look and like to do on my e46 M3 but not sure how doable it’ll be. Appreciate any feedback. Thanks!
Can anyone chime in on what it’ll take to run this setup? Camber settings, fender modifications etc.? Really like this look and like to do on my e46 M3 but not sure how doable it’ll be. Appreciate any feedback. Thanks!Originally posted by nextelbuddy View PostStock e9x ZCP 359M wheels.
19x9 - 245/35/19
19x10 - 265/35/19
Anyone running the apex VS5RS? Thinking of switching to those from my square CSL rear setup.
Unnecessary weight. It'll be impossible to pick a set of tires that suits both wheels correctly AND our dsc. Possible fitment issues for the rear.
What would be the downside of running a 2 inch stagger?Originally posted by Tbonem3 View PostThat's almost the correct E46 M3 set. The rears should be the 10"ET25, not 10.5" - maybe double check with seller.
If it is the 10.5", they'll still work, but I don't think a 2" stagger is ideal. 245/275 would be best imo.
What would a decent price for a set of used CHRs? Seller states no rash or bends. Pics looks very good.
Love those wheels. I had a set of the machined finish on my E36 as track wheels. I have continually harassed them about making that finish available for all the 18" sizes, sadly to no avail. Regular silver paint would also be better than the gunmetal or black IMO. Looking forward to seeing these once you refinish them.Originally posted by Gt4 View PostBought Bimmerworld TE16 wheels from a member here. They look better in person than pictures IMO. Really like them. Going to respray them in silver.
I'm running General Gmax RS, 235/40/18 and 265/35/18 right now, would run 235/45/17 and 255/40/17 or 275/40/17. From what I can tell, the 17" tires would be slightly lighter, by .1 lbs or so. Focusing more on feedback and lightness vs "max grip and width bro!!" For a street car, I like the steering and responsiveness.Originally posted by Gt4 View Post
What tire brand/model and sizes are you using?
For same total diameter and width, a 17’’ tire will be heavier than a 18’’ tire
He confirmed it's 10.5 with 25 offset. But I didn't even find that size on bbs website for the chr.Originally posted by Tbonem3 View PostThat's almost the correct E46 M3 set. The rears should be the 10"ET25, not 10.5" - maybe double check with seller.
What tire brand/model and sizes are you using?Originally posted by EthanolTurbo View Post
From what I can gather, the 17x8.5 is 16 lbs, the 18x8.5 is 17.2 lbs. The 17x9.5 is 16.5 lbs, the 18x9.5 is 17.7. The tires in same sizes are equal weight according to the manufacturer. It will be a small difference but in the most meaningful place. I figure every lb off the wheels, tires, brakes, and suspension are the weight you feel the most and that make a significant impact.
From what I can gather, the 17x8.5 is 16 lbs, the 18x8.5 is 17.2 lbs. The 17x9.5 is 16.5 lbs, the 18x9.5 is 17.7. The tires in same sizes are equal weight according to the manufacturer. It will be a small difference but in the most meaningful place. I figure every lb off the wheels, tires, brakes, and suspension are the weight you feel the most and that make a significant impact.Originally posted by Gt4 View Post
I just look weight on Tirerack and same tire in 275/40/18 is 1lb heavier than 275/35/18.
IMO any wheels/tires setup around 45lbs on rear axle is good. Lighter on front axle when staggered is even better
I just look weight on Tirerack and same tire in 275/40/18 is 1lb heavier than 275/35/18.Originally posted by EthanolTurbo View Post
I was just gonna install the same width tires on the 17" and the same brand/model of tire and then throw the 17" and 18" on the same scale to compare.
I was just gonna install the same width tires on the 17" and the same brand/model of tire and then throw the 17" and 18" on the same scale to compare.Originally posted by Gt4 View Post
While wheels are going to be lighter, tires are going to be heavier due to bigger sidewall. Let us know the weight difference with tires mounted.
You can see tire weight on Tirerack website in Tire spec’s
