Terra posted this over on another forum a while back:
0x545
Byte 0
Bit 0 - unused
Bit 1 - Check Engine light (0 = off, 1 = on)
Bit 3 - Cruise Control Light (0 = off, 1 = on)
Bit 4 - EML Light (0 = off, 1 = on)
Bit 7 - Check Gas Cap light (0 = off, 1 = on)
Byte 1 - Fuel Consumption LSB
Byte 2 - Fuel Consumption MSB (Values just cycle from 0 to FFFF then start over at zero. Fuel consumiption is the rate of change.)
Byte 3
bit 0 - Oil level error if motortype = S62
bit 1 - Oil Level Warning
bit 2 - Oil Level Error
bit 3 - Overheat Light
bit 4, 5, 6 - M3/M5 RPM Warning Field (refer to tables below)
Byte 4 - Oil Temperature (ºC = X - 48)
Byte 5 - Charge Light (0 = off, 1 = on; only used on some DMEs)
Byte 6 - CSL Oil Level (format unclear)
Byte 7 - Possibly MSS54 TPM Trigger
RPM Warning Field Table (E46 M3 Cluster)
Code:
LED Value (dec) Value (bin) Left shift
7500 0 0 #000####
7000 1 1 #001####
6500 2 10 #010####
6000 3 11 #011####
5500 4 100 #100####
5000 5 101 #101####
4500 6 110 #110####
4000 7 111 #111####
Cluster Display project
I will be using HTG tuning GCU, it will be able to communicate with MSS54HP through CAN bus.Originally posted by S54B32 View Post
don’t want to go too much offtopic but...
Are you go with DKGECU? Tried for weeks to contact dkgecu, but never got a response. Other possibilities are Maxxecu, but only E9x m3 DCT is possible. But DCT is not on same Bus (as example PT-Can on E9x, not available in e46 chassis) And as I only plan for 1 Can input, there will be only possible to monitor DCT OR rest of E46. About price, until I have a prototype PCB, I can’t say anything about it. After prototype I will get a quote for a small batch of PCBAs.
nextelbuddy : someone need to dissemble in IDA the code in programspace for oillevel sensor and port it to normal firmware. Maybe one day some pro‘s like terra or Martyn or Olza will do this.
t3ddftw : thanks for the support! If I get to a point where I can‘t get further, I will come back to you.
you can PM me if you prefer
Thanks. Maybe S54B32 can clarify beyond that!Originally posted by terra View Post
Yeah the DME broadcasts it on message 0x545. I don't remember the details beyond that off hand.
You were able to snag CSL oil level from CAN? Forgot I will be without this now with the AIM.Originally posted by S54B32 View PostAdded today the CSL oillevel reading. Maybe interesting for older cluster or swap‘s.
Still working on PCB layout, it’s way more complicated than I thought. Even if I implement future possibilities like a second display and to make it as small as I can to install everything inside the cluster without a box attached behind the cluster. (Not shure if that is possible in the moment)
btw. Oled’s look real shit if you want to capture it on photo.
don’t want to go too much offtopic but...Originally posted by kokgo20 View PostOP, i'm probably in for one of those LCDs if the price is right. Specially i'm about to retrofit F8x DCT in my car and the SMG display doesn't display #7
PM me if you're interested in help with PCB layout. I have a relatively successful product (www.bluebus.dev) that I developed solely by myself, and I'm pretty versed into fitting lots of components into constrained spaces.Originally posted by S54B32 View PostAdded today the CSL oillevel reading. Maybe interesting for older cluster or swap‘s.
-Ted
I so wish we could get CSL oil level read out on standard mss54hp software and not just the CSL software.Originally posted by S54B32 View PostAdded today the CSL oillevel reading. Maybe interesting for older cluster or swap‘s.
So cool, I'd like to do the DCT swap someday. Are you using BMW's transmission control or aftermarket?Originally posted by kokgo20 View PostOP, i'm probably in for one of those LCDs if the price is right. Specially i'm about to retrofit F8x DCT in my car and the SMG display doesn't display #7
btw. Oled’s look real shit if you want to capture it on photo.1 Photo
The effort to make this would be way to much. But you know Ratio, rpm and wheelspeed. So we can calculate selected gear by these values. But don‘t know what the benefit is of this in a H-pattern box.
Do you think it would be possible to have the gear display for a manual. I remember bringing this topic up on m3forum and IIRC Terra said it might be able to happen?
Mostly just a gimmick but I got the idea from the gt3.
I looked into it a bit and you need a gear position sensor. The manual cars do not have one. The SMG cars do have one but it’s a part of the hydraulic unit. I’m sure there’s a way to get this done I just don’t have the parts in front of me...
There must be a way to have the dme accept data from that in a manual car.
the possibilities are near unlimited. I already thought about to replace 2 bottom displays and maybe even the „door status“ area. Have couple of displays that would fit in the original cutout like the one in the gear indicator cutout. Currently doing the PCB layout, which is really time consuming. But maybe i add one or two display connectors for future possibilities. But as long, as they run on the same bus, it should be no problem. Maybe more than 2 displays on one controller can really slow down the code. Need to test this. But would be nice to draw boost or AFR graph in one Display and show values on the other.
The full lcd/oled is a very different story. The need so much more power (a Due or Raspi) to work correctly.
And also have to say, full lcd is great as Racedash. But I like the Gauges with real needles...so the idea of the project was to hold the nice millenial e46 design.
