e46 M3 Tire Sizing Thread
  • crbws6
    Another potential DSC issue to watch out for is due to different sidewall stiffness front and rear. I recently had to install different rear tires which are softer than the older fronts. I was unable to match tires due to the older tires being out of production.
    F: 245/35/19 Bridgestone RE-11(stiff) and R: 275/30/19 Firestone Indy 500 (soft). The delta in sidewall stiffness now generates enough yaw to activate the DSC on hard corners or sweepers with any bit of a bump. And this is without any perceptible tire slip.
  • Albino09
    Originally posted by SP-1 View Post
    Is there a reason why 265/35/19 wouldn't work well for the rears? Seems to have a circumference that is closer to stock than 265/30/19, which seems to be a much more popular size.
    While it is a good idea to stay close to OEM size for the speedometer's sake, what's more important is matching the diameters of all 4 wheels (or a close approximation thereof). The way our car's traction control works is by checking wheel speeds against one another. If the rear wheels see a higher speed than the fronts due to a diameter difference, the vehicle will cut power assuming there is wheel spin. If you plan on driving around with the VDC off all the time, you won't run into this issue.
  • SP-1
  • George Hill
    And there is also www.willtheyfit.com great source I use often.
  • kaiv
    The miata.net calculator is cool but these are my favorite:
    Tire size calculator:
    The best tire size calculator. Use our tire size calculator to find tire size specs and suggested tire sizes. Then check prices for all available tire sizes.
    Wheel offset calculator:
  • liam821
    Thanks for Obioban for this
    Offsets:
    First, let's start out with a definition of what wheel offsets are, so people can follow.
    From tirerack.com:
    Originally Posted by tirerack.com
    The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (measured in millimeters).*
    Zero Offset
    The hub mounting surface is even with the centerline of the wheel.
    Positive
    The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
    Negative
    The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
    If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
    On the M3, and all modern BMWs for that matter, the offsets are negative. Therefore, the smaller the offset, the more aggressive (or pushed out) the wheels are. Moreover, adding a spacers will decrease the effective offset. For example, adding a 10mm spacer to a 35mm offset wheel will make the offset 25mm.
    Spacers: Whenever possible, spacers should be avoided. Neon01 explained why very well:
    Originally posted by Neon01
    1. You add to the weight of the wheel, effectively, which is never good for bearings
    2. Assuming the "face" of the wheel is relatively flat, you're adding a moment arm through which the wheel will torque on the hub (bearings). For example, if I have a wheel that is an ET22, the wheel face will be located pretty close to the center of the wheel, and the compression forces of the car acting through the hub are in the same vertical plane as the wheel face. The same is true in the case of the ET45 wheel, but when I add a 20mm spacer, I've now added a torque to the face of the hub in addition to the simple shear force I had before. With the spacer, the force is vectored down in the plane of the hub, which is transmitted to the wheel through the spacer. The wheel is directing its force on the spacer vectored upward, so the spacer moves the planes apart by the 20mm, which creates a torque on the wheel and the hub from the upward force of the wheel and the downward force of the car. Maybe this wasn't that clear, but it is true.
    Spacers create more stress, add weight, and create more possible sources of vibration. Whenever possible, buy wheels in the correct size/offset and skip the spacers.
    If you do run spacers, and sometimes they are necessary (I need them for my snow wheels to clear the BBK, for example, Whenever possible use hubcentric spacers. They're much safer, and stress the car much less than non hubcentric. It's also an extremely good idea to get a stud kit. They make a stronger construct, they're less likely to loosen themselves, and they make mounting/dismounting tires much easier.
    M3 Offsets:
    Okay, so, now that you know what they are, how do you find the right one for the car? Well, originally with a measuring tape, shims, spacers, etc… but we're past all of that at this point. What works well on the e46 M3 is pretty well establish at this point.
    So, here's how I'm going to do this: I'm going to list the best offset for a given size wheel (best meaning biggest tire fitting. You bling guys can make your own thread about stance, flush, etc), and the tire size you can fit on that. From there, if you wan to run a more aggressive wheel, you just decrease the tire size from there (aka, for every 5mm more aggressive you go, reduce one tire width (tire widths go in increments of 10mm, half goes on the inside, half on the outside, so every 10mm decrease in width brings it in 5mm on the outside)).
    And I'm just going to focus on wider wheels with bigger tires, as smaller wheels/tires fit fine over a wide range of offsets.
    Assume stock fenders, no rolling, no fender liner removal.
    Front:
    9": ET38. All tires 265 and smaller will fit, some 275s will fit.
    9.5": ET35. All tires 265/35/18 and smilers will fit. All 275s will fit with some extra camber in the front. SOME 285s will fit-- this will vary from one tire model to the next.
    10": There's no reason to go with a 10" front
    Rear:
    9.5": ET27 will fit all 275s and most 285s with the proper alignment
    10": ET27 will fit all 285s and some 295s with the proper alignment
    Special Case, track setup:
    For the track, it's beneficial to run a square setup so you can rotate tires (extends tire life) and dial out understeer (matching front and rear tire sizes). The Optimal setup for this is 18 x 9.5 ET35, with a 10mm hubcentric spacer in the rear. This setup allows you to easily run 265 tires square, 275 square with some alignment tweaking, and 285 square if you work at it.
    Take away: Clearly the offsets listed above are not the only offsets. What they are is the ideal offsets. Generally speaking, for every 5mm of variance of the above offsets, you need to decrease the width of the tire by 10mm.
    NOTE WELL: There are lots of factors involved with tire fitment. Alignment, the specific fenders on your car, the model of tire you go with, etc. The above is generally true for the e46 M3, but there are exceptions. If you want to be guaranteed to have no fitment issues, don't push the tire sizes. The smaller you stay, the less issues you can run into!
  • liam821
    started a topic e46 M3 Tire Sizing Thread
    You can play with tire sizes to your heart's content here: http://www.miata.net/garage/tirecalc.html
    Quote Obioban:
    Everything in this thread is aimed for optimal. There are lots of things you can do that are not listed here. I'm well aware that some people love the look of 11" wheels and have made it fit, and claim no decrease in handling, ride quality, etc. Congrats. This thread will focus on the best possible setups from a functional perspective, and you can vary it however you want from there.
    This first post is not about fitment. Just because I list a setup as matched DOES NOT MEAN IT WILL FIT ON YOUR WHEELS OR IN YOUR FENDERS.
    I'm going to attempt to lay down some basics for tire sizing on this car. This thread is going to be geared mostly towards street use, where DSC interference matters.
    Okay, ground rule: You want the front and rear tire to have, as close as possible, the same rolling diameter. DSC works by comparing the rotational speeds of the various tires. If your rear tires have a smaller rolling diameter than the car expects, and the fronts are the same, the DSC will think at all times that you are having slight wheel spin (as the rears are rotating faster than the fronts). If the system is predisposed to thinking that you have slight spin, then it's much more prone to intervening-- it'll take much less to set off the DSC. That makes for unfun driving dynamics.
    Before going any further, I think we should make everyone has an understanding of what tires sizes actually mean, as it's not as intuitive as you might thing. I'm bolding the middle part on profile, as that's the key part to all of this and the most misunderstood:
    On the side of every tire is a host of numbers and ratings that describe the tire and its performance characteristics. A typical tire size numbering system will appear as a string of letters and numbers, such as this example: 215/70R16
    215/70R16
    The numbers before the slash (/) indicates the section width of the tire; the widest point from sidewall-to-sidewall. The larger this number, the wider the tire. This number is the wide of the tire in millimeters. In this example, the tire has a 215-millimeter section width.
    215/70R16
    The next number trailing the slash (/) indicates the height of the tire in a percentage of the section width. In our example, the number is 70, which means the tire height is 70% of the section width, which is 215 millimeters. The height of this tire would be 150.5 millimeters. The lower the number is, the lower the profile of the tire.
    215/70R16
    The next letter is reveals the construction of the tire. The most common is “R” such as found in our example. The “R” designation states the tire is of radial construction. Other construction types are rarer for modern passenger car use, and may include “D” for bias ply construction and “B” for belted tires.
    215/70R16
    The number following the construction code is the size of the wheel in inches. The example tire would be designed to fit a 16-inch wheel. Tire sizes on modern vehicles typically start at 13-inches and go up to 18-inches, but aftermarket and special package wheels can be 22-inches or even larger.
    Take away: If you go with a wider tire, you need to run a smaller profile percentage to have the sidewall (and circumference with it) not become larger.
    Okay, moving on:
    The stock M3 tires sizes are
    225/45/18, circumference: 81.6"
    and
    255/40/18, circumference: 81.8"
    225/40/19, circumference: 82.0"
    and
    255/35/19, circumference: 81.8"
    Notice how the circumference is nearly identical in stock spec. The closer you keep to that ratio, the less DSC interference you'll have. The numbers are close enough that for ease of use I just stick to 1:1.
    Okay, so let's expand upon this. Most of us don't want to be running the stock setup as 225 is pretty small and understeery. So, what options does that leave us? Well, two categories: staggered (30mm) or square.
    Staggered pairs that work well together:
    18":
    and
    235/40/18, circumference: 79.8"
    and
    265/35/18, circumference: 79.5"
    245/40/18, circumference: 80.8"
    and
    275/35/18, circumference: 80.4"
    and
    285/35/18, circumference: 81.2"
    and
    295/35/18, circumference: 82.1"
    19":
    and
    235/35/19, circumference: 80.0"
    and
    265/30/19, circumference: 79.4"
    245/35/19, circumference: 80.9"
    and
    275/30/19, circumference: 80.1"
    and
    285/30/19, circumference: 80.8"
    and
    Square setups that work:
    One final note: For the purposes of DSC, all that matters is that the front and rear have nearly the same circumference. That said, as you get further away from the stock 81.7", the speedo will read faster and faster at the same speed (and the speedo comes about 5% fast from the factory, so you're just making a bad situation worse).
