Help diagnosing high water temps at track - Resolved? (not really!)
  • bigjae46
    I can’t imagine going through life as not a DIYer. Every time I pay people to do things, I am incredibly dissatisfied with how well it’s done.
    Just went through this with a body shop. Now I’m seriously considering learning how to do body work.
  • Obioban
  • jet_dogg
    Since we are on the topic of radiators and cooling...remember to keep those cooling fins clean by blowing them out once in a while from inside the engine bay outward. For efficient cooling and heat exchange, air needs to move through the fins. Especially the oil cooler, which sits low and exposed, while radiator gets some protection behind the ac condenser.
    My issue with csf rad in old forum was just getting the thing to fit, the welds were so poor that they did not fit properly into plastic framing to secure the radiator to the chassis.
    If I was a diy'er I'd definitely have air in the garage along with an air comb for this exact purpose.
  • mrgizmo04
  • bigjae46
    CSF strikes again haha. I wonder when people are going to learn.
    I can't help but chuckle when people spend more money than oe on parts that are actual junk which is not often but often the case with radiators and csf.
    Glad you got this resolved BR.
    This is one issue that was documented on M3Forum. Some people have an issue with the CSF radiators and other don’t.
    I have a CSF and it has been fine. If I had to do it again, I’d go with OE. Really no point on the M3. For a non-M, makes sense since the whole cooking system is like a ticking time bomb.
    When it comes time for a radiator, I will go back to OE.
  • jet_dogg
    Originally posted by Fresh1179 View Post
    Moderator please label this post as NSFW and and with an appropriate trigger label. 😁
    Should just make my first post in this thread a sticky 😎
  • Fresh1179
  • cobra
    Original equipment parts are required to have so much testing done. Even though they may be built in a way that looks "boring" due to cost saving measures, they are surely vetted more than most aftermarket parts to meet internal and BMW durability and performance standards. CSF has to do nothing but make it look nice.
    That said, I don't agree with the excessive use of plastic on OE parts but it is what it is. Replace every 100k miles.
  • jet_dogg
    Or you could have simply used an oe rad for less and is not made in china.
    I also quite enjoy when people use the term defective when describing their experience with csf radiators. Seems they are all defective in that case.
  • BigRussia
    Hey all,
    Sorry for not updating in awhile, but yes the cooling issue was resolved! It was the damn CSF radiator!
    After installing a brand new genuine OE BMW radiator the cooling issue was resolved. Already done two whole track days since the job and water temps stay under control and under 200F, with the needle pinged dead center. Only one time did I get it to move up slightly during November, around 210F when I was absolutely dogging the car 10/10ths on back to back laps trying to chase down faster cars. Once backing off it came right back down to center under 200F. Our Novembers are not actually cool here so was a normal nice warm day.
    This past weekend did the 2nd full track day, 4 x 30 minute long sessions and car stayed well under 200F the entire sunny day, even with setting a new PB that was 1.5 seconds quicker than my previous. Granted it was one of our coldest days of the year and I had the heater on, but yup overall very pleased the issue has been resolved!
    Click image for larger version  Name:	C9C1CF13-3815-4FC7-90A0-D2887068A4D6.jpg Views:	0 Size:	104.8 KB ID:	151511 Click image for larger version  Name:	image_31765.jpg Views:	6 Size:	77.9 KB ID:	151509 Click image for larger version  Name:	image_31766.jpg Views:	5 Size:	197.3 KB ID:	151510
  • bigjae46
    Deleted AC
    Deleted heater core, aux pump
    Blocked off water pump and water pipe outlets to aux pump (JB welded freeze plugs)
    No fans
    CSF Radiator
    Canton 2Q expansion tank
    ​​​​​32psi coolant cap
    OE t-stat
    OE water pump
    OE pulleys
    OE shrouds in the front
    100% distilled water with water wetter - because running coolant on track is generally frowned upon.
    I run 275 NT01s, I consider myself an advanced driver. Water temps never get over 190 degrees even in 90+ degree weather with 60% humidity. I still can run into oil temp issues if I really abuse the car.
    I trailer my car to the track. If you want the car to reliably run cool in any condition...you pretty much have to trailer it. Or at least trailer it when its hot. or cool enough where you need heat.
    I've had the popular straight blade SPAL fan and also the highest output fan that SPAL makes. Both did an excellent job of cooling at low speeds. It would drop temps in the paddock by 20 degrees very quickly.
    I welded some bungs in the thermostat housing for some temp senders - one in the feed to the radiator and return. The biggest cooling gain I had was removing the fan. About 15 degrees at speed. The drawback is it won't be able to withstand stop and go traffic AND MUST be mindful to cool the car down.
  • Tonggi
    Having toured Mishimoto's facility, I'm not at all surprised that it isn't
    so upgrade to mishimoto when the time is right, got it! My OE rad is working wonderfully.
  • Obioban
    Originally posted by GolanM3 View Post
    Obioban
    Can you share any information you have on WW or TTFS tunes being harmful for these engines? I'm particularly interested in your experience/knowledge on the TTFS before I spend hundreds of $$$ on a new tune.
    I’ve just seen a couple engines go pop on track due to detonation with the TTFS tune. That’s not a common failure, either— never seen that failure on track without a TTFS tune.
    Water wetter creates deposits over time. If you’re only going to own the car for a couple of years, you probably won’t suffer the consequences. If you do, you’ll be sad you used it.
  • Obioban
    Hey Obioban , I was thinking of replacing the hoses while replacing the radiator as well, the current ECS silicone hoses have held up fine and had no issues with them but maybe its good to put new hoses at the same time in case any gunking from before. Wanted to see your recommendation if I should replace with OE genuine BMW hoses, or OEM Rein is fine too? Or just keep the ECS ones? (The oem Rein are much cheaper than the OE BMW ones at least).
    I’ve never seen anyone have issues with the ECS or Rein hoses. Don’t think there’s a wrong choice there.
  • BigRussia
    When you put the OE rad it, seems like a good time to stop using water wetter, as well!
