Originally posted by heinzboehmer
Best Battery Replacement Options
Wow. Glad I installed those rubber terminal covers. I don’t run with the plastic battery compartment shelf anymore since I need access to the restart button on the battery. I’ve often worried about a stray wrench or something shorting the terminal.
Worse than traditional ones lolOriginally posted by eacmen View PostI don’t know how lithium batteries react when shorted to ground but traditional ones its dangerous.
Just to provide a data point: Car sat in the garage for 4-6 weeks (battery connected, no charger) and just started right up without hesitation.
Antigravity ATX-30
Thanks for the input! I obviously hadn't considered the potential for a short after an impact. I have some aluminum I can fabricate into a more sturdy strap like above. Appreciate it!Originally posted by eacmen View Post
I would not trust that in a wreck.
Background: We had a CSL battery in our old car with the OEM mount. Cranked down the mount and the battery was TIGHT. Passed tech at every event, even the anal ones. Got in a wreck on track and the battery still shifted and shorted to the chassis and was hot to the touch. Marshals got to it real quick so it didnt start a fire.
Keep in mind its not just about flying away, the battery can’t shift at all in a wreck.
Personally I would reconsider this solution.
Like this one?: https://www.walmart.com/ip/EverStart...0-CCA/40647529Originally posted by TramRam View PostI went with an H8 sized Wal-Mart Platinum Ever Start AGM & love it. The car has sat for a month and NO PROBLEM cranking! If you track the car you might be concerned about its weight. H7 is the standard size but the H8 fits into the existing bracket perfectly with no mods. It's all about what you do with your car.
I would not trust that in a wreck.Originally posted by ZHPizza View PostI actually bought some stretchy velcro straps for mine lol
Saw a guy post about that setup in an e90 and was like well shit I guess it really makes sense for holding something that light.
https://www.m3post.com/forums/showpo...72&postcount=6
I actually bought some stretchy velcro straps for mine lolOriginally posted by Radekxpl View Post
Good looking solution 👍, about pull a trigger on ATX-30 will need mounting solution.
Just get an OPTIMA Red Top with a BimmerWorld mounting tray.
For a street car that is driven once every 2-3 weeks, would you guys recommend the Champion H5 or H7?
Wanted to know your opinions both in terms of fitment (easiest to install and fit) and in terms of starting reliability without a trickle charger. Or if you guys recommend a better battery/set up for cars driven once every 2-3 weeks.
Below are links of the sample batteries in this thread:
Thanks.
Thanks. I’m not aware of any off the shelf brackets. I think you’re going to have to fabricate something.Originally posted by Radekxpl View Post
I had a hard time finding battery post nuts for the charger pigtail. I got sick and tired of hooking up the tender/charger clamps to the battery terminals. I found these worked well for the motorcycle-style battery terminals and let me mount the charger pigtail to the battery permenantly:
BikeMaster Battery Bolt 6x10mm... https://www.amazon.com/dp/B004C1ZRMO
I love the antigravity battery for my track build. Same size as oem so I didn’t need to modify the battery strap but and it’s about 6lbsOriginally posted by eacmen View Post
If its a street car with options (radio, heated seats etc) then just go for OEM equiv (H7 i believe).
If its a track car or dont have much electronic options then the CSL/Mini battery is a good ligherweight option (H5 i believe)
Beyond that is the lithium options which are big money and a pain in the butt for a weekend street car, but worth it for a track car.
I own an antigravity battery and I don't mind it for a track car I know I would hate it on a street car.
I went with a Champion H5 for $125, slightly smaller and lighter then stock H7 and have had no problems in my weekend streetcar.
Good looking solution 👍, about pull a trigger on ATX-30 will need mounting solution.Originally posted by eacmen View Post
Sorry it took so long. Just got the car back in the garage. Here are the pics of the bracket that was fabricated for the anti-gravity battery. Basically two L brackets and one large U bracket. Some flat aluminum bar stock and a metal brake should make easy work of this.
Sorry it took so long. Just got the car back in the garage. Here are the pics of the bracket that was fabricated for the anti-gravity battery. Basically two L brackets and one large U bracket. Some flat aluminum bar stock and a metal brake should make easy work of this.Originally posted by eacmen View Post
The car is in storage right now. I'll snap a pic next time i go see her.
I would seriously reconsider getting the restart button if you can. Otherwise you will need a jump starter if the car sits for too long.
