Questions on running OE CSL/ZCP 19x9.5 et 27 squared on the e46 M3.
  • 0-60motorsports
    Originally posted by BBB View Post
    Click image for larger version Name:	IMG_3816.jpeg Views:	0 Size:	171.5 KB ID:	74998
    Click image for larger version Name:	IMG_3813.jpeg Views:	0 Size:	204.1 KB ID:	74999
    Click image for larger version Name:	image_18923.jpg Views:	5 Size:	170.5 KB ID:	74996
    Click image for larger version Name:	IMG_3808.jpeg Views:	0 Size:	198.5 KB ID:	74997
    Couple notes - my garage floor is slightly uneven so the rear wheel gap is bigger in the pictures than it naturally sits. The top of the wheels do not poke front or rear either although it's hard to illustrate that in the photos.
    Well that looks gorgeous! I need to do this as well LOL. Im running 380mm ST60/ST40 on GC Coilovers. Ride height is 13.5"/13" and i dont plan on going lower. Anyone running the same BBK and can confirm if the Rear CSLs will fit up front?
  • Thomas131
    Originally posted by bmw m3 s50 View Post
    Does anyone know how thick the back pad is on the CSL/ZCP 19x9.5? Also how thick the lug bolt seed is from the backpad?
    I’m doing some research into this myself. Any verdict how it all worked out?
  • Mystic3
    Question on your direction for shocks.
    which Koni Yellows are you going with ?
  • Los888
    Useful Info on this setup. Looking forward to go square down the road.
  • bmw m3 s50
  • bmw m3 s50
    Thanks man. Yes, -3 front and -2 rear. I'm on some GC coilovers/camber plates that are on the way out. Can't speak for the PS4s, I don't have personal experience with them.
    Gotcha, thanks for the pics and info.
  • robgill
    Did you swap them out to progressive springs? I thought the Ohlins came with linear springs? Even though they look like OEM progressive springs to mate with the stock top hats.
    Is the progressive spring your running the same size as all other progressive springs?
    I have the Ohlins "Road and Track RTR" with progressive springs, stock tops and dinan fixed camber plates. I tried to run 265/35 PS4s and they did rub the spring a tiny bit. 265/30 Cup 2s did not rub.
  • BBB
  • bmw m3 s50
    Those 19x9.5’s square setup looks so amazing on the e46 m3. You can definitely see the camber up front.
    What suspension are you on?
    Your on -3 degrees camber up front?
    You think you would have problems with a wider Michelin PS4 265/30/19?
  • BBB
  • r4dr
    I thought 19x9.5 with et 30-35 was needed to run up front to be able to fit a 265/30/19 or 275/30/19 tire. I remember running a 19x9.5 with et33 with both a 275/30/19 and 265/30/19 with minor camber and without any issues.
    9.5" with et35 is the "easy" fitment that doesn't really require camber up front. But going from et35 to et22 is pushing the wheel out more than half an inch, and it gets trickier. CSL et27 is halfway there.
  • bmw m3 s50
    I'll post some pictures in a bit. Even with a 10mm spacer and -2, the rears looked slightly sunken. It might sound crazy, but the extra 2.5mm made an impact.
    When I bought the car, the previous owner was running 265/35/18 on 18x9.5+25. Alignment shop showed -2.5 camber on that setup. The fenders were completely untouched. It did rub very slightly at full lock before I modified the fenders. 265/30/19 is roughly the same overall rolling diameter as 265/35/18 (actually 1mm smaller per willtheyfit).
    Still would like to see the pics of your car with the wheels.
  • bmw m3 s50
    Originally posted by robgill View Post
    Thanks! I have run Cups and PS4s with no issues. Also my Ohlins are a progressive spring. I haven't done much research on the back pads so not much to add there.
  • bmw m3 s50
    Not at all. Most that run 9.5 up front run et22. Csl 9.5 is et27, so it's an even easier fit. Neg camber is what's needed, and 265 tire not 275 tho that might just work too
  • BBB
    Can you post some pictures of the setup? I like how the fronts look with camber dialed in, but it seems like the rear is sunken in a bit by comparison without a spacer. Would love to see your setup.
    So you would require front fender modification for it to work?
