Solid Mount Short Shifters: CAE / IRP / RTD / AAF / Coolerworx
  • jareds941
    Originally posted by BlAikenstein View Post
    That kinematic shifter looks nice. The side stops would be great for smg swaps and I prefer the look/simplicity without the reverse lockout. Good seal to the trans tunnel and simplified install are big pluses. Morespeed made a motor Mount that would pair well with the akg metal cup + e30 trans mount too
    I’ve got the bimmerworld “group N” motor mounts and stock trans mounts for now. The stock mounts are like new, and so far so good. I’ll know at the track for sure if there seems to be an issue but Kinematic indicates upgraded isn’t necessary. And yes, the rubber seal is solid.
    What do you mean with regard to the side stops and SMG swaps? Just curious as I don’t know enough about that to understand it.
  • BlAikenstein
  • jareds941
    Got it installed...still need to work on cutting the boot to fit this new shifter. Did a short test drive and loving the shifter. So crisp and short with the shifts. It's pretty loud with each shift, which is perfect for race/track car. I'll have it on track in about a month.
ID:	87950 Click image for larger version
ID:	87951 Click image for larger version
ID:	87952 Click image for larger version
  • PHNX636
    Originally posted by deeznutz972 View Post
    Love my rtd but any suggestions on how to reduce the trans heat? It’s melting my center trim haha
    Use an E30 insulation boot its smaller than E46 but kind of annoying to get on.
  • Gearhead55
    Originally posted by eegstwozero View Post
    Curious on this as well. I installed 95A motor/trans mounts along with my RTD shifter and I hate them. Even on a track focused car the vibration is too much for me. Wouldn’t mind going back to stock, or near stock you can with a solid shifter.
    For the record, I went with OEM replacement motor and trans mounts. The NVH feels like refreshed stock and the shifter still feels great. Still felt great at the track.
  • jareds941
    My Kinematics shifter arrived. Looks and feels great in hand. I started the install today...but probably won't have it in for a few days.
  • mrgizmo04
    Originally posted by Jevi Javi View Post
    did you install yet?
    Waiting for that review...
    It's been in the car for a few weeks, however, car's been on jackstands for a while now (partially why I'm not as active on the forum lately). Started with smogging (intake/exhaust/e85/etc), then I dove in to replace a few front mounts/bushings, then discovered that my diff was a bit fried, so been working on replacements, then I dove into solid rear subframe bushings, other bushings, looking for the right bushing press/cup/sockets for while in there parts, some parts on backorder, etc.
  • eegstwozero
    So I am about to replace the motor and trans mounts in my car. I have the AKG shifter and I am debating on whether I should go with OEM trans and motor mounts or something stiffer. I would like to keep NVH as low as possible since I street drive the car relatively frequently. I am leaning toward OEM for both, though theoretically you should stiffen the trans mounts when using a solid mounted shifter, right? I also have heard that the trans and motor mounts should match density. I would love to hear peoples opinions about what to use.
  • Lip
    Are those woes about the CAE design in general, or having to carve shit up in E46 cars?
    I watched a few installation videos. Def need to get the alignment perfect which is difficult considering CAE doesn’t use stock mounting points.
    With that said, people who tried both CAE and shifters like RTD prefer CAE.
  • Tonggi
    Question for those with an RTD mini, when in neutral your shifter is centered correct? Not to the right and off centered like some have experienced?
  • r4dr
    Originally posted by sc_tr0jan_m3 View Post
    i've heard from one of my buddies who also ordered that they solved a lot of the installation woes from the CAE and others. that seems to be the biggest upside of this new product.
  • jareds941
    Well, considering pre-order pricing was $600 if the installation is easier (they do directly mention contained fasteners as one way it is easier) then I'll be quite pleased if it also drives well. Doesn't have the reverse lockout function, but honestly not too concerned about that.
  • sc_tr0jan_m3
    Originally posted by jareds941 View Post
    Well, I pulled the trigger on the pre-sale price for the Kinematic Speed option. Should ship in a couple weeks (2.15) and then I'll look into installation...I've never messed around with anything in this zone, so we'll see if I can figure it out myself or if I'll have to pay for it. I hope they provide some decent installation materials. There's a local shop where you can rent a bay with a lift by the hour...might just be worth it for this install I'm thinking.
  • jareds941
    Funny I was just about to post this same link. I'm tempted too...
  • Jevi Javi
    I ordered a Coolerworx Pro (will install in the next month, dealing with smog and few other things at the moment). From what I heard from folks who have run CAE/RTD and the Coolerworx one, Coolerworx is closer to quality of a CAE for the price of an RTD. I got the direct fit plate, so hopefully that will simplify the installation. They are in Europe, but shipping was pretty fast. It has lockouts for R/5/6.
