  • duracellttu
    Had me searching deep for the pic.
    Nice, looks like you have some significant weight reduction.
  • Cronenberged
    Can you share your corner weights?
  • mrgizmo04
    Yes recommended by FCM, based on corner weights and dual use. Don't have have aero yet, but eventually.
    I guess I can see it if your car is rather stripped where you are carrying closer to 55-60% of weight in the front.
    What are your FRC and hz ratio per FCM setup recommendations?
  • mrgizmo04
    Is the approach to aim between a 45-70 mph flat ride?
    Yeah, remember, it is somewhat "static", so you need to aim for avg cornering speeds on track. That will differ on a more technical/slow speed vs a more open higher speed, but 45-70 is a decent range.
  • duracellttu
    Yeah that's set up for "flat" ride at like 300mph with those frequencies...
  • mrgizmo04
    Per the spreadsheet, those spring rates give you a 1% flat ride.
  • duracellttu
  • Cronenberged
  • duracellttu
    My previous suspension was TCK SA and after talking with TC he recommended 400F/500R spring rates. Any idea why the spring rates are so much different than flat rides approach?
  • duracellttu
    With those rates it sounds borderline pitchy, and adding GC on full stiff to those front rates sounds very understeery...
    Did FCM suggest these rates/bar settings? Are you running heavy aero/splitter to counter?
  • mrgizmo04
    I went with a build directly built by FCM.
    H&R street coilvers
    450lb 6" f spring
    800lbs 6" r spring
    GC weighted jacks
    GC front Sway bar stiffest setting
    OE rear sway bar.
    Will give some feed back as soon I get everything in and on the car.
  • duracellttu
    For those on a budget, my current setup according to the calculator and butt dyno is flat ride.
    Bilstein B4
    Eibach pro kit springs
    Hotchkis F/R sways medium front, soft rear
    Great comfort, bumps even with Hankook v12 (awful sidewalls) feel smooth, car turns in very well, and isnt unsettled at motion changes/apex bumps. Couldnt be happier, as it nearly feels my like old MCS setup. Ride height is fixed, but low enough where it looks OE+ but not low enough where its compromising the control arms/bushings.
    What are you spring rates? Also, did you measure corner weights?
    H&R street coilvers
    450lb 6" f spring
    800lbs 6" r spring
    GC weighted jacks
    OE rear sway bar.
    Also curious if you measured your corner weights before FCM recommended spring rates? Were these spring rates aimed towards a sporty or more race focused setup?
  • Cronenberged
    H&R street coilvers
    450lb 6" f spring
    800lbs 6" r spring
    GC weighted jacks
    OE rear sway bar.
  • Chas3n
    Bilstein B4
  • r4dr
    Hmm, seems like you’re right.
    well, something is different and I forget what, it seems. Whatever it is, the result is that the US cars need the strut spacer and the euro cars don’t.
    Is this true for US cars regardless whether it's using stock top hats or camber plates?
