The Phoenix: My Build Journal Excerpts
This topic is closed.
  • Epoustouflant
    Some more shenanigans!
    I tested fitted the Recaro CS and BK mounts. No spacers needed for my height, it doesn't hit the center console like the PP ABE mounts.
    I also put the OE boot on. It needed to be cut as I was unbothered by attempting to remove the knob off the RTD. I'm working with a company to do a clip-in flat panel that will be upholstered to specs for the upcoming RTD group buy.
  • Epoustouflant
    I need to find time to install the CSL airbox now. I also pulled the recall campaigns off the VIN. Airbags need to get done still.
  • Epoustouflant
    I need to update this soon, here are a few things recently done.
    Engine work is done: VANOS is bulletproof'ed, rod bearings & bolts got swapped, 288/280 cams are in time, valve adjustments done.
    Most importantly, the S54 is back in the chassis. The car will be on the road in 2-3 weeks, maybe - if coilovers, seat brackets and a new top reinforcement kit makes it in time.
  • Epoustouflant
    Matt, the color is stunning! Thanks for the journey.
    maw
    : ) Thanks for following.
    Last body panels are finally getting sprayed this week!
  • maw1124
    maw
  • Epoustouflant
    NEW BUILD JOURNAL ENTRY
    Let 'em brag
    Linkto the full entry.
    Special Series: S54 Schrick Cams
    In this new entry, I unbox my S54 Schrick cams, I look back at the CSL uprated cams and how we can improve upon what BMW spec'ed for the street.
    I touch on the fundamental camshaft nomenclatures of duration & lift, and rationalize my decision making process on the 288/280s.
    Sign up on the waiting list for the upcoming Social Buy here. The S65 and S85 applications are on board as well.​
    See below for the preview.
    Up next: we get the OEM camshafts out, compare them side by side with Schrick, and get the new camshafts in fast.
    Or so I thought, AH!
    It'll be a great opportunity to touch on the valve adjustment service and what it entails.
    Cheers,
    Matt
    @m3_epoustouflant
  • Epoustouflant
    OE new ones? Interesting.
    Correct!
    Yes you can still obtain replacements from BMW, I recall from when I looked into this that some of them show differences compared to the originals that came on the car.
    Note that any that include VIN etc require a dealer to sight your vehicle before they can be ordered.
    That's 100% right.
  • karter16
  • 0-60motorsports
    BMW
  • Epoustouflant
    I really like the labels. Who made them for you?
    BMW
  • 0-60motorsports
  • Epoustouflant
    The Hiatus is over!
    Link to the full entry.
    Special Series: Restoration of The Phoenix
    Link to the complete series.
    In this entry, it's a test of patience.
    The build is put to a stop as parts slowly creep in and shop time gets limited. I document the bottlenecks and give a quick preview to the parts that came in.
    I had forgotten how much there was to this restoration and CSL’ification.
    Up next: we get back to work.
    In late June, the carbon doors finally showed up. Doors get ready for paint. The subframe gets reinforced and the engine work is back on: time to slap some cams in this straight 6.
    Cheers,
    Matt
    @m3_epoustouflant
  • Epoustouflant
    Ha! Nice touch with the Phoenix yellow subframe!
    I have no merit - it's from a previous experiment
    You really get a sense of how raw the E46 M3 is when you compare front and rear subframes - the E9x are quite literally twice the size.
    Click image for larger version  Name:	REC05991.jpg Views:	0 Size:	156.5 KB ID:	214072
  • Epoustouflant
    He put phoenix yellow where it can't be seen. Now that says a lot about PY !
    😂 I will never please PY purists but hey I tried - I went with the black underbody for it to give it a chance, c'me on now!
  • Maxima SE
