nice work! Love the Slick top Silver Gray
Tyler's 04 slicktop 6spd Silvergrey MCS/BBS/Brembo/CSL/Karb/Nogaros/Supersprint
Thanks!
September 2018
TMS had a great sale at the end of '17 on their pedal kits. I wasn't a big fan of most pedal kits with large rubber grips plus I didn't want silver with my mostly black theme. TMS' black pedals were my fav anyway, so I grabbed them on sale. I also then got a Mason Engineering clutch pedal (formerly GSP). I also grabbed a set of brass bushings for the clutch and delrin bushings for the brake pedal. These are self lubing and thicker so as to eliminate slop. I also, manually (as opposed to software) disabled the clutch signal to start the car.
We've been learning more about RACP issues, and the fixes that many of us long term owners have done are now incomplete/insufficient. While I wait to further reinforce the car, I picked up a cheap rear strut bar (ebay). It came white. I had left over yellow caliper paint so I thought I'd be smart and match 'em.
I also wanted to get a custom license plate. Growing up in Socal, I've always loved the "arts" plate with the palms trees and sunset. I figured I'd take it a step further with a little inside code, NA S54.
Last edited by Tbonem3; 07-24-2020, 01:26 PM.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
January 2019
I bought a barely used SGT SCZA muffler. I already have the OG scorza, but my friend loves them too so he could take one and plus I thought it'd be cool to see how close it was to the og.
Mees hermanos may he canos know bout that blanket super suave
Well they look really similar as far as dimensions. Different steel, slightly different mounting arms. Mostly just looks newer. Same 2.5" piping, mostly similar welds. Sgt's feels slightly cheaper/sloppier. To be fair, the og isn't like my SS sport either though.
I had gotten lucky and come across a separate set of sgt tips in 82mm brushed stainless only weeks prior to getting the scza. My original plan was to put them on my stock exhaust for when I'm ready to calm it down, but it worked out where I could use them for the scza as it came with new 76mm black tips (similar to dinan).
Something in those big boxes
Mounted:
I had been contemplating a rack switch. I narrowed it down to zcp(csl) blue or zhp yellow 712. I found a 74k really nice zhp one on ebay for a song (I love ebay deals; a trend throughout my journal).
At my mileage, I like to replace basically everything when I work on an area. I first got a new Rein high pressure line, but shy'd away (due to not so good rep) when a friend gave me his newer, low mileage OE part. I bought new OE lines altogether, plus a new housing and fluid of course.
Oh ya, and after liking the TMS sway, but wanting to lower weight, I got a hotchkis front bar too and new lemforder links cause why not.
Nasty. Used the special disconnect tool. Didn't work too well, had to pry them off with a flat head too.
New hose clamps on the boot to rack ^. v Polished the plate lil bit
Last edited by Tbonem3; 08-27-2020, 10:54 PM.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Thanks, always!Originally posted by 8000RPM View PostNice and clean underneath! It always feels good to do a proper “while you’re in there” when you’re working on a project.
Ya a bit, it's not the greatest system. What I did was get them pretty close to where I want, tighten them most of the way, then use a rubber mallet to tap them into the final place and tighten the crews all the way. You can even tap again even after tightening the screws. The trick to to pull the tip in the direction you want with one hand, while tapping it in that direction with the mallet in the other hand.Originally posted by BMWahba View PostDamn - seeing your SCZA makes me cringe at mine. It's sticking way further out than yours. Did you struggle with adjusting it at all?DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
February 2019
TMS had a big sale on their monoball fcabs, so I decided to try them out. I had a set of used lollipops, so I was able to press them in ahead of time.
Well, I really hated this mod. The steering wheel felt numb, less resistance, just alien and I didn't like it at all like not even close. Car didn't behave any better that I could sense. It is a street car, after all.
Put the car back up on stands and got some new OE FCABs. Ahhhhhh back to that steering feel I love!
I also really really missed the exh tips from the SS Sport plus my fav of all time are Eisenmann lemans (slanted) so I decided to slash cut my SGT tips to recreate that.
Fock ya!
Also put in 6" 600lb eibachs vs. my 6.5" GC 550lbs. Didn't like it, swapped back right away just too harsh. My car is super light, esp in the rear, and a street car, so lower spring rates are better I've found. Every time I deviate, I keep coming back to this custom GC 550lb eibach spring, it's just perfect - barrel style for more travel before blocking. 600 would be better if I had stock muffler and stock battery and mobility kit and trunk tools etc...
This rear pass side bumper sag finally got taken care of with a simple, cheap (how often can you say that) OE part.
M3 gusta
Hmm I don't feel that way at all. I prefer the stock part over aftermarket unless the reason to switch is great enough. I don't think turner's plate and logo look better than the stock part with ///M logo. I also wouldn't want to ruin the dead pedal by screwing into it. It was bad enough screwing into the gas pedal. I actually regret even using the throttle plate. I just wanted more traction for the clutch and brake pedals.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
No worries Rich!
May 2019
As I mentioned earlier, I had replaced my failed Koni dampers in the rear with new Bilstein B6. After waiting to see what higher end dampers I could convert into coilovers with my Ground Control hardware, and almost buying a set of Dinan JRZs, I decided to stick with Bilstein B6 and modify them for my use.
Here's the new B6 next to my Koni and then next to stock sachs. Most notably, the B6 doesn't extend down past the hub's clamshell. It also has shorter travel which we already knew about. Because the shaft is actually taller, you'll have sacrificed more travel to achieve same ride height, all else equal. Don't let the big, shiny B6 rod fool you, that's actually the exterior (you'll see the inner rod momentarily). All of it sits inside the yellow outer housing. OE Sachs and Koni are basically identical.
First thing I did was make sure that my Ground Control perch would fit the Bilstein. The outer shell/body, is very very close (ever so slightly smaller) to OE sachs and Koni, so no issue there. In fact, I wrapped a single layer of duct tape around the B6 body at the top so the Grouncontrol perch sits very snuggly. The part that needed modification, was the ID to fit onto the B6's large shaft.
Yes, standard american measurements for my machinist 🙄
There we go
Next, was disassembling the B6 to expose the inner bump stop for trimming. Be very careful if you try this! You'll need to heat up the bottom nut to break the loctite. You also want to make sure you have the correct metric, high quality allen head sockets (5mm iirc). The Bilstein's metal is a bit soft here and it's easy to strip the head. Here, you see the real inner rod, into the silver body which sits in the yellow body/shell.
There are a few posts floating around out there about this bump stop trimming. FCM has a good youtube video on disassembling the unit as well. Iirc, he also touches on the bump stop. it seemed that most people said an inch, but I cut 7/8ths just to error on the side of caution, plus I had another trick up my sleeve to increase travel anyway so this wasn't as crucial. I cut from the "softer" side so as to preserve the stiffer foam for heavy compression situations. The whole bump is about 2.5"
Here's the stock "stack." Takes up about 3 & 3/8" of potential travel.
Here's the TMS street plates that I have. They, alone, reduce that stack height by about 5/8" iirc - going off memory now, sorry no pics
But I also removed the little, concave spacer that they include, to realize another 1/4" in travel. I also don't use the BMW external bump stop plate (pictured), but I did add an, albeit thinner, spacer of my own. Total recapture of travel was basically an inch! For Bilsteins, this is massive as they really don't like being much lower than stock height. Well, most of us run about an inch lower; ~ 13.5" instead of ~ 14.5"
I also took the opportunity to swap springs. I was initially running 6" 440lb Groundcontrol eibachs, but FCM flat ride influence saw me first try 6" 300lb Hypercoils, but they were too short and too soft, so I bought some very nice "high travel" Eibach 7" 325lb springs. The "softer" spring rate (still double that of stock) allows me to get down to 13.375" ride height at lowest setting on perch. I really wanted a taller spring than 6" as I don't want track car rates (like 500lb which would allow for a shorter spring) AND I don't want to "block" the springs at full compression. This 7" spring is literally perfect. The 325lb rate never feels too soft, and with the hotchkis front bar set on medium, there's little body roll (you want some).
Assembled. Plates already on the car. I also had recently replaced the inner bushings in the plates, so they're fresh.
Installed and set for 13.5" ride height
I recaptured so much travel, that I ran out of threads at the top of the shaft to secure it with the M14 nut. I repurposed that TMS spacer, flipped upside down, in order to provide a "stop" for the nut before it ran out of threads.
.Last edited by Tbonem3; 09-23-2020, 04:52 PM.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
These pics are very recent, but I wanted to show where the rear setup is at after finishing the fronts, as depicted above.
Rear setup is Bilstein B6 shocks with GC shortend bumpstops & "tall" RSMs that lift droop by a couple of inches (stops coilover springs from coming unloaded over uneven road conditions.) I also threw in a cheap rear strut bar for more rigidity (you feel it right away) and maybe a little RACP insurance (until further reinforcement)?
Sticking with the 550lb GC eibachs, they're just perfect. If the car were heavier, I'd have kept the 600lbs.
I wanted to go a hair lower, and I thought I could do so while also removing the GC adjusters for less weight and more comfort.
RUCA with GC perch and plate removed.
New, OE BMW lower spring pad (instead of GC adjuster). Normally kits come with 5.5" or 6" springs and you'd be way too low without the perch, but my 550lb eibachs are 6.5".
To keep the ride height from dropping too much, I added 3/16" rubber shim to the GC locating cone for the upper seat. Keep in mind that small changes here at the control arm manifest into larger changes at the wheel due to the angle (roughly 150% greater).
Spring in. While the ID is 2.5", it still can be held in by the spade of the stock pad. Further, once weighted, it's not moving. Further, my tall RSMs prevent them from coming unloaded at droop.
Perfect! 😆 Just j/k. Loaded it up in the driveway.
There we go, on level ground. 12.9" from center cap to arch.
Last edited by Tbonem3; 10-14-2020, 10:11 AM.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Yes! By Eibach.
Thanks!Originally posted by 8000RPM View PostGood looking angle and the gap looks spot on!DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
