Tyler's 04 slicktop 6spd Silvergrey MCS/Brembo/CSL/Karbonius/Nogaros/Supersprint
  • eforty6_m3
    Thanks guys! Still got more content to upload, and a big development coming!
    Anyone else feel like this after this update??
  • Tbonem3
  • EthanolTurbo
    One of the best M3 builds on the planet! Love this thread.
  • liam821
    Thanks. I've really only been able to take my car to the next level due to these 3 things:
    -No longer a daily
    -Fully garaged
    -Covid19 lockdown, work from home
    I'm all those things too, but yeah, I couldn't tell you the last time I wash my car lol
  • Tbonem3
    I don't know how you find the time to keep it that clean.
    -No longer a daily
    -Fully garaged
  • Tbonem3
    July 2020 continued
    I had been running OE grilles with blacked out center slats ala non-m 3 series. It was a sleek look, striking a balance between OE class and aggressive, but I decided to go completely original as far as the exterior goes.
    New OE:
    August 2020
    I was starting to tire of the paint finish (too flat, too bright) of my Sportline wheels. They're such great wheels, I even contemplated having them repainted, but when an almost new set of CSL wheels (which are backordered!) with new PS4S popped up, locally, for sale by member Discowagon, I jumped. These wheels and the CSL boot are just perfection to me, I had to have them!
    Glam shot upon returning home:
    Sportline 18" 275 PSS vs. OE CSL 19" 265 PS4S
    Mounted
    Before mounting, I dressed the wheel liners and cleaned the suspension:
  • liam821
    I've never done so many things! Still got more updates coming too.
  • Tbonem3
    I need those seats!! Looking good my dude.
    Originally posted by KhanArt View Post
    Nice, looks like you have been busy too.
  • KhanArt
    Sent from my SM-G965U1 using Tapatalk
  • liam821
  • Tbonem3
    Thank you. I can only speak about Nogaros on OE manual sliders using BK setup. The passenger side seems to scoot a little farther forward, but both sides are pretty difficult to get behind. And I'm not a big guy, pretty slender. It's not ideal tbh. Perhaps there's a way to mount them differently that would create more space. Oh, and I have them in the more reclined position, so that makes it a hair tighter too (it's not that tilted tho)
  • ///Mad///Man
    Awesome build, if you slide the seats all the way forward can you still access the rear seats and some one could sit back there? Thinking about these seats or the speedsters. Thanks!
  • Tbonem3
    Thank you! I only will swap OE sect 2 for CSL green stamp sect 2 (actually I may try a resonated X pipe just for fun sometime purely for sound reasons)
    April 2020
    Finally got around to installing some software and buying a license from Martyn for the binary tool. My car's already been coded by other people for almost everything I want, but my goal here is to play with the throttle settings and view flash counter (Martyn's most recent tool).
    May 2020
    Originally, I didn't do a great job routing my Turner IAT harness. I finally got around (I should name this thread "I finally... ) to cleaning the area up and I routed the IAT wiring along the same path as the factory wiring in the area for the cleanest look I can do I think:
    June 2020
    Interior work. I guess I should have bought a new set of carpets back at this point in time (hindsight, before they ran out), but I just wanted to refresh the look of the driver side one. I used soap and water to clean it, then I used my old E36 "back to black" trim dye to darken it to look newer.
    Looks ok
    July 2020 more interior work
    Finally decided to just rip out the tint. I've always liked tint, being in Socal, but as I've been making the car more OE/CSL looking, the tint is detracting from the look and just now looks cheap/ghetto to me. At first, I was thinking I'd have to pay someone, but it ended up being very easily actually, just using a heat gun (or hairdrier). Thanks to liam821 for tint removal info. Didn't need steam. I did use windex/water mixture to lube as I went. Almost all of it came out in whole sections, luckily. The tint is 3m, and was applied in 2010, so it's not like it was recent and that's why it came off super easily.
    Used a razor blade to get the corners started (heat first)
    Some little bits might get caught in the window trim. I used a razor to hold the trim off the glass, then pulled/dragged the little bits of film/adhesive with windex soaked Q-tips.
    Clean
    Driver side
    The rear is the hardest. To make it easier (access), and because I've never cleaned/touched this area, I pulled the rear shelf.
    OGs will know about the tennis balls
    The good side effect of having tint for so long, for a car that was not always garaged, is that my interior is in good shape and this rear shelf isn't too faded. I was thinking of dying/spraying it, but....
    After a good wash (water/drop of dish soap), it got a little darker and matches the other interior fabrics perfectly, so I don't want it black black.
    Removed more weight. These are part of the child restraint sys. No car seat in this car lol
    303'd the rear vent/trim
    I had done this years prior, but got a picture of it now. I put some closed cell sound foam under the rear bench to quiet down the diff whine and overall road noise. I've said it before, but my goal for the car is that fine line between hardcore and BMW luxury/class. This doesn't add any weight.
    Along the same lines, I added some sound deadening to the rear panel and the speaker cones.
    Light weight sound blocking foam on top of the BMW foam
    Rear Tint C pillars removed as well
    Center shade cover has been cracked and warped a while, so finally got a new one
    Pretty clean! I don't run rear headrests
    Obligatory Nogaros shot. Tasty
    FISHBOWL:
  • skristedja
    Great progress on my favorite build! And I totally agree on the resonated section 2 comment - stock section 2 for the win.
  • Tbonem3
    Thanks Gary! If someone isn't partial to the exhaust note anyway, then I don't think they'd care, esp those who believe the e46 sound is crap. But I got my car to a point where I loved the note, then it got ruined - imo.
