Tyler's 04 slicktop 6spd Silvergrey MCS/Brembo/CSL/Karbonius/Nogaros/Supersprint
  • heinzboehmer
    Yes please! 😀
    I've been delaying the Slon strut brace just due to competing projects on other cars. Very curious about this. Almost looks factory.
    EDIT: I just went over to your build thread. Holy hell Heinz! That strut tower conversation there is awesome.
    Done!
    TL;DR Everything needed to recreate this project can be found here: https://drive.google.com/drive/folders/1A19wuT_PbK6pI3qUJwib65e2dj8d9FKH?usp=sharing Sharing my design for a street car friendly way to triangulate the front strut towers to the firewall. This is inspired by the stock triangulation present on the E86 and
  • Casa de Mesa
    Tyler - thanks for the detailed steps on the P/S shims.Will likely do this over the winter, doesn't look that bad. Wish I had done that when I had the car disassembled.
    No need to make it a race car! Here's my solution for the triangulation:
    I really need to get to posting all the stuff from this project so others can adopt on their cars...
    Yes please! 😀
  • heinzboehmer
    Yes that'd be awesome. Maybe if/when I convert this thing to a race car!
    Keeps all the street car comforts and the braces come off with four nuts for working on the engine.
  • maupineda
    I forgot I had bought a new gas fill neck-gasket IDK what to call it, but my original was badly cracked. I had assumed it was a hard job, so I put it off until 0-60motorsports did his and said it was easy.
    Really easy actually. I coated the new one in 303 aerospace which both helped it slip on and made it look fresh rather than so ugly with some sort of protective gunk it comes with.
ID:	320807 Click image for larger version
    I also got around to doing the Powersteering pump shim mod... After driving an E9x m3, even with steering servo on low, you get real disappointed when you get back into the ol' E46. The E90's steering is so stiff and heavy, but my favorite part is that it's so linear - it feels stiff from 0 whereas the E46 feels pretty loose at first, then gets a bit better (and I have zhp rack plus wide front wheels/tires!). So I was very interested in something that would reduce boost and get me closer to the E90 feel.
    Got shims from @bigjae. Volke said each is about 12.5% reduction iirc. I settled on 2 shims for 25% - didn't want to get too crazy.
    Work is done from below, but I removed my airbox "trunk" for more light and so I could refill the PS reservoir at the end. Loosen the big nut on the line
    And fluid will drain. Maybe you lose like half a quart? You will definitely need some ATF on hand, not more than a quart/liter imo. Though not a bad time for a complete flush.
    Now, remove the regulator with a big hex like 26mm - I only had standard that big and 1-1/16th was perfect
    This was the hardest part. The little valve is pretty stuck in there (hydraulically I mean, I think) and it took many tries to coax it out. In the end, the only method that worked for me taking 3 skinny cynlindrical magnets, grouping them together, then pushing on the valve, then pull to use both spring force and magnetism to pull this guy out. It barely worked, but enough to grab it and pull it out.
ID:	320814 Click image for larger version
    There's one shim on there by default, now I have 3 total
    Topped off and ready to test!
    Unfortunately, it didn't make things much better. There does seem to be more effort needed, so I guess the 25% claim is pretty spot on, but the initial "play" is still there, and the springy character remains. It also feels like it gets stiffer in a gradual way. Maybe I could add another shim, but I feel like I've scratched this itch and will let sleeping dogs lie. The E90 can reign supreme on this one.
    At least it's an almost free mod!
    I think if you change the steering guibo for a u joint may fix that dead center feel. The Z4M has that design and is uniform from center to lock.
  • Tbonem3
  • heinzboehmer
    Triangulating the strut towers to the firewall will help gain you some of that E90 steering feel you're looking for
  • Tbonem3
  • Tbonem3
    Another round of miscellaneous updates.
    Did an oil change in Nov '24. The garage is still full with remodelling bs, so I'm still working outside
    Still had a half bottle of Castrol to use up, but I'm now buying Motul power ester 5w50 for both this car and my E90
    Then I finally finished my rear shelf setup, or at least so I thought, until I realized I still need the blind plugs for the headrest holes doh! Thanks to Avedis for the trim blanks and idea!
    I've been dedicating all of my free time lately to finally getting comfortable using BMW standard tools (NCS/winkfp/INPA/etc). My E90 needs a lot (TPMS delete, battery coding, DCT tune, engine tune), so I started reading every forum and guide I could find.
    Anyway, my E46 is already pretty set up coding-wise, but there was one thing I did want to do, and now I have the knowledge and tools to do so: Mtrack mode for mk60 dsc (non zcp) retrofit
    Added ZCP $7MA to the VO via NCS Expert, then coded defaults to kombi and DSC. Then, since I have 996 brakes and ZHP steering rack, I decided to keep the ZCP parameters as I think it'll match up best. my 11/2003 doesn't have the cluster for Mtrackmode, so I did have to edit the trc file for the light (so I will see DSC light for MTM and DSC+BRAKE light for DSC-off).
    Pictured above is DSC fully off. My only issue here is that, with the DSC yellow triangle and circle illuminated, I won't have a visual indicator that DSC is intervening (in MTM). Ofc, I should feel the brakes pulsing or fuel being cut, but I did like to see the DSC circle flash when DSC would intervene. I'm not gonna bother with the stalk retrofit.
    I don't drive the car very often, but coincidentally, a local E46 guy, Italo, spotted me on the 101! Always fun to see your car captured by others.
    Last but not least, I made a little video of some recent actividades:
  • 0-60motorsports
    Bi-annual SMOG test
    I posted the same thing, basically, 2 years ago, but I have something new to document this time 'round. Here's everything (hardware-wise) that I swap for the test:
    Not that I drive it much nor are conditions extreme, but the inside of the (karb) box looks brand new still as does the OE filter. TBs still pretty as well and those I cleaned like 8 years ago (20k)
    All set, hardware-wise. Doesn't take long at all. Now to tune.
    I've been tuned for about 8 years and have flashed back and forth probably twice that many times. I was starting to get close to the flash counter and, obviously, didn't want to brick the ECU, so I went ahead and finally purchased MSSflasher so that I could reset the FC, and flash faster than BMWflash (free) can do.
    Smooth sailing
    While flashing my alpha N tune (Evolve-R) back to the car, I wanted to lower the front just a tiny bit. After going down to 343lb rates in the front, I'm still playing with how low I can go without scraping the car in some of my favorite sections of canyons out here. I don't love how the car looks at 13.5" and above, but I know the car needs travel. Luckily I've the hardware and enough spring/light enough car that gives maximum travel, but lower ride height.
    Took the opportunity to check on my new HEL brake lines, looking perfect particularly the rubber grommet that holds the line to the strut. The cheaper lines' grommets just crumble in my experience and don't fit too well anyway. HEL is perfect!
    I was waiting until the next time I had the strut brace off to install my MPOWAAAAA decal to the airbox.
    Light polish and clean
    Look at the weave. Just look at it.
    Measured and marked
    Proper
    Next thing to do will be a decon, perfecting polish, and application of ceramic coating, most likely Gyeon Pure Evo that I still have about 40ml of (used 10 on the E90's E88s), but I'm still building out my garage and suffering through a kitchen remodel, so it may be a little while plus the E90/X7 are getting more focus these days :/
    Coming up on 15 years of ownership later this year. Still gives me big feels
    Great update T
  • Tbonem3
    Bi-annual SMOG test
    Smooth sailing
    Measured and marked
    Proper
  • karter16
    Worry not! It's only being married and having kids (esp the 2nd kid) that has curtailed my hot modding streak. I can do this shit forever. Tho the trick might have to be to keep getting more m3s to work up
    haha too true - 2nd children are something else haha 🤣
  • Tbonem3
  • karter16
    not that there's much left I want to do to the car.
    I live in fear of this. I have this niggling concern that once I get the car "perfect" I'll no longer be interested in it 😋
  • Tbonem3
    Thanks bro! Sadly, no updates for a while, not that there's much left I want to do to the car.
  • gabylonfive
    I've lost count how many time's i've viewed this thread to keep up with your updates - such a clean and meticulous build!
