Originally posted by Tbonem3
View Post
Tyler's '04 Slicktop 6spd Silvergrey @ NA.S54
So true! And it's been stolen...just swapped out this afternoon, as a matter of fact. Cheers man!
2005 BMW M3 (6MT) Instagram
You know, with the prices on some of this trim, I bet a good body shop could do a great job for a fair price! Maybe bmw black sapphire paint? My friend has trim repainted by a shop to match the stock titan, but I actually think it looks better than stock. It was years ago, don't remember price.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
The soft cover ya, but the light fixture requires more technical removalDD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Great idea on the black sapphire, I had a F30 that was black sapphire. The metalic flakes should pop when nicely polished.Originally posted by Tbonem3 View PostYou know, with the prices on some of this trim, I bet a good body shop could do a great job for a fair price! Maybe bmw black sapphire paint? My friend has trim repainted by a shop to match the stock titan, but I actually think it looks better than stock. It was years ago, don't remember price.
July 2018
I was thinking of my brakes, and the little mods to make them better like brass guide pins, euro pads/rotors, etc., but I then started researching 996 Brembo conversions. Turns out, if you DIY it all, it's very affordable. I ordered rotors/pads from FCPeuro for future replacement, brackets and lines from ECS, and a set of used Boxster S calipers from a dismantler.
My father is a machinist, so he took care of the front mounts for me. I DIY'd the paint job and install. I'll post some photos, but real info/details can be found in my DIY thread: https://nam3forum.com/forums/forum/m...bbk-conversion
While installing the fronts, I first took the opportunity to replace the hub (bearings) with OE FAG.
OLD
NEW
Rears
D737 vs. D738
I've learned a lot since then, so what I've posted here has changed. I've refinished my set a few times now, chasing perfection. I also went with Rallyroad brackets for the front to drop weight (half the weight of CM).
Latest version:
My favorite thing about this "BBK" is the weight loss (unsprung weight). The car feels lighter overall, and very tossable and fun. Looks are there too of course, not gonna lie, especially after I worked out how to get my perfect yellow finish. For street use, braking isn't that much of an upgrade, actually. OE brakes are touchier (esp zcp), work better cold and better initial bite IMO. These brakes shine once up to temp and after repeated stops, which is what suits me for my car's use. The pedal feel is insanely firm as well. I'm using OE Porsche comp textar & ate pads. Fluid is ATE Type200 (higher boiling point).Last edited by Tbonem3; 06-09-2020, 10:17 PM.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Thank you Steve!DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
oh_look_a_jimmy
August 2018
I was getting tired of the 4.10s and found a fellow member who wanted to buy it where I could inherit their stock diff. At my mileage, my original diff's LSD was toast, so if i was gonna go back to stock, I wanted a lower mileage diff as I know how important a working LSD is to the dynamics of this car. I also wanted to get more than -1.7 camber in the rear. I had been keeping an eye on adjustable LCAs, mainly aluminum for weight savings, when I got lucky and saw a vendor mis-list some eibach/SPC alloy arms on Amazon for the steel price (half). They quickly re-upped the price after I purchased
Lubed up. Wrote wrench sizes for easy alignment
If your socket wrench isn't slender enough, as you're backing out the rear diff bolts (etorx e12?), an 11mm iirc, offset box end wrench fits perfectly!
Late night swapping by myself
When you've done it before, recently, it's not too bad. This stock diff had 71k which I was happy with. I swapped my diff cover back over since it has the AKG poly bushings. Used a new gasket, a new gasket for the drive shaft end, and then new OE SAF XJ + fm booster fluid.
This is why you must remove or loosen, and lean back the diff to R&R control arms (well, the long bolt). The passenger side has enough room iirc, but the driver side doesn't.
Matched exact length to maintain alignment
Leverage; my old friend, Archimedes.
Shiny
With how few miles the car gets, I'm on annual oil changes now.
Last edited by Tbonem3; 07-03-2020, 11:34 PM.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Thanks. Sounds like you get it 😆. For me, it was scotch brite pads and wd-40. Polishing the pipes on my dirtbikes, as ritual. The e46 m3 is a perfect segue for me and my "tendencies"DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
