MasterC17's HPDE/Time Attack Track Car (Re)Build
  • jhatch
    Hi all,
    Lot of small things to update on, some since the last post and other small things that we never posted.
    I'm MasterC17's younger brother, we have both been building the car together over the last 9 months. I have wanted to rebuild this car for the last 6 years, so exciting to see it nearly finished.
    1. Fire Suppression System
    First big item is the Fire Suppression System from Lifeline. Went With Mechanical 2020 System.
    I've never installed a system like this so I was just doing what seemed best but im sure it could be done better.
    Click image for larger version  Name:	IMG_5714.jpg Views:	0 Size:	107.7 KB ID:	230548
    Click image for larger version  Name:	IMG_5730.jpg Views:	0 Size:	137.3 KB ID:	230549
    Just noticed the line got pushed down in the bottom left of this picture, ill fix that!
    Click image for larger version  Name:	IMG_5676.jpg Views:	0 Size:	120.3 KB ID:	230550
    Click image for larger version  Name:	IMG_5686.jpg Views:	0 Size:	208.8 KB ID:	230551
    The last things I need to do on this is potentially add the aluminum Nozzle mounts to the passenger side engine nozzle, and the interior nozzles. They seem very sturdy as is, not sure how crucial this actually is.
    Then I need to do a final mounting location for the mechanical pulls to activate system. Plan is to build mounts and weld into the cage.
    Overall pretty happy with how it came out considering I didn't really know what I was doing.
    We chose to mount the bottle in the trunk to keep it out of the way and shift a bit of weight to the rear. We plan on adding a passenger seat in the future.
    2. AIM MXG Dash Logger
    The next big change was to upgrade to an AIM MXG. Got a good deal buying almost everything used. This is the Strada , but we bought the logger accessory.
    Along with this we installed a cluster delete panel and light switch delete panel. Came out clean.
    Click image for larger version  Name:	IMG_5705.jpg Views:	0 Size:	98.9 KB ID:	230556
    Click image for larger version  Name:	IMG_5723.jpg Views:	0 Size:	148.6 KB ID:	230552
    Didn't take any great pictures of it, but here it is with the delete panels. Note that I painted the tear in the seat with black paint, a lot less noticeable now. This seat will get replaced at some point, but not a priority right now.
    You can also see the eyelets for the anti sub portion of the 6 point harness. Previously this was wrapped which I wasn't super comfortable with.
    3. Brake Lights and Turn Signals
    The last big change was to wire up the brake lights and turn signals. The reason for turn signals is that we plan to break in the motor on the street..... That may go poorly but im willing to see how it goes lol. Wanted to be as legal as possible even though the car will never be street legal again.
    Click image for larger version  Name:	IMG_5708.jpg Views:	0 Size:	101.6 KB ID:	230554
    No pictures of the front but that's just a ground and power tapping into the same wire as the rears.
    To operate we just have a simple switch that I mounted on the Dash.
    Click image for larger version  Name:	IMG_5706.jpg Views:	0 Size:	153.4 KB ID:	230555
    Here I realized I didn't take the Trim into account which was a bummer lol. Ended up Cutting the trim, removing the bridge between the trim. Not supper happy with it as now the start button portion of the trim is a bit flimsy. Ill figure a better solution out later.
    Along the way there was lots of small things done but I wont bore with every detail. The car is effectively complete until everything breaks and we have to fix it lol.
    I will follow this post up with some semi final pictures of the car. Really happy with the results.
  • MasterC17
    Slow and steady wins the race! We're nearing a trackable car!
  • MasterC17
    A bunch of minor updates.
    Front Windshield Installed
    Rear Lexan Window Installed
    New Alternator & Pullies
    12V Battery Tray Cut (Needs Paint)
    Shortened Fuse Box Cable
    Idled Motor up to Temp
    Drove 10ft
    I think there's light at the end of the tunnel!
ID:	223436 Click image for larger version
ID:	223437 Click image for larger version
ID:	223438 Click image for larger version
ID:	223439 Click image for larger version
  • MasterC17
    Always willing to help an OG and share experiences. I'd probably leave it. If you start getting weird or intermittent readings from the sensor then you know what you have to do. I just used a crimp on ring terminal and put it between the sensor and the fitting. Then used one of the thermostat bolts on top of the lift bracket as a ground.
    Fvcking VAC!!! lol
    I was able to get the pin out and fortunately this one is grounded to the AIM!
  • bigjae46
    Originally posted by MasterC17 View Post
    It is yes! Hmm, I honestly don't know lol! I'll try to check, it's a 4-pin connector but I'm not sure if all four are used.
    Appreciate all your help through this build!
    Fvcking VAC!!! lol
  • MasterC17
    Sensors are configured and working - hooray!
  • MasterC17
    Is that the VAC water pipe? If the sensor is 1 wire you’ll need to ground it or you’ll get an intermittent reading.
  • bigjae46
  • MasterC17
    MAP Sensor Wired
    MSS54HP tuned by HTE
    AIM Oil Pressure Sensor Installed
    AIM Oil Temp Sensor Installed
    AIM Coolant Temp Sensor Installed
    Failed to get the Fuel Level Sensor working.
ID:	222223 Click image for larger version
ID:	222224 Click image for larger version
  • MasterC17
    Nice!
    BTW...your valve cover is dirty! haha
    Are planning to reinstall the dash and/or use the OE instrument cluster?
    Haha yeah I'll have to make it look prettier at some point!
    Dash will be going back in, and just using the AIM MXL Pista for now (old school I know).
  • bigjae46
    Nice!
  • MasterC17
    It runs! Took a bit of an effort, but we were able to start the motor today. Other than one noisy pulley it sounds great!
    Still many details to get sorted out before an event, but massive progress from six months ago.
    Click image for larger version  Name:	PXL_20230611_154206347.jpg Views:	0 Size:	220.7 KB ID:	221396 Click image for larger version  Name:	PXL_20230611_214311340.jpg Views:	0 Size:	276.5 KB ID:	221397
    Obligatory first start video!
    https://youtube.com/shorts/B7nTnksYNIg?feature=share
  • bigjae46
    The solenoid valve on 11617833212? If so, that's very surprising. Wiring diagram shows it going to the DME only.
    There is a lead that goes from the hall effect switch to the DME which I am assuming activates the lead going to the solenoid. Not sure if it makes a difference, I have an LCI with the LED tail lights as well.
    And I had a push button switch in place of the hall effect sensor. I wasn't confident in the reliability of the push button either.
  • MasterC17
    Agreed - I don't remember exactly what I did, to be fair, but I removed the LCM back in 2013 and ran that way for two years without any issues.
  • heinzboehmer
    You really can't delete the LCM unless you find another way to control the solenoid on the brake booster vacuum line....learned that the hard way.
