NorCal M3 - CSL Conversion (Orignial owner car)
  • M3dragon
    CSL Center Console Install
    CSL Front Bumper Install
    SMG Paddle Install
    Replacement Oval Mirror
    VANOS Unit Reinstall
    Buttoning things up
    Car returned home for a short week as it would soon be off to paint and interior. These are the few images I have of the car before she left again for the plastic surgery work.
  • M3dragon
    CSL Cam Install
    CSL Cam Install
    CSL Air Temp Sensor and Air Ducting Install
    Spal Fan Install
  • M3dragon
    2013 The Transformation Begins
    From December 2012 until February 2013, the car was in surgery. The shop I took the car to was kind enough to take images of some of the work as they did it. I need to give a major kudos to the shop for doing the work and doing an AMAZING job.
    IPB-Autosport - Audi, Porsche, BMW, Mini, VW Specialist.
    Address: 1206 C St, Sacramento, CA 95814
    Phone: 916-453-1465
    They made it all come together and highly recommend you spend the money to have them do any CSL work you need. Sorry for the death by images but this is my journal after all.
    Install of the CSL Intake
  • M3dragon
    From what I have found the reason the frames are cracking is fatigue failures. Same issue with aircraft hulls and the pressure changes. The metal eventually begins to fracture with constant pressurization and un-pressurization.
    The fatigue part on an E46 m3 is the loading and unloading going around turns. This constant flexing causes the area to fail. Bad job by BMW not to beef this up as this is a performance car. The stiffer suspension only acerbates the issue faster. As the car has 59000 hard miles on it from back roads driving and being on CA roads I guess I am not surprised to know I would potentially have the issue.
    Last, of the changes at this point in time was the 3.91 gears installed. These were immediate change I could feel when driving the car home after all the work was done. I took an image of the old 3.61 stock gears for history's sake.
    By December 2012, the day has finally come to take the car to the shop and install all the remaining parts. This was a good day as I was getting tired of all the parts taking up space in my office. Before I loaded all the parts into the car, I went through and took images of each item so I had a record of what was being installed.
    As the E46 M3 CSL is such a popular car, most BMW enthusiasts have seen the following parts images. As most of these parts would never been seen individually again I wanted to document them and take images of different angles I had never seen. My hope is by sharing these that fellow enthusiasts see things they have never seen before. An example in my case was the flares on the CSL Center console, which in images I had never noticed, as the angles never caught the subtleness of the flare.
    First group is miscellaneous parts needed for the CSL intake install.
    CSL Splitter and SMG expansion tank
    Hidden air ducting and air filter
    CSL Un-Filtered Housing
    CSL Snorkel Intake
    CSL Center Console
    CSL Cams and Followers
    CSL Main Filtered Housing
    I did want to share one image that proves the fiancée / soon to be wife at this point is allowed to drive the M3. Granted she does not like that much because it has the SMG system. She preferred to drive the 1M as it is a proper manual car. Images was taken and a social event in August at a parking garage in Down town Sacramento.
    December 2012 and I loaded all the parts into the M3 and the fiancé’s Subaru. This is the last image of the car in its current configuration all be as it is transformed into a US Spec CSL car.
  • M3dragon
    The long awaited big items arrived. Thank you to the Evolve guys for a great packing job. A thing to point out is that the bumper comes with the gasket, splitters, and tow hook cover. So I have a spare tow cover, 2 extra splitters, and a spare seal. Kind of nice but at the same time could have saved the funds. The last of the interior parts from BMW were in this order as well. Each delivery is one-step closer to getting the car to the shop for the major overhaul. I hope to be able to pick the seats up next week as they are in.
    The bumper itself comes painted, which is kind of a bummer, as I need to repay it. Does the bumper also seem to be some sort of carbon fiber? First time seeing an OE CSL bumper off a car.
    I have two pairs of splitters. The splitters are super light and seem to be a thin carbon fiber. I will do a write up OE vs VS splitters.
    The final piece of the intake puzzle. Only bummer part with this order is you can only order it with the servo. I am going to see what it might take to get it to work. Nice thing about having a mechanical / electrical engineer as a father =)
    Today’s parts entry was a woohoo and a damit moment. The Recaro Profi XL seats are at the shop along with the installation brackets. We installed the driver side seat and epic fail. The seat with the bracket sits taller than the stock seats so my head was holding the roof up. We are looking into either new brackets or having to make custom ones to drop the seat low enough. So I have seats but not in the car.
    While at the shop I wanted to get a base dyno before all the big moods. Again another damit moment. We were only able to get to 2nd gear for the dyno test. We were able to at least use all the revs so we got a descent set of numbers. Max power was 317 and the consistent number was 312.4. Not too bad for a starting point.
    Finally, after almost a year the replacement cam arrived WOOHOO. Took a long time and I started to think I would never get it but at least it showed up.
    Car hit a milestone in October and reached the 59,000-mile mark. Thought I should take a picture of it for history sake.
    In order to fit the Recaro seats I had custom seat brackets made so the seats sat low enough. The reason I need them low is I am 6’5 but I also have the Recaro sliders to adjust seat position. I installed these so the wife and other could drive the car. The goal of choosing Recaros was to drop weight and sit lower so I could wear a race helmet and not have to bend my neck. Sadly I only gained a little height drop in doing these seats but it is still a tad more than the power seats.
    Over to the fabrication shop to have the rear subframe done as well as have the differential upgraded to 3.91 gears. A note on the Subframe is my car had started to show signs of spider cracks on both sides. The frame had not "completely cracked" but if I had not done the reinforce kit it would have eventually done so.
  • M3dragon
    In July 2012 now fiancé and I came back from a two week vacation in Aruba and Curacao to find that Mr. UPS has left me some new items. These parts were the Evolve R Tuner system, 73MM Wheel stud conversion, and the CSL/Completion steering rack.
    The first of the new upgrades required me to pull the SMG control unit and ship it to ESS for their SMG software. I will have more comments on this later on as I found out some interesting info on this later down the road.
    Big box should up with some of the parts you all have been waiting to see. CSL intake, install hardware, air ducts and less a few parts the supplier missed in the shipping. I contacted the supplier and they are shipping the missing items from this order. So have to wait for the last few parts need to have the complete CSL Intake. Also included in the box where the CSL door handles to make the custom CSL doors.
    Soon after the big box showed up the miscellaneous box of parts showed up. This contained mostly the parts for the center console. Also included was the OE BMW differential parts and the SMG expansion tank. Basically all the nuts and bolts which means all that is left to arrive is the CSL cam, Bumper, snorkel and center console.
    Mid-August 2012 I finally got the SMG controller back from ESS. I was disappointed in how they returned the unit to me. The controller was not in a static-free bag as I sent it to them and it was in a USPS flat rate box with only one pass of bubble wrap. After reinstalling the SMG Controller, I went on a 40 miles of driving and could not tell 100% if there is a change. From what I notice, it seems to change up and downshifts are a smidgen faster in feel. I am taking it on a “spirited” drive on August 30 so we will see how it drives.
    Loaded all the parts up and car is off to the shop to get all the major goodies installed. I will post some more images of the parts later tonight. Never got around to doing detailed images like I wanted to but at least I have images of everything before it goes on the car.
    The drive I did on August 30th was the Livermore Mines run. This time I was able to arrange a photo shoot at an old airbase. This made for some great images, which I need to go back and do once the car is done.
    The Monday after the drive, the Samsco hoses arrived. I hope that these will help keep the car running cool for years to come.
    Saturday 9/1/2012 I was finally was able to install one of the major parts on the M3. My fiancé's father works for a Porsche/Subaru shop so I was able to get access to a lift so I could install the steering rack. I combined it with two oil changes as well. Might as well make the most of having a lift right. My fiancé' drove the 1M to the shop on a nice Saturday AM drive there.
    The following images are of the installation of the steering rack. Sorry for the crappy image quality as all I had was my Iphone. The installation of the steering was pretty straightforward and took about 2 hours to do the install. I also changed the oil as it was due.
    On the drive home after the installation I could tell a noticeable change in the steering. I was concerned as some M3 owners said they did not notice a change when they drove their M3 and an M3 with the competition steering rack. The steering feels sharper and I can notice I do not have to turn the wheel as much when making hard overturns. It is not a major change but it enough that makes the steering feel closer to the 1M which was my goal. I believe that if I did try the ZHP rack of a 330 ZHP it probably would feel as tight as the 1M but I did not want to go that extreme.
    For kick and giggles, I wanted to see what 10 years of ownership looks like in paperwork. It means a whole lot of paperwork in a hanging folder that I will have to split into two eventually.
    The weekend after installing the steering rack, I lead a drive up HWY 1 with some local NorCal gang on a 189 mile loop. (345 miles total for me). For those who say there is not a major change between the CSL/ZCP steering rack and OE need to take it on a super twisty road. Hitting the back roads and taking hairpin turns is where I really felt a change. Bear with me as I try to explain. Before on a tight hairpin I would have fully crossed my arms over and still would need to turn more to make the turn. IE remove hand(s) and turn the wheel more. Now I do not exceed making a parallel X when having to crank the car over. Sorry best way to explain it. The bottom line is I just got my justification the cost was worth it. ESS software seems to make down and up changes in mode 5 a tad faster but I am still not sold at this point.
    If you care to see some more images of the group drive I lead you can see them at www.raddrives.com. Hopefully, I will expand this website to the other states for the routes/photo places if anyone ever sends me routes and photo locations…..
  • M3dragon
    2012 CSL Path Determined
    If you have been reading this, build thread I believe I have brought you up all the way to January 2012. I hope that all the scrolling and reading to this point has been interesting and well worth the sore finger. I have included a summary of the car in its current state as of 2012.
    Engine & Exhaust
    AFE Stage 1 Intake
    AFE Air Scoop
    D/A Race software
    Samco Intake Elbow
    Supersprint V1 Stepped Headers
    Supersprint V1 S Race cats
    Supersprint Center Sections W/Resonator
    Eisenmann Race Exhaust 83mm tips
    Rouge Engineering Under drive Pullies
    Ignition Solution Plasma Coils
    Turner Motorsports Oil Cooler Kit
    Suspension
    TCK E46SD E46 Smart Design DA Coilover 500/600 springs
    TC Kline Camber plates
    OE Strut Tower
    Eibach Sways with polly bushings
    Ground Control Lower rear control arms
    Ground Control hybrid control arm bushings
    Transmission & Drive line
    Ground Control Differential Bushing limiting kit / nylon discs
    Power Flex Tabs
    UUC Tranny mounts hybrid (red)
    Brakes
    STOPTECH Yellow BBK
    StopTech Stainless Steel Brake Lines
    Axxis Ultima Break pads
    Motul RBF600 Gold now / was blue to start
    Exterior
    BMW CSL Carbon Fiber Roof
    BMW CSL Trunk
    BMW CSL Rear Diffuser
    BMW Euro bumper with/custom molded in CSL splitters
    BMW LED Taillight conversion (no led module)
    Interior
    Hardwired Valentine V1
    UUC SMG Peddle set
    Wheels & Tires
    BMW CSL 19 Rims
    Michelin Pilot Super Sport 245/35/19 & 275/30/19 – Filled with nitrogen
    Turner Motorsports 10mm front spacer (needed to clear the calipers)
    BMW CSL 19 rim front spare
    At the start of 2012 I did my second track day at Thunderhill. Like the last track day, I had fun but by the end of the day, I was just not feeling being on the track. Maybe it is because I love my car too much or I want to see a different turn. In either case, I will go back but I am in no hurry to do so.
    In April of 2012 I went to the Sacramento Delta to take photos of both the M3 and the 1M. The wife drove the 1M and helped me take some cool pictures of both cars. I was hoping to get some better pictures but that just means I just have to go back out there and take more, oh darn.
    By May of 2012 I had the light bulb moment that said dam the torpedoes and full speed ahead on the CSL conversion. So I placed my orders in May for a LARGE amount of parts. The following list is what the first round of modification entailed.
    BMW CSL Airbox (kit)
    11617833496 --- AIR COLLECTOR
    11617831740 --- BRACKET
    07119902973 --- HEX BOLT WITH WASHER
    07119900398 --- HEX NUT X2
    11617831745 --- MUFFLER CLAMP X6
    11617833497 --- UNFILTERED AIR HOUSING
    11617833648 --- INTAKE
    07129952137 --- HOSE CLAMP
    11617833646 --- AIR DUCT
    11617833645 --- SUCTION TUBE
    07119905016 --- COUNTERSUNK SCREW X4
    07119901780 --- FILLISTER HEAD WITH WASHER
    16131176747 --- PLASTIC NUT
    07119931115 --- FLAT WASHER X2
    07129952127 --- HOSE CLAMP
    11617833647 --- AIR SHUT OFF CALVE
    11157833649 --- VENT HOSE
    13717896774 --- INTAKE MANIFOLD
    13621739510 --- TEMPERATURE SENSOR AIR
    13727838625 --- BMC AIR PANNEL FILTER
    SMG tank to replace the one on the stock airbox
    21532282549 --- Expansion tank for SMG fluid
    BMW Center console
    51167895578 --- Console-CSL
    51167896362 --- Frame-CSL
    51167896361 --- Frame- CSL
    51167896956 --- Insert-CSL
    51711904843 --- Blind plugD=23MM X2
    34417896360 --- e-brake boot
    51168235570 --- Bracket
    07129901644 --- Body Nut X2
    71111180290 --- Sheet Metal Screw X2
    I am making CSL door panels in alcataera. I got the idea from the interior of my 1M. Also I wanted to be different then everyone.
    51417896919 --- Door handle front left-CSL
    51417896920 --- Door handle front right
    Differential upgrade. This is all the items needed to make a kit.
    Turner Motorsports - 3.91 Ring and Pinion
    33121205138 --- securing plate for pinion
    33121204657 --- crush sleeve
    33107510289 --- output seals X2
    Summit TMK-HM803110 --- bearing race
    Summit TMK-HM803149 --- inner pinion bearing
    BMW CSL Bumper
    51117896820 --- PAINTED FRONT BUMPER TRIMSILBERGRAU
    51117896379 --- Aerodynamic cover, left
    51117896380 --- Aerodynamic cover, right
    51117895883 --- GRILLE,AIR INLET LEFT
    51112695252 --- Flap, towing eye, primedM
    51118191149 --- Gasket 2125 MM
    BMW CSL Engine parts (note I already have the exhaust cam)
    11317835041 --- INLET CAMSHAFT
    11337833259 --- Rocker Arms X24
    Chassie
    Tuner Motorsports Sub frame kit
    Suspension
    BMW ZCP/CSL steering rack
    Software
    Evolve Stage III alpha N software. Need to match the intake, cams, and exhaust all together
    ESS SMG Software
    Engine
    Zionsville Competition radiator/electric fan kit
    - 2 speed controller
    - Shroud
    - 16 spal fan
    Samco radiator hose kit
    Interior
    Recaro SPG-XL seats - I am 6'5 so need the big boy seats
    Ebay black aluminum SMG paddles
    Custom rear seat delete
    Custom CSL / Interior mod
    While I was waiting for parts to arrive, I setup a drive to Santa Cruz. This drive if you know the area has some “hidden” back road sections that most people do not drive on. This allows for some great time just blasting around tight corners or parking in the road to take pictures.
    June 2012 has now rolled around and all the parts I have ordered have slowly started arriving. The first items off the large parts order list where the Turner 3.91 gears and reinforcement kit.
    The cheapest upgrade I bought was a set of EBay black aluminum SMG paddles. While cheap, I loved the look and the paint
    will not start to bubble like the OE BMW ones did.
    After the SMG paddles, I received the CSL Intake cam HOWEVER it was damaged in shipping. I had the Exhaust cam already as it was a wedding gift from the now ex-wife in 2008. At this point in time, I had to return the cam and fight to get a new one.
    Parts continue to slowly arrive every day. The bearing items from Summit Racing showed up so I could do the differential gear upgrade.
    Next item to arrive is the Zionsville Competition Radiator and fan kit. The same day as these parts arrived, I got an Email that the CSL steering rack is on its way and the new Intake cam was shipped from Germany to the US supplier.
  • M3dragon
    2011 Out of the Fog
    After so many years of not doing meets and drives, I finally came back around and started doing them again. Before we get to the drives, here are some of my favorite images of the EuroSunday events of that year.
    In March of 2011 I ordered the Samsco intake elbow and AFE intake scoops. These were the first upgrade to the car in years sadly
    On June 1st 2011 I did my first track day at Thunderhill. It was a fun experience but I realized that the track was not my cup of tea. Yes it is fun but I was getting more bored as the day went on. This could be because I drive the track like back roads and trail break in so I am not fast on the track. Oh well.
    One of the drives I organized in 2011 was a drive to Livermore down mines road. This is one of my favorite drives in Northern CA.
    In October of 2011, the girlfriend and I decided we wanted to say we have driven down ALL of HWY 1 or PCH. We took a week of work and hit the road. We had no plans, no pre-defined stops, just the open road, and a map. All we knew was we wanted to stop at Disney Land and end up in San Diego. Other than that, it was all up in the air. If you have not done the PCH drive from SF to San Diego then you are missing out. Once you get to Monterey heading south you really hit some amazingly beautiful country. It is well worth the time off to take trip. We did the northern section in April of 2012 to complete the northern and southern sections. Below are the Images of the car on that drive.
    The images start at the split of HWY 5 to Monterey where the GF drove to the start of HW1. From there the images are shots going down HW1 all the way ending in San Diego.
    The last image I have for 2011 was a drive I lead up HWY 1 to Biscomb Road. This drive is a full day of driving along the California Coast and some very fun off the beaten path back roads. The images are at a fuel stop and checkpoint for the drive.
  • M3dragon
    2009 Only Events
    2009 was a sad year in regard to my normal routine of things. I was no longer organizing big meet and drives as well as just doing EuroSunday events. The only drive I was doing at this time was the drive after EuroSunday. This was mostly due to the now ex-wife kind of putting a damper on such activities. All the images I have are from EuroSunday events throughout the year.
    I did manage to squeak one upgrade in which was to go to Discovery Automotive Race Software. This was to replace the rich running Powerchips software. The “DA” software seemed to work well and I ran with this software for until 2013.
    2010 Only Events
    This year was the same as 2009 with no major changes and just events. I have picked some of the best images I have from 2010’s events.
  • M3dragon
    2008 Going Through the Motions
    2008 would be a year of meets and drives and nothing in the way of upgrades. Other than the right mounting bracket of the muffler breaking and having to be re-welded, it was just a year of life, not cars.
    The first set of images I have from this year is pictures at the local dealer during the BMW club's annual dinner. These make for some great images when looking back on them now. I need to get back there again for more images.
    One of the best rolling shots I have of my car was taken at a EuroSunday event in the Bay Area. I do not know when the date was but it still is a great shot of the car.
    The next set of images I have are of a photo shoot at the Aerospace Museum of California in October of 2008. This combined the two loves I have of flying and sports cars. A bit of trivia for those out there is the F14 Tomcat in the pictures is one of the F14’s used to film the movie Top Gun.
  • M3dragon
    2007 New Start towards the CSL
    After several months of dealing with the legal issues of the poor roof installation, I finally got a resolution and began the rebuilding process to fix my car. The first Item was to replace the roof with an OE CSL roof. The shop that did the installation of the new roof did a lot of research on how the factory does the installation. Needless to say, they did a great job as they had to fix the 96 spot welds and re-prep the car for the new roof.
    Now that the new roof was installed we could start to remove the other EvoSport installed crap. First Item was to install SuperSprint Stepped Header V1, SuperSprint Stepped Race 100 cell cats.
    At this time I decided that I would upgrade the car's suspension to a coil-over kit. I purchased the TC Kline dual adjustable coil overs, with 500 front and 500 rear springs. I also purchased the TC Kline Camber plates so I could get a better suspension configuration.
    To help improve engine cooling I had the Turner Motorsports Oil Cooler kit. The size comparison between the stock oil cooler and the Turner Oil Cooler is quite a difference. This is a great system for those looking to protect their investment.
    For the transmission, I had UUC red transmission mounts installed to keep everything firm and in place.
    The Last major change at this time was to remove the Vorsteiner bumper and replace it with an OE Euro bumper. I took the CSL splitter off the old bumper and had them custom installed into the Euro bumper so I could get an OE fit and finish but with the Vorsteiner CSL look.
    After all the upgrades and changes had been completed it was around mid-April 2007. The work was completed in time for me to attend Bimmerfest that year and display my car in the shops booth that did the work. It was my first time being a car on display for a company which was pretty cool.
    After getting back from Bimmerfest I attend the monthly EuroSunday event where I got to showcase all my new parts and upgrades. I still was running the Powerchips software at this time and still had issues with the car running way too rich.
    In August of 2007, I did my first indoor photo shoot of the car.
    At the end of the year I did one more photo shoot for a fall calendar. These are some of the best images I have of the car in its older configuration. 2007 Was also one of the last years I would do any modification to the car for quite some time. This had to do mostly with how life throws curve balls at you and not always helping you achieve your goals.
  • M3dragon
    2006 Majors Changes and All Most Lost The Car
    The start of 2006 was the same as the year past. Setting up meet drives and still trying to figure out what I wanted to do with the car. This year was also the year a lot of changes would happen to the car and not all of them were good. But before we get into the good, the bad, and the ugly of the year, let’s start off in January with a nice bath.
    The start of the year of bad and good
    In March of 2006, I decided I wanted to do some major changes. At the time the hot shop for BMW’s was EvoSport down in Long Beach CA. I contacted them to do an install of a Vorsteiner Carbon Fiber roof with a sunroof insert. I made the choice to do this option in order to be different as there were people already with CSL roofs. Below is the start of the CSL Sunroof installation and the start of many other problems.
    Besides the carbon roof, I had some other changes made to the car under the recommendations of EvoSport. This would turn out to be a big mistake and was a life lesson to always, always do your own research. The first of EvoSport recommendations was to install their headers as they were “supposed” to be similar to CSL headers. These were also supposed to provide better low end torque.
    The last power mods I had them install was an AFE stage 2 intake and Powerchips performance software. The AFE was supposed to be superior to the GrouppeM as it allowed more airflow compared to the smaller GrouppeM filter. Supposedly this was also the setup they ran on their race car which at the time was doing very well on the race circuit. The Powerchips software was the race software tune to take advantage of the new intake, headers and exhaust system.
    The last of the work I had done while the car was in Long Beach was to install a set of Ground Control lower control arms and differential shims.
    Before I show the finished install pics, the story associated with this stall was when I drove to LA and started to make the track over the Grape Vine it started to lightly snow over the summit. Now for you folks in snowy areas, you are like ok and this is a special cause? You forget this is California and that white, wet water stuff is a myth unless you live in the Sierras HAHA. And to note it also snowed on me over the summit on the way home as well so I have seen double snow. Images as flows are of the car being picked up at the end of March 2006.
    It is worth to note at the time I thought the parts and work were done correctly. Over the ensuing months, I would find issues with the installs and parts that would eventually end with legal actions being fired at each other. As EvoSport is no longer in business I can now share my stories of the bad work that was performed.
    In April 2006 I ordered the rear CSL diffuser in order to complete the back end CSL look. This is not one of the fanciest mods for a CSL but is a good accent piece.
    When May 2006 rolled around I went down to Long Beach Again to have EvoSport install a Vorsteiner CSL bumper with fog lights. The bumper itself looked good but I could tell the fitment was not that great. I went with the Vorsteiner bumper as I wanted a CSL look but did not want to lose my brake cooling ducts. Sadly I do not have any images of the install images or images from the 2006 Bimmerfest of the bumper. The only Image I have of the new bumper is a photo shoot at Sacramento State in June 2006.
    After May 2006 things went downhill with the car. The first of the downhill things I noticed was the bumper fitment and how it was just not quite right. I know this is minor but it always seems to be the little things that bother you the most. Second was the car felt very sluggish at times with the new headers and intake. Needless to say I was not happy with the “supposed” upgrades and was starting to become very displeased with the work done to my car. The last straw was when I was washing the car and I started to have a leak over the passenger side of the car. That was it and at that point I went to my new local shop and said I want all the EvoSport crap off my car.
    In December 2006 I dropped off the car at my new shop and started the few month legal fight with EvoSport to correct their shoddy installation of the roof. The images below are of the roof prior to the new roof install. Notice the over the drilling of the 96 spot welds and the crapy application of the glue on the areas of the roof.
  • M3dragon
    2005 Same old different year
    The next big purchase I did was to order the SuperSprint Headers, SuperSprint Race Cats, and SuperSprint Center section with resonator in February 2005. This was to replace the RaspX system and start the path down a more performance based setup. There of course is a story behind the installation. I had the local dealer do the installation and they did a piss poor job. So bad in fact they use vice pliers to remove all four 02 sensors that needed to be replaced. Needless to say, I had to work through that issue with them but it all worked out in the end.
    Sadly I did not think about making a build journal about the car till more recently. That means a lot of images I have taken have been lost over the years because I did not think of them as being important. By February 2005 I remember I had Discovery Automotive race software installed to take advantage of the new SuperSprint setup. I also decided to do another Sacramento State photo shoot as I had the trunk installed this time around.
    Throughout the year I was organizing meets and drives for the NorCal BMW gang. By this point in time, I had become a seasoned organizer and was continually looking for new roads to drive on for our regional meets. One of the only images I have of the meets of 2005 is a picture of me driving to either the Bay Area or Napa. Not sure which.
    In June of 2005 I ordered some serious stopping power. I spoke with Will Turner no less and ordered the StopTech 355 mm BBK in Yellow. The kit included stainless steel lines and ATB super blue which made for a nice package. I have had no issues with the StopTech brake kit and could not be happier with the purchase. The only thing I wish I did differently was go with the slotted rotors to get a little more bite and braking surface. Even with the cross drilled the car stops on a dime with change to spare.
    One thing that I had to order in a pinch was a setup 10MM turner front spacers. The reason for this purchase was I needed them to clear the brake calipers.
    The last images I have from 2005 are of a drive I lead up Ice House Road. We call this road the “don’t F-Up Road” as there one section is a 2500 vertical drop off the cliff and did I mention there are no guard rails. The other half of the road is more of the same cliffs and sheer rock walls on the other side. Sadly there is a story about the rock wall later down the timeline. The road after the zero tolerance areas is smooth and a sheer blast to drive.
  • M3dragon
    We are now into the first part of July of 2004 and it is time for Lake Tahoe Drive. This time I lead the entire drive from start to finish. There was a good size group this time and the new performance modifications we definitely help at altitude compared to last year.
    At the end of July, I headed down to the Bay Area again for another one of the Stanford Mall meets. I finally got a rolling shot of me in my car for once.
    In August 2004 I purchased my CSL trunk from Bekkers. This part seemed to start a trend of me having a story around a parts install. When I was driving to the shop to have the trunk installed I was pulled over and got a no front plate ticket. Not how I wanted my day to go to say the least. I get to the shop and they install the trunk but when they were backing the car out they backed my car into a Z06 corvette that the other tech was backing up. The look on my face must have been I am going to kill you because the guy turned pale white. The car was ok other than the paint in the right light showing some spider marks. I have yet to repaint the rear bumper and will need to do it sometime in the near future.
    In Late August I went down to the Bay Area again for another Stanford mall meet. If I remember correctly I believe this is where I took over the meets to include an after drive activity.
    After organizing the meet and drive I was driving back over the Bay Bridge and hit some debris in the road. I just side swiped it enough to cut the tire and take a chunk off the lip of the rim. I was able to limp across the entire Bay Bridge as it happened right as I entered on the San Francisco side heading east. I have no clue how I survived not getting rear-ended.
    At the time I took a chunk out of my rim, I did not know you could fix them so I ordered a new CSL rim. It was not until recently in the last few years I found out you could repair rims. I have had the damaged rim fixed along with another front rim and a rear rim. Joys of driving on crappy California roads. At any rate now I have a “spare” tire in case I need it.
    In November 2004 I organized the NAPA drive again and was now starting to get the hang of organizing meets and drives.
    In December 2004 I organized another Stanford Mall meet and drive. This event was also combined with a toy run for Toys For Tots. I did this so we could give back to those who were less fortunate than us that year. On the way down someone took one of my favorite rolling shots of my car going through the tunnel on Treasure Island. The first image is the Sacramento meet-up point for the drive down.
  • M3dragon
    In April 2004 I decided I wanted to take some pictures of my car. So I pinged the E46 forums and got a few guys together to meet up and take some photos. I only had a point-and-shoot camera so the pictures were not that great but I did get a few that I still love to this day.
    2004 was my first time going to Bimmerfest at the Santa Monica Fair Grounds. I was there with three of my driving buddies at the time to spend a few days in SoCal. Before the day of Bimmerfest I purchased and install a GrouppeM Air Intake system from one of the big vendors at the time. I can’t find the name of the shop now which is kind of a bummer.
    One thing that I was not able to confirm at Bimmerfest 2004 was if I was the only one there with OE CSL rims. I had six people on the spot ask me if I was willing to sell them the rims. Of course, I declined all of the offers.
    After seeing all the sights of Bimmerfest, we took off early and did the planned drive route the rest of the Bimmerfest was going to do later that day. I heard later from others said the drive was a giant cluster and there were some kids causing trouble. Glad we left early when I heard that. The images I have of that trip are of the drive after Bimmerfest, at the hotel, and me using an old video camera to film down Pacific Coast Highway.
    When I got back from Bimmerfest I ordered the H&R Sports Spring Kit with Koni Yellow Adjustable shocks. I went with this kit at the time because one, there was only one coilover kit option at the time, and two I did not want a slammed look which most people were doing with the coilover kit. This kit is still something I remember how well the car drove and would recommend this kit to anyone with an E46 M3.
    In June I went ahead and ordered some more power upgrades for the car. I ordered the Confrti Shark Injector from Turner Motorsports, the Rouge Engineering Power Pullies, and ignition solution plasma coils with Denso Iridium spark plugs.
