heinzboehmer's 2012 Alpine White 128i
  • heinzboehmer
    Realized I never posted up a picture of the car on the snow wheels. There was unfortunately no snow on the ground when I was up in the mountains, but I did snap a picture of the winter machine next to some less practical cars:
    I also bought a set of 215/45 R17 PS4Ss and got them mounted on the summer wheels this weekend. The car feels so much better on those than on the shitty runflats it came with. I'm glad its finally on some proper tires.
  • heinzboehmer
    Getting close to having this thing be fully presentable. Interior refresh was one of the last things on the list.
    All the trim in the center console was messed up. Not sure what happened but that soft touch finish was peeling on a bunch of the pieces. I first tried to get rid of the coating and leave the bare plastic, but that didn't turn out great:
    So I decided to just send the trim out to TexaZ3. The cupholders are plastic riveted to the center console (thanks BMW), but fortunately it wasn't too bad to get them out. Took the center console out and drilled out the formed heads of the rivets:
    Here's how the trim looked after it got refinished:
    Sooo much better, especially compared to how the cupholder part was before sending it out:
    Since I drilled out the plastic rivets holding the cupholder insert in, I had to figure out how to resecure it. I managed to put some screws through half of the rivets and that held it pretty firmly in place. I also added some plastic epoxy to the rest of the rivets just to make sure it didn't go anywhere:
    The screw heads are facing down when installed in the car, so I'm hoping the friction against the plastic keeps them in place. To help them stay in place, I super glued the heads to the plastic. I also painted some (hard to see) lines so that I can know how much of a waste of time the super glue was next time I take the center console out:
    Here's everything back together:
    Looks so much nicer than before. Pretty pleased with how this came out. Now just need to give both the interior and exterior a good clean.
  • heinzboehmer
    Managed to get the TPMS disabled and the FTM enabled today.
    First thing I did was remove the TPMS module. It's underneath the car and very much feels like an afterthought:
    It's also extremely light and hollow feeling. So much so that it makes me think that it's just the antenna, even though TIS says this is all there is. I followed the wires leading to it, but gave up once they got lost in the wheel well. Would be nice to remove everything, but it's the daily and I don't need to be stripping it to make a racecar, so whatever.
    Then came the coding. There's a bunch of different info out there on how to do it, but this is what worked on my car:
    • Removed $2VB from the VA
    • FA_WRITE to CAS and NFRM
    • Default coded DSC, CIC and CAS
    iDrive wasn't super happy after the coding:
    Clicking reset made it change its mind:
    Seemed like everything was working well, but I wanted to make sure it actually did what it was supposed to do. I let out air from the front right tire until it was at 20 psi and drove the car around. Eventually I got this:
    It also showed a warning on the dash that's pretty hard to ignore. Very useful since the iDrive screen is showing carplay/android auto most of the time now:
    I actually struggled a lot to get the system to react to the low tire. Had to air back up and reset multiple times. This system seems a lot less sensitive than the E46 one, but whatever, it seems to work.
    All in all, I'm pretty happy with this. Less complexity, less things to fail and less cost when swapping wheels
  • heinzboehmer
    Recalibrating the steering angle sensor now. Good thought.
    Pressures look good and it did it to me on the Richmond bridge today with a cross wind. It’s probably the steering angle sensor, let’s hope at least.
    edit: scratch that, steering angle sensor was straight already :/
    Hmm, not sure what else could be causing it. Maybe the different sized wheel + tires on the non-M body are throwing the system off? Supposedly the system should learn the diameter of each tire when it's reset, but I'm not sure how it actually works. Very much a black box.
  • Bry5on
  • Slideways
    Didn’t know you could enable TPMS by wheel speed on those cars. Cool.
    My TPMS triggers itself on the same stretch of shitty road on 880 north every. time. on my commute 2x/ week to/from Sunnyvale. My only explanation is that the road quality is SO bad that my rear wheels under torque are spinning more than the front wheels.
    Could it be one of the sensors or the wiring? Maybe that road is transmitting something physically to the sensor/wiring. Other than that, wheels or tires.
  • heinzboehmer
    Yep! Apparently only US cars got the sensor based TPMS system. Other markets stuck with the regular wheel speed sensor one.
    And that's weird. The light in my M3 has only ever come on when a tire was actually low. The system monitors wheel speed differences between the two tires of each axle, so different speeds between front and rear shouldn't make it come on.
    Is your steering angle sensor well calibrated? Only thing I can think of is that the car is turning a bit and the system thinks it's not because the sensor is slightly off.
  • Bry5on
  • heinzboehmer
    Did some small things.
    Windshield was getting a bunch of streaks when using the wipers, so I cleaned it up with some 0000 steel wool and then washed it. Did a quick coat of wax on it too to help the rain glide off.
    Streak:
    Click image for larger version  Name:	20230411_185235.jpg Views:	0 Size:	67.0 KB ID:	213826
    No streak:
    Click image for larger version  Name:	20230411_191425.jpg Views:	0 Size:	73.8 KB ID:	213827
    Headlights were looking pretty tired, so I polished those up quickly:
    Click image for larger version  Name:	20230411_191455.jpg Views:	0 Size:	86.2 KB ID:	213828
    Click image for larger version  Name:	20230411_191504.jpg Views:	0 Size:	100.1 KB ID:	213829
    Click image for larger version  Name:	20230411_194830.jpg Views:	0 Size:	71.4 KB ID:	213830
    Click image for larger version  Name:	20230411_194834.jpg Views:	0 Size:	81.4 KB ID:	213831
    They're not perfect, but this is about as much as I was willing to go. The light output of the halogens is pretty terrible, so I'm considering one of those LED retrofit kits. Still need to look more into it because I'm not fully convinced that the retrofit kit won't blind everyone else on the road. Gonna need to see if I can find one to check out in person.
    Anyway, point is that the headlights might get worked on again, so just did a super quick polish. Also, the car desperately needs a thorough wash. Will get to that after the car has finished its snow duties.
    After that I finished up the dashcam install. Got the PCB soldered up and made it look niceish:
    Click image for larger version  Name:	20230412_113452.jpg Views:	0 Size:	121.7 KB ID:	213832
    Click image for larger version  Name:	20230412_114858.jpg Views:	0 Size:	113.2 KB ID:	213834
    Went into the car without any issues. Since there's no sunroof, there's tons of space up in the headliner, so tucking it out of the way was super easy.
    Click image for larger version  Name:	20230412_195212.jpg Views:	0 Size:	101.6 KB ID:	213833
    I also finished up the aux adapter so that the carplay module cable could be run fully inside the center console:
    Click image for larger version  Name:	20230412_113351.jpg Views:	0 Size:	104.6 KB ID:	213835
    Click image for larger version  Name:	20230412_115042.jpg Views:	0 Size:	99.0 KB ID:	213836
    Click image for larger version  Name:	20230412_200244.jpg Views:	0 Size:	110.6 KB ID:	213837
    No more visible wires . Center console is all taken apart cause the trim was pretty destroyed. More on that later.
    And finally I installed the same VW grocery bag holders that I have on the M3.
    Just like before, I removed the locating dowel things to have them sit flush against the trunk panels:
    Click image for larger version  Name:	20230413_111323.jpg Views:	0 Size:	89.9 KB ID:	213838
    And installed:
    Click image for larger version  Name:	20230413_113026.jpg Views:	0 Size:	91.8 KB ID:	213839
    Click image for larger version  Name:	20230413_114851.jpg Views:	0 Size:	127.4 KB ID:	213840
    Love these things, I use them a ton on the M3. They'll be even more useful on the daily.
    Next up is disabling the US market TPMS system and enabling the MK60 wheel speed based flat tire monitor (just like what's on the E46). I was too cheap to buy TPMS sensors for my snow wheels and the bonging every time I get in the car is driving me crazy.
  • heinzboehmer
    Originally posted by Seano666 View Post
    What did you use for hub clean-up? I got one of those drill brush attachments, it's kind of plastic-y feeling and I don't think it does a fantastic job.
    Nothing fancy. Just a wire wheel on a drill and some brake cleaner. After that I added a thin film of WD-40 just to keep water away. Sprayed it on a rag first, not directly on the hub.
  • Seano666
  • heinzboehmer
    Ooh dashcam PCBs just arrived. Fit is great. Proud of my measurements.
  • heinzboehmer
    Subscribed!!! Can't wait to watch this unfold! Love the Guage cluster update 🤠
    Thanks! The gauge cluster made a huge difference. GF thinks it was stupid, but I hated driving that thing around with 0 temp gauges. Don't get too excited about this car though, probably won't be as interesting as the M3. Any mods to it will be mostly convenience type things. Well until I decide to E9x M3 swap it
    Also, I fixed my transmission yesterday. It was shifting fine, but still making gurgling noises. I went back and read through TIS and realized I made another stupid mistake. I used this thread as a reference for doing the service: https://www.1addicts.com/forums/showthread.php?t=995991 . Just skimmed through it since I thought I mostly knew what I was doing. The one thing I didn't realize is that after filling the transmission back up cold, you're supposed to start the engine, get it up to temp and leave it running when you fill it back up to spec. I was getting it up to temp and then shutting the engine off. The thread doesn't ever say to turn it off, but for some reason I assumed that you needed to. TIS makes it super clear though:
Name:	Screenshot 2023-04-06 at 11.54.25 AM.png
    Honestly feel like an idiot about this, but that's what I get for skimming stuff and being overly confident in my skills as a mechanic (especially when servicing a system that I've never worked on before). Oh well, another lesson learned. Not gonna make that mistake again.
    Transmission took another 1.5 L when filled up correctly (yikes again) and the noises are now gone! Still no glitter, so think I managed to avoid killing it.
    After that, I swapped on snow tires cause this car is going up to the slopes soon. Surprisingly, the hubs were extremely rusty. Car has been in CA all its life, so no idea how they got like this. Even the hubs on the M3 —which was driven through winters a good chunk of its life— looked nothing like these. They cleaned up well though.
    Was dark when I finished, so didn't take any pics of the car on the style 45s, but it looks pretty terrible. I'll grab some pics of it in the snow. Fortunately these wheels will only be getting put on the car when going up to the mountains.
  • Casa de Mesa
  • heinzboehmer
    Also gave this thing a fluid service this weekend. The car came with service records and it had been recently serviced at the dealer, so it wasn't a huge priority, but still wanted to do it to make sure everything was good.
    Did oil, coolant, transmission fluid (+ filter and pan gasket) and RBF600. Didn't do the diff fluid because it was surprisingly expensive and the car is at 76k mi. Plus, I'm kinda okay with the diff failing, since that means I can replace it with an LSD
    Nothing out of the ordinary with any of the fluids, but thought the before and after of the transmission pan cleaning was interesting enough to document:
    I'm very unfamiliar with torque converter autos, but I think that amount of metal is normal/expected?
    I did make a very stupid mistake though. Did the service at a friend's house and used his jack stands. He has a set of those aluminum torin jack stands and at first glance all four look exactly the same. However, it turns out he has two from one batch and two from another. Most of the dimensions are the same, with the exception of the height of the outer red cylinder.
    When jacking up the car, I put the front up first at a height that seemed appropriate and then set the rear stands to have the same number of holes visible above the red part. I didn't realize this at the time, but because the jack stands are different, doing it this way meant that they ended up at different heights. This, in turn, meant the car was higher at the front and led me to underfill the transmission (by a lot).
    I realized something was very wrong quite quickly on the test drive and immediately drove back to put it on the stands again. This is when I realized that I had set them to different heights and had underfilled the thing. Jacked it up correctly and I was able to put 2 more liters in before it started coming out the fill hole (yikes). Unfortunately, I did drive the car around when underfilled, so I circulated a good amount of air through the hydraulic passages. After filling up to the correct level, the car shifts fine, but I can hear some gurgling in first and second gear. I'm assuming that's just air trapped somewhere. Gonna need to mess around with INPA/DIS to bleed this stupid thing and then recheck the level.
    Things would have been totally fine if this was a manual...
    I did also drain a bit of fluid when I realized things were wrong and saw no glitter, so I think the internals are okay. Just gonna have to spend a bunch of time getting the air out because of my stupid mistake. Lesson learned though, not gonna trust my eyes to tell me that a car is level in the future.
