  • karter16
    Pretty sure I've finally found a source for the male MAF sensor connector that allows for MOQ of 1 (and it's cheap to boot).
    This is what I'm talking about:
Name:	Screenshot 2025-06-01 at 8.30.16 AM.png
    I've ordered a couple to check and confirm, but if it is then this is the missing piece for people to be able to build their own harness extensions (and IAT relocation extensions I guess, not that I think they're good idea) without having to pay Turner mark-up. It also means anyone wanting to do what I did (keep the MAF connector and wire up for MAP sensor) doesn't have to buy a Turner extension just to then hack it up to add on the Bosch MAP sensor connector, etc.
    I'll wait til these arrive and I've confirmed and then put up a post with all the various part numbers needed to do this.
  • karter16
    Now I'm curious to try this! Good thinking.
    Very keen to hear how you get on if you do this!
  • Bry5on
    Whole family (including myself) are sick this weekend so took the opportunity to try out doing a VE table tuning run with the MAP sensor turned off. I've been wanting to do this for a while as theoretically it's another variable that can be removed from the process. With the MAP sensor taken out of the RF calculation path the car is essentially running in "Alpha-N Mode". My theory behind this is that depending on point in time conditions the MAP sensor is adjusting the final RF either up or down from what's calculated from the VE table. While this is desirable in day to day use, for the VE tuning process it's an unwelcome additional variable.
    Unfortunately I can't really think of an objective way to measure the impact of it to the VE tuning process, so it's really just a subjective assessment I guess.
    The difference with the MAP sensor disabled is immediately noticeable in the part-throttle conditions the MAP sensor targets. The car is less responsive and throttle input is jerkier and less consistent. I found a couple of RO/RPM conditions which I hadn't previously been able to flush out.
    I intend to do another tuning run tomorrow or Monday on a day when I can get further out and up the RPM range more to get a more complete test.
    It would need more people to try this out and get their subjective feedback as well as to whether disabling the MAP sensor positively influences the VE tuning process (I think it will mostly be about the speed at which one arrives at the end result), but I am pleased to have finally proven out that changing the configuration byte from 0x12 to 0x02 does behave as expected.
    Oh and also gave the nylon MAP sensor adapter a couple of good heat cycles and then took it off and inspected it - appears to be unaffected by the heat so far, so off to a good start.
  • karter16
  • ugaexploder
    that would be awesome, sign me up as well
  • bmwfnatic
    The MAP sensor adapter printed in CF-reinforced Nylon arrived today. Minimum order value applied so I'm now the proud owner of 12 of these.
    I'll try to install in the next couple of days. HDT is significantly higher than the CF-PETG I used previously.
    Click image for larger version Name:	IMG_2274.jpg Views:	0 Size:	187.7 KB ID:	306677
    Yeah send me one as well since you said not to use the previous one 😂
  • 0-60motorsports
    I can always take one off of your hands. Let me know brother.
  • karter16
  • karter16
    Well yesterday and today I tackled a job I've long been putting off.
    Yesterday I took the headlining out of the car, and dropped it (along with the sunroof cover, etc) plus the BM-134 fabric off to a professional headliner upholsterer. The dude was a legend and had it ready for me to pick up this morning (think he was grateful that I'd done the hard work of taking it out of the car!). He was very complementary of the BM-134 fabric - he said it's a quality fabric with quality foam and was lovely to work with.
    I'll tackle pretty much any job on the car, but this is one of those few things I'm very happy to leave to a professional - the work is flawless and it looks incredible.
    For those wondering about the fabric match - I took some photos of the re-wrapped headliner against one of the interior trim pieces which has the original BMW fabric on it (non-foam-backed):
    It's a very close match and certainly once it's in the car you can't tell at all - the slight difference really only shows up in photos.
    Likewise it matches well against the new A/B/C pillar trim I bought (which fortunately all match each other as well - as that was a problem for a while):
    While the headliner was out I took the opportunity to pull out the wiring a PO had put in for a radar scanner - I removed the T-Tap connectors, insulated the wires and wrapped in Tessa tape:
    In order to remove the sunroof cover to retrim it I also had to remove the sunroof glass - I took the opportunity while it was out to give the frame a good clean and re-lubricate with graphite lubricant:
    I reinstalled the headliner and then got on to installing the new pillar trim - shiny new B-pillar covers:
    Then the C-pillars, along with the foam insulated clips:
    And lastly the A-pillar trims and inserts with the airbag logo on them. Notably the A pillar inserts are a significantly different shade to everything else. (which is hilarious given this is all new OE parts). If it annoys me too much I might order replacements and hope for a better match.
    I'm very happy to have this done - it's not a particularly fun job but very satisfying to have everything refreshed and like new.
    You can see the huge difference in shade between the new a-pillar and the insert 🙄.
  • karter16
    Manufacturing for my design is close to being done! Should be in my hands in a couple weeks. Once finalized, installed and validated, I'll make it available for all.
    Not sure what your plans are for the front end, but I guess I'm just excited to get my braces installed
    Very much looking forward to seeing it installed!
  • heinzboehmer
    It's a very significant improvement and I'm getting itchy to give the front of the car similar treatment
  • karter16
    Well 2 days of driving an excavator, 4 months of weekends, 300m of rebar, 14 tonnes of concrete, 232 CMU blocks, and a lot of manual labour my retaining wall is complete - finished backfilling it today. Starting to get a bit wet here for the winter so great timing.
    Bit of a general update on the car.
    • The latest version of the SMG reservoir bracket is in use, I've got some more tweaks to make to it so will do that and print the latest iteration.
    • The MAP sensor adapter in CF-PETG shows some evidence of softening. It seems, under the clamping force of the bolts, it's not quite up to the ~100 degree C temperature that the rail hits. Plan is to get this printed in GF-Nylon which should be able to handle beyond 150 degree C temps.
    • I'm doing some preliminary work on the reinstallation of the trunk interior with the RACP brace in place. Working through a few things to get to a lightweight, high-quality solution that meets my need to make it look as OE as possible.
    • The version of the CSL tune I've been running the last while seems super stable. Even as it's got colder here it's remained super smooth. Seems I've got the warm-up maps pretty much spot on. I still want to do some more fine-tuning, and in particular am keen to try out running the fuel tuning process with the MAP sensor integrator turned off, but it's not top of the priority list given what I'm currently running is so good.
    • Planning to get the headliner out and off to the pros to redo with the BM-134 fabric that I have stashed. I've also got brand new A/B/C pillars to go in once it's reinstalled.
    • Intend to make more progress with the 0401 disassembly as well - especially as the days get shorter and the weather gets worse.
    Lots of little bits and pieces on the go.
    I've also been enjoying driving the car. The refreshed diff bushes have eliminated any remaining clunk in the drivetrain. Combined with the smoothness of the CSL tune it makes for lots of enjoyable downshifts with no need for the manual throttle modulating that I'd previously gotten used to to minimize the thunk. Secondly the RACP brace has, in addition to providing top-side support to the RACP, made an enormous difference to the torsional rigidity of the rear of the car. It's a very significant improvement and I'm getting itchy to give the front of the car similar treatment
  • karter16
    Great updates as usual. Do you have a link to that screen protector?
    Yeah sure - the one I got is a local brand - but should give you an idea of the sort of thing I used: https://screenshield.com.au/products...LSXH4mF.WHCYV2
  • 0-60motorsports
  • karter16
    Today I also finished up the repainting of the v brace and rear sway bar brackets project. I top coated them a week and a half ago and they've been resting while the enamel fully cured. Today I reinstalled them along with new hardware to match.
