EPIC Journal !!!
Thank you for the write up. I have to be honest, I am feeling pretty inadequate right now 😦
My journal is the equivalent of a few average detailing sessions 😿
And that under carriage care, I love that. I have a total fetish and watch all the reddish motor sports under carriage rehabs . . .. https://www.youtube.com/watch?v=yAzyc8S6boE
Totally following!
Slavik's 2002 Carbon Schwarz M3 6 Speed Build
Lots of nice work going on and very satisfying to see a clean and rust free underside!
Started to tinker with the wiring today...
I will be de-pining all of the options that I do not want on my car. The first to go was the speaker wiring and side air bags on the doors.
I plan on removing the following options from the 06 M3 SMG wiring:
-SMG wires
-SMG hood lock wires
-Sunroof wires
-Secondary air injection wires
-PDC wires
-Door air bag wires
-Heated and power seats wires
-Any audio wiring that is left on the main harness
All of the wires will be weighed at the end to see how much weight was saved.
Did some dirty work over the weekend...
Got out the P21s, a brush and the pressure washer to clean out the underside and engine bay of the chassis before I start running the wiring and subframe reinforcement.
Engine Bay Before/After:
Front Left Wheel Arch Before/After:
Front Right Wheel Arch Before/After:
Rear Left Wheel Arch Before/After:
Rear Right Wheel Arch Before/After:
Fuel Tank Housing Area Before/After:
- Likes 5
The FM LSD thing is about finding the sweet spot for your car where there's enough FM in the lube to keep it quiet and not be so touchy, but not so much that it allows the clutch to just slip too easily. It's not about the brand or even which chemicals that brand uses. It's just about the quantity you need to reach that point.
It's hard to know if the OE fluid, with the FM booster, is the correct amount. It does seem to quiet everyone's down, but how do we know if it's allowing for slipping? I used the OE fluid (sans FM booster), much cheaper, then added in "Lubegard" LSD FM (great brand). I actually stopped at the point where I could still just barely hear some groaning on a tight turn. Just so I knew it was still grabbing hard.
Since I couldn't get on top of my overheating issues, I decided to park the car for the winter. Big plans for the winter. First and foremost, I ordered myself a weld in stealth VinceBar due to the fact that my reinforced RACP started to split. Next on the list was a project that I am really looking forward to. Picked up a complete wiring harness from a 2006 M3. The purpose of this is to do a Mk60 conversion. All parts came out of a low mileage SMG M3. In my pursuit of lightweight, I will be pulling out all of the unnecessary plugs and just leaving in what I need. To finish everything off, I will be fitting a set of Porsche brakes with PFC V3 rotors.
The progress so far...
Waiting for the weekend to swap out the harness and remove some other parts. A full under body wash is in order prior to assembly.
I'm partial to only OE fluids in this car. I haven't heard of the clutches not grabbing as well with Redline in the diff but the M Variable unit struggles with OE fluid too. Luckily there are many companies that make "plug and play" clutch packs with more aggressiveness to them for you.Originally posted by slavik1988 View Post
Thanks for the input. I also read that adding some Redline friction modifier may quite things down but the draw back is that it clutches don't grab as well? Any thoughts.
I did have a set but I got rid of them for emission reasons. The ones I had were catless. This time ECS had a good deal on cats and headers.
Very cool to see! Since the wall is thinner, if the csl one has at least the same OD, than the ID would be slightly bigger. Not much, but maybe a couple of ponies :P
Nope, weight is the only difference between the two.Originally posted by Nick_P View PostAre there any differences between a stock OE section 2 and the CSL section 2, aside from weight savings?
Packed up some necessities and went for a camp/drive to Virgina/Tennesse:
Originally, planned as a three day drive (Friday to Sunday), but ended up as a two day because my brother ran out of front tires. All in all it was an awesome trip. We put in 535 miles round trip with both cars not skipping a beat. I couldn't ask for a better weekend with temperatures being upper 70's/lower 80's and no humidity.
Thanks for the input. I also read that adding some Redline friction modifier may quite things down but the draw back is that it clutches don't grab as well? Any thoughts.Originally posted by Sharocks View PostREM polishing the diff won't do anything. My Dinan diff is REM polished and it whines like crazy on accel and decel. I have different clutch packs tho.
Thought you already had SSV1s installed tho?
