Obioban's 2005 IR/IR Coupe
  • Obioban
    I thought I saw you selling the E60, did you decide to keep it?
    Nah, just waiting for spring. Winter didn't seem like the time to get the best value :P
  • George Hill
    All my recent car projects have been e60 and e82. The e46 is so nice and easy in comparison. Really missed it.
  • Obioban
    Doing a little spring project on the M3, which is fun-- with building the house, the e60 M5, etc, haven't really had time to do anything with it for a while. Changes:
    1) new/updated/lighter/not crumbled under back seat sound deadening pad
    2) Bry5on's additional exhaust mount point
    3) Higher flow injectors (Bosch 0280156063), with new OE BMW injector o-rings and vacuum rail o-rings.
    4) one step colder plugs (Denso ixu27)
    5) creating a little spacer to allow my OEM (Die Wethje​) CSL airbox from before CSL's existed to use the factory CSL air filter (my filter is slightly larger in one corner, so it doesn't get a good seal as is with a factory filter)
    6) replacing two of the power steering lines that are slightly weeping
    7) installing a wideband so I can use the forum partial throttle auto tuner
    8) moving to an HTE tune, to update for my new injectors and colder plugs, as well as tuning the WOT with the wideband/data logger.
  • Obioban
    Originally posted by gnoy26 View Post
    hey man! glad to have found you, good that youre still active.
    need some advice, what bump stops should i use for eibach and sachs?
    Don't really know, never looked at it. Stock is probably fine-- the eibachs are a pretty reasonable drop.
  • gnoy26
  • 1bluemcm
    I'm discovering that the list of NLA parts for M coupe/roadster seems to get bigger and quickly. Problems with low production numbers. I also try to pick up extras of things that seem to be getting harder and harder to find.
  • Obioban
    Kind of a boring update, but the old driver door arm rest cracked, so I bought a new one. Feels like the kind of part that will soon be NLA.
  • Obioban
    Originally posted by 5676879 View Post
    Any update? Can't have the mythical obioban m3 off the road!
    Ha, I’ve been driving it.
    Pressure tested it and it held pressure. No further coolant has disappeared.
    Hopefully it just burped over winter 😜
  • 5676879
    I hope not.
    Zero coolant smell in the cabin.
    Going to pressure test the system.
  • Obioban
    I hope not.
  • heinzboehmer
    Heater core leaking?
    I want to drain my entire cooling system. How can I drain my heater core without having to disconnect the heater core hoses? Can I have the motor not running but the ignition turned on and the heater turned on? Will that open the heater core valve that will allow the heater core to drain along with the rest of the cooling
  • Obioban
    Hmm. Just pulled the M3 out of winter storage and the coolant was low.
    No sign in the oil.
    No puddle or residue under the car.
    Where did it go?
  • Projecte46m3
    Waiting to see how this CF driveshaft goes...
  • 0-60motorsports
    Just bought a used F8X driveshaft. Going to follow Altaran's lead and put e46 M flanges on it, for a hopefully OE qualify CF driveshaft on the cheap.
    Click image for larger version  Name:	s-l1600.png Views:	0 Size:	1,022.9 KB ID:	248784
    Click image for larger version  Name:	s-l16002.jpg Views:	0 Size:	67.2 KB ID:	248785
    Click image for larger version  Name:	s-l16001.jpg Views:	0 Size:	68.2 KB ID:	248783
    Yes! Looking forward to your feedback.
  • Obioban
    When I saw what Altaran did I actually thought of you as I figured six seconds would elapse between you seeing it and you buying one. lol
    I don't know how to feel about being so predicable.
