structure3230's Build Thread
    Current Status:
    Ohlins coilover suspension
    Rear subframe reinforcement by TC Designs
    Bayside Fabrication roll bar
    Cobra Kevlar Seats
    Schroth 6 point harnesses
    Ground Control camber plates
    Eisenmann sport exhaust
    Rogue Engineering / CSF high performance radiator
    Rogue Engineering / CSF high performance oil cooler
    Rogue Engineering FCAB bushings
    Rogue Engineering RTAB bushings
    Rogue Engineering rear spring perch reinforcement
    Rogue Engineering rear shock mount reinforcement
    Rogue Engineering strut brace
    Rogue Engineering differential bushings
    Rogue Engineering high pressure coolant line
    Rogue Engineering transmission mounts
    Rogue Engineering front sway bar end links
    Bimmerworld engine mounts
    Bimmerworld front brake caliper brass bushing kit
    PFC Direct Drive Rotors
    PFC front & rear 01 brake pads
    Bimmerworld rear brake caliper brass bushing kit
    Brake fluid flush with Castrol React SRF
    Stoptech SS brake lines
    Turner Motorsports shifter rebuild kit
    CARB legal K&N intake
    Front & rear Hotchkis sway bar kit
    BMW original parts complete water system refresh
    BMW original parts complete clutch kit
    BMW original parts oil filter housing
    BMW original parts steering lines
    BMW original parts guibo
    BMW original parts transmission fluid
    BMW original parts differential fluid
    BMW original parts front wiper cowl
    BMW original parts F10 M5 lighted shifter with merino leather
    BMW original parts steering wheel reupholstered in alcantara and merino leather
    BMW original IHKA relocation for Android navigation system
    Upgraded sound system with focal speakers/crossovers, PPI amp, and Kicker 6X9 subwoofer in factory locations
    BMW original subframe foam reinforcement performed at BMW of North America’s National Workshop
    BMW original VANOS bolts preventive maintenance performed at BMW of North America’s National Workshop
