Apparently im wrong on the SAC. Another thread in E46 section the guys are saying its not necessary, so disregard..
no advice to give on clutch… mine was good but failed on about the 4 th track day after the rebuild. Had 150k miles on it, so consider a replacement while youre in there or risk another big repair. I replaced w the tilton twin disc and ltw flywheel combo and have been happy. New stock is fine too if you are wanting to avoid another big job. I mention in the build all the transmission “while youre in there” items. I believe i have a trans seal leak now coming from the belhousing. I dont think its the rms. I replaced the shift shaft seal but not the trans input shaft seal so i think its that one.
Definitely get the sized ring compressor 87.25. I think theyre like 10$ more and the universal one is a pia. The rings slip out at the last second and u have to start over.
if youre on a budget with this(and no matter how u do it its very expensive) just get the stage one rebuild from lang, just so thats done and its a fresh start. The upgraded parts etc youll want the head perfectly flat and as well have the block decked so you have two perfectly flat surfaces.
those rods and pistons look like what i got on first glance. Obv the pistons need to be 87.25. They are very nice and again the main reason i went with those is the significant rotating mass weight savings. You can get a rod bolt stretch guage tool from carillo that is way cheaper than the arp. Also Lang was very helpful in picking out parts so drop him an email about your plans and he may be responsive as he was with me.
good luck! Take your time and have fun!!
