The Red Drift ///Machine - 2026 NASA TT4 adventures
  • bigjae46
    Brake fluid was nasty...
    Changed all of the fluids, FCABs and RTABs. Installed the TCKs, Vorshlag camber plates and Turner rear control arms from my 330ci. Ordered a new Stoptech BBK, UUC SSK Only issues I found at this time was a seized rear outer control arm ball joint and a leak from the diff pinion seal. I sent an oil sample off to Blackstone.
    So you read that correctly, I used non-M camber plates on my M3. I called TC Kline because Vorshlag did not have the M3 plates in stock. TC Kline said I could use the non-M plates if its a track car. I'll just gain negative camber and lose some caster. So I set the Vorshlag plates to max caster (they come set in the middle setting). The camber range is -2.5 degrees for -4.5 degrees. This is GREAT because I have a much more usable range of camber for track use.
    I had NTB align the car. The front camber was at -4.0 degres and the rear was stuck at -1.8 degrees. All in all, NTB did a good job but it was too much of a camber imbalance front to rear. Totally on me. So off to the track...
    As you can see, the rear end was pretty squirrely. Then bad news. I spun bearing #3 at its first track event. I shut it down before anything else got chewed up. I get home and that Monday my Blackstone report arrives.
  • bigjae46
    It started in Nov 2012. I had a supercharged 330Ci (LOVED IT!!!) which lost, yet, another oil pump sprocket nut. Third time. So it was time to move on.
    Here is the last ride...
    That car was fast! 1:57 at Texas World Speedway on street tires at 3300lbs. I needed something more reliable and less susceptible to heat soak.
    I bought this red on red 2004 M3 for $10,500. It was an auction car so that is part of the low price. Since it was going to be a track car, didn't really care since I was going to gut it and replace everything consumable.
    98,000 miles
    Imola red on Imola Red
    6 speed
    Moonroof
    19" wheels
    So you've seen endless pics of stripping the interior...mine looks no different. I installed this VAC floor panel. Lesson learned, make it easily removable. Funny story. I was driving home from Ice Hockey at 10pm. I totally forgot that I was low on fuel. I pulled off on the next exit and then the car died. I was going to call my wife. I dropped my phone and it fell under the floor plate. So I had to walk 1 mile in a bad neighborhood and carry fuel back in 2 Gatorade bottles.
  • The Red Drift ///Machine - 2026 NASA TT4 adventures
    Here's the story of the Red Drift Machine. Started out as a track car but has been slowly evolving into a car geared towards competition. Not sure what yet. I hope to start in TT in 2021. Unfortunately scheduling...can't make any 2020 events in addition to the whole COVID thing.
