Saved a good amount of weight from removing the AC lines, AC pump, and probably reclaimed 2 HP from the drive belt being removed. Every little bit helps. Hopefully I don't burn up in the pits during the summer trackday events. It's a chance I'm willing to take haha.
Cooling system revamp which including:
OEM Water pump w/Gasket
OEM Thermostat w/ Gasket (stock)
OEM Radiator
Continental Water pump belt (Performed 50 miles ago at Lang Racing)
OEM Aux Fan Switch
OEM Expansion Tank
OEM Expansion Tank Line
OEM O-Rings
I didn't go with an aftermarket radiator because I've been good with the stock OEM radiator and water wetter with my previous builds.
Mechanical Fan Swap:
Removed the stock clutch fan and shroud. Installed the Mishimoto mechanical puller fan.
Getting the front bumper off was a real pain in the ass. Could not get the bumper to budge after removing inner fender screws and the underbody screws! After about 20 minutes of pulling from various angles, I decided to start pulling off headlights, turn signals, etc. Finally found the problem. The dealership added some screws below the turn signals which affixed the front bumper to the fenders. A heads up would have been nice.
Other than that, the cooling system overhaul was a pretty straightforward endeavor. I'm certain this preventative maintenance saved me from having a 3 hour tow truck drive home from the track.
Tires and wheels update:
Went with Apex ARC-8R 18x9.5 35ET wrapped in Bridgestone RE 71 R rubber. This combo has served me well in the past, so why change a good thing? I'll probably graduate to pull off slicks sometime next year, but the current setup will keep me glued to the track for my first couple of trackdays in the second half of this year. Shout out to Big O Tires for not scratching my rims!
Cage Update:
I have my cage build slot reserved for early April. Ordering the carbon roof today, as the cage installer will glue it on. I'll need to deliver the vehicle stripped, and without glass and a roof (trying to keep costs down). Will replace the stock windshield but will go with a polycarbonate rear window.
Rough plans for cage include shock tower tie in, full cage, x bars at doors, foot/ankle protection, subframe tie in, harness eyelets, cabin bar (removing hvac), & a few other goodies.
Harness Update:
Going with 6pt Sparco Aluminum Hans compatible 3/2 (black) Will order them next week so I can have the gage builder install them with the cage.
