2002 Steel Grey 6spd coupe Daily/Restoration project
  • Casa de Mesa
    You should be proud of the work done to bring this car to the state it is now. Looks fantastic, Tbone. Exceptional work.
  • Tbonem3
    Figure now's a fine time to share some recent pics. I didn't feel the car was quite there yet until recently. It's still just a stock looking car with rashed 18s.
ID:	144890 Click image for larger version
ID:	144887 Click image for larger version
ID:	144891 Click image for larger version
  • Tbonem3
    Ok, last bit of wet sanding, I promise...
    All that remained was the very top pillar "rail" of the passenger QP (respray)
    Not the worst finish, but pretty rough where it meets the trim, as I assume the shop did not remove trim for the paint job. Example:
    Click image for larger version  Name:	Pillar (0).JPG Views:	0 Size:	75.4 KB ID:	144831
    I took it pretty easy, just using 2500 grit, putting some more pressure where the trim is as that did need the most flattening.
    Click image for larger version  Name:	Pillar (2).JPG Views:	0 Size:	79.7 KB ID:	144830
    Click image for larger version  Name:	Pillar (1).JPG Views:	0 Size:	63.8 KB ID:	144829 Click image for larger version  Name:	Pillar (4).JPG Views:	0 Size:	87.1 KB ID:	144828
    Alright, all done sanding. I took it easy on the edge near glass as it's a sharp angle. I really wasn't looking to take the OP down too much here, just trying to match it to factory as much as possible since this is the last of the respray.
    Click image for larger version  Name:	Pillar (5).JPG Views:	0 Size:	64.3 KB ID:	144832
    Time to buff
    Click image for larger version  Name:	Pillar (7).JPG Views:	0 Size:	94.4 KB ID:	144834
    Had to do some by hand, right where the trim is
    Click image for larger version  Name:	Pillar (8).JPG Views:	0 Size:	95.9 KB ID:	144833
    Click image for larger version  Name:	Pillar (10).JPG Views:	0 Size:	104.8 KB ID:	144837
    All done!
    Click image for larger version  Name:	Pillar (12).JPG Views:	0 Size:	58.6 KB ID:	144835
    Click image for larger version  Name:	Pillar (14).JPG Views:	0 Size:	57.7 KB ID:	144836
    Still a little sloppy closer to the trim, but I didn't want to burn through the clear, so this is the best I could do.
    Almost exact orange peel as factory, comparing to other panels:
    Click image for larger version  Name:	Pillar (16).JPG Views:	0 Size:	82.2 KB ID:	144840
    This area was pretty rough, but now basically factory looking
    Click image for larger version  Name:	Pillar (17).JPG Views:	0 Size:	41.1 KB ID:	144838
    Happy to be done, though it is kind of fun
    Click image for larger version  Name:	Pillar (19).JPG Views:	0 Size:	57.0 KB ID:	144839
    Very proud of the restoration I've done to the exterior of this car. Pictured below is a recent pic, so no more body work. Hard, almost impossible, to tell it's not original (only hood/fender are factory):
    Click image for larger version  Name:	lunchshot204.JPG Views:	0 Size:	175.8 KB ID:	144843
  • Tbonem3
    Some more maintenance. I think I mentioned it earlier, but while doing headers/CPV, I notice the Exhaust cam sensor was leaking. I decided to just replace both sensors (intake/exh).
    Here's the leak (only exh side)
    New OES(upplier) part from FCPeuro. Newer one is now gray and larger. Make sure to buy the o-ring! The intake comes with new o-ring, but not exh!
    You can see the BMW logo ground off, it's a genuine part for half cost. Another pic of new sensors:
    Exhaust is easy to change, just need a 5mm hex bit/key. Intake, however, is a PITA. Not only do you have to remove the manifold, but technically, you're supposed to remove the air and even fuel rail as the plug and wire for the sensor is hiding behind. I took a short cut that I'll explain.
    There's a little plastic "cage" that you have to get out of the way
    Now, you can get your 5mm hex bit back there, a wobble helps.
    Since it's easy to do (2 x 10mm bolts), I removed the air rail for more access
    Here, you can see the sensor's harness snug as a bug behind the fuel rail. So instead of removing the fuel rail and dealing with all those bitch clips, I just cut the harness so I could pull it out. Then, after installing new intake sensor, I plugged the harness in, and just stuffed the extra wire behind the fuel rail.
    Also, even though I did a quick cleanout of the ICV, since the airbox was off, I wanted to do a better job. I got some new hose clamps as the oetikers are one-time-use, and I pulled the hoses of and cleaned everything thoroughly.
  • MTiz
    Repainted Roof Rails
    Luckily, none of the original paint on the body panels has any clear coat failure, but the roof rails certainly do, and not so little that I could just polish it finely to make it passable. At least they can be removed easily and repainted without much fuss.
    Hey, thanks for this quick DIY. My roof rails are the only thing on my car with clear coat peeling and I was wondering if I could just repaint them. Definitely filing this away for the future.
  • lastMleft
    Nice work Tbone!! You are indeed an E46 M3 fanatic keep up the great work!
  • Tbonem3
    Thank you Alex!
    Still have some more updates to post before catching up to present day. Finally fixed the rear bumper and put on the scorza muffler recently.
  • alexM3Chicago
    Dude, you are on a completely different level in terms of restore. Quality work, steel grey is one of my favorite colors. Love this thread!
  • Tbonem3
    Thank you! Glad to hear
  • Rudbari
    Amazing build mate
    enjoyed your journey
  • Tbonem3
    I had flushed the tranny with some Liqui-Moly conventional 75w gl4 to clean it out. As I documented, there was a lot of synchros (brass) dust in the, I'm sure, original factory fill. So now I wanted to flush that and put in the "permanent" lube, but it's about impossible to find Pentosin MTF2 anymore. You can buy the OE MTF-LT2 still, but it's pricey. I decided, with FCPeuro warranty returning in mind, to try Pentosin's MTF2 replacement, FFL4.
    I actually put some in a friend's 6spd a couple of years ago, and it's been working well. FCPeuro had it on sale as well, so here we go...
    Click image for larger version  Name:	FFL4.1.JPG Views:	0 Size:	80.4 KB ID:	139567
    The conventional 75w gl4 looked great (only had 2k miles). Happy to not see any synchros bits at all. Now I'm confident the tranny will be fine for years, with fresh fluid and relatively smooth (for the 420g) operation with no lockout or any issues.
    Click image for larger version  Name:	FFL4.2.JPG Views:	0 Size:	63.2 KB ID:	139569
    While doing this, I had ordered a new belly pan for my other M, so my old one got spruced up and installed on this car now
    Click image for larger version  Name:	FFL4.3.JPG Views:	0 Size:	223.9 KB ID:	139570 Click image for larger version  Name:	FFL4.4.JPG Views:	0 Size:	86.2 KB ID:	139568
    All back together. Now there are no more missing/broken pieces!
    Click image for larger version  Name:	FFL4.5.JPG Views:	0 Size:	52.5 KB ID:	139571
    The armrest's leather is actually in great condition, but unf, the hinge is broken and not repairable
    Luckily, my friend had a spare black armrest for me. You must disassemble quite a bit to get it out:
    Click image for larger version  Name:	Armrest1.JPG Views:	0 Size:	144.0 KB ID:	139574
    Good to remove the center console anyway as it needed a good cleaning
    Click image for larger version  Name:	Armrest2.JPG Views:	0 Size:	59.2 KB ID:	139572
    Here, you can see how it's broken compared to new one (bottom). Console cleaned/treated.
    Click image for larger version  Name:	Armrest3.JPG Views:	0 Size:	72.6 KB ID:	139573
    Going back in
    Click image for larger version  Name:	Armrest4.JPG Views:	0 Size:	76.5 KB ID:	139575
    Click image for larger version  Name:	Armrest5.JPG Views:	0 Size:	114.8 KB ID:	139576
  • 0-60motorsports
    Awesome update!
  • Tbonem3
    Thanks! I was thinking maybe the white behind the base coat would lighten it a touch, but maybe not.
    Overall, I'm pleased though
  • Sergmann
    Pretty darned good! A hair darker, but not much. I *think* using primer might have resulted in a slightly better match. Another:
    I used their primer on my project and it still came out a bit darker. I wasn't sure if it was just some fade from a 20 year old paint job or something else. I have read that metallics especially turn darker if laid down to heavy but I'm not a painter.
    this looks great IMO
  • Tbonem3
    Click image for larger version  Name:	roofrails01.JPG Views:	0 Size:	80.9 KB ID:	137435
    Click image for larger version  Name:	roofrails02.JPG Views:	0 Size:	95.3 KB ID:	137436
    They just pry up. I used a small flat head to get started
    Click image for larger version  Name:	roofrails03.JPG Views:	0 Size:	72.2 KB ID:	137434 Click image for larger version  Name:	roofrails04.JPG Views:	0 Size:	94.6 KB ID:	137433
    Another newly exposed area shows the level of dirt I've had to deal with on this car.
    Click image for larger version  Name:	roofrails05.JPG Views:	0 Size:	80.6 KB ID:	137437
    And dead bugs to boot
    Click image for larger version  Name:	roofrails06.JPG Views:	0 Size:	100.0 KB ID:	137440
    Cleaned up:
    Click image for larger version  Name:	roofrails07.JPG Views:	0 Size:	69.7 KB ID:	137438
    Click image for larger version  Name:	roofrails08.JPG Views:	0 Size:	67.2 KB ID:	137439
    Nothing broken luckily, and not too dirty here.
    Click image for larger version  Name:	roofrails09.JPG Views:	0 Size:	105.5 KB ID:	137442
    Hosed them off, then applied protectant to rejuvenate while I prepare the surface to be painted
    Click image for larger version  Name:	roofrails10.JPG Views:	0 Size:	183.4 KB ID:	137444
    Well worn
    Click image for larger version  Name:	roofrails11.JPG Views:	0 Size:	98.5 KB ID:	137441
    Sanded them down. Rather than try to remove and possibly hurt the rubber, I tried blocking it off with paper. It sort of worked, but some of the pieces ended up falling out. No biggie, the paint is easily chipped off the rubber at the end.
    Click image for larger version  Name:	roofrails12.JPG Views:	0 Size:	64.2 KB ID:	137443
    I bought a rattlecan of steelgrey 400 from automotivetouchup.com. *I should have used primer. It ended up fine, but I did a couple extra coats of base and actually used up the whole can on the 2 trim pieces.
    Click image for larger version  Name:	roofrails13.JPG Views:	0 Size:	78.7 KB ID:	137445
    Click image for larger version  Name:	roofrails14.JPG Views:	0 Size:	66.3 KB ID:	137447
    Then I used 1k clear which is decent enough for this small job vs. 2k. Plus I don't have professional equip/vent
    Click image for larger version  Name:	roofrails15.JPG Views:	0 Size:	74.3 KB ID:	137446
    So metallic in the sun!
    Click image for larger version  Name:	roofrails16.JPG Views:	0 Size:	181.5 KB ID:	137448
    After drying, before finishing, I wanted to see the color/metallic match
    Click image for larger version  Name:	roofrails17.JPG Views:	0 Size:	50.2 KB ID:	137449
    Click image for larger version  Name:	roofrails18.JPG Views:	0 Size:	47.4 KB ID:	137450
    Ok time to color sand and buff. Used 2.5k. In hindsight, I should have done one more coat of clear to give myself a little more wiggle room. I took it easy on the sanding, and it worked out.
    Click image for larger version  Name:	roofrails19.JPG Views:	0 Size:	120.1 KB ID:	137451
    Click image for larger version  Name:	roofrails20.JPG Views:	0 Size:	105.6 KB ID:	137452
    Now to buff and restore clarity. A little compound first
    Click image for larger version  Name:	roofrails21.JPG Views:	0 Size:	138.2 KB ID:	137455
    Now polished
    Click image for larger version  Name:	roofrails22.JPG Views:	0 Size:	104.6 KB ID:	137456
    Click image for larger version  Name:	roofrails23.JPG Views:	0 Size:	38.9 KB ID:	137453
    Ok, time to reinstall (step 1: push down. step 2, there is no step 2 )
    Click image for larger version  Name:	roofrails24.JPG Views:	0 Size:	58.4 KB ID:	137454
    Click image for larger version  Name:	roofrails25.JPG Views:	0 Size:	74.3 KB ID:	137459
    Click image for larger version  Name:	roofrails26.JPG Views:	0 Size:	40.2 KB ID:	137457
    Click image for larger version  Name:	roofrails27.JPG Views:	0 Size:	45.3 KB ID:	137458
    Click image for larger version  Name:	roofrails28.JPG Views:	0 Size:	51.8 KB ID:	137461
    Click image for larger version  Name:	roofrails29.JPG Views:	0 Size:	48.2 KB ID:	137460
    I'm really pleased with this. The faded roof rails were really killing the car's vibe. Even more than the shit tint, I was dying to get these redone. Spent about $40 in base and clear cans. A big win!
