2002 Steel Grey 6spd coupe Daily/Restoration project
  • Sharocks
    Ya sorry, itching for a v10
    this car is probably sold tomorrow I'll update
    You going Bangle Butt V10?
  • Tbonem3
  • Sprp85
    Noooo! Enjoyed reading up on the resto progress...
    What's next??
  • Tbonem3
    Car is for sale - $25k if anyone here is interested or knows someone. Thanks, Tyler
  • lvm3sm46
    Sounds really good that Scorza
  • Tbonem3
    Time to address the sagging/dented bumper and throw on my scorza muffler!
    Boat anchor down - also take note of the dent or warping of the bumper up top
    Click image for larger version  Name:	rearbumper01.jpg Views:	0 Size:	159.9 KB ID:	151239
    I've never removed a rear cover before, never had to. Surprisingly easy. A few screws/rivets at the back fender liner and a couple of "screws" in the trunk under the tail lights.
    Click image for larger version  Name:	rearbumper03.jpg Views:	0 Size:	71.6 KB ID:	151237
    And it slides off.
    Click image for larger version  Name:	rearbumper05.jpg Views:	0 Size:	137.0 KB ID:	151238
    It looks like the plastic just collapsed here. I'm not sure why, but I will try to shim it (the kevlar carrier slides right under so I can shim in between kevlar and the plastic.
    Click image for larger version  Name:	rearbumper06.jpg Views:	0 Size:	72.2 KB ID:	151240
    Bumper back on, Slipped some dense rubber sheet in between kevlar and bumper cover - it evened out well! & Scorza on!
    Click image for larger version  Name:	rearbumperscorza01.jpg Views:	0 Size:	154.3 KB ID:	151242
    Love this muffler. Rarely see any posts about them or being for sale at all anymore. I had the SGT version on for a bit (on my other car), but it didn't quite sound as good. Not quite as loud or throaty. Less of that wail this thing makes. I'm really looking forward to how it sounds on this car with Fabspeeds' 55mm outlets. I always thought it sounded better with my 55mm euro headers or my friend's 55mm SSv2s than it did on my 63.5mm v1s.
    Click image for larger version  Name:	rearbumperscorza05.jpg Views:	0 Size:	91.4 KB ID:	151241
    Diffuser back on, everything done now.
    Click image for larger version  Name:	rearbumperscorza11.jpg Views:	0 Size:	143.6 KB ID:	151243 Click image for larger version  Name:	stahlrear1.jpg Views:	0 Size:	191.1 KB ID:	151245
    A little video I took while my friend was driving it. so fuckin' güt:
    Little thing: I noticed coolant was coming out the little expansion line. The o-ring was a new OEM Rein part, but we know those aren't the best. I didn't expect it to leak this bad so quickly. WOLFN8TR to the rescue with a new one
    Click image for larger version  Name:	steelexporing1.jpg Views:	0 Size:	89.1 KB ID:	151244
    Luckily, the neck of the line wasn't damaged - it was all the coolant crusted up. Drained some coolant.
    Click image for larger version  Name:	steelexporing2.jpg Views:	0 Size:	97.8 KB ID:	151247
    Getting the o-ring out is easy enough with a pick, but putting the new one is was a bear actually. I had to remove entire hose end to catch the new o-ring if I inserted it too far.
    Click image for larger version  Name:	steelexporing5.jpg Views:	0 Size:	95.5 KB ID:	151248
  • Tbonem3
    Thank you! Ya he just keeps quiet lol
  • lvm3sm46
    Speechless on the resto work. Your hard work can definitely be seen. Has your wife's uncle seen the car recently?
  • Tbonem3
    Weird
  • 02_lsb
    I am 99% sure pre LCi cars only came with one boot. My car, and literally every other car I’ve seen only had one. I did the same as you and added the other.
  • Tbonem3
    You're welcome guys, Merry Christmas!
    Originally posted by Will View Post
    Car looks fantastic.
    Thanks!
  • Will
    Car looks fantastic. Thanks for posting so many before / after photos, too!
  • Casa de Mesa
    I always thought it was weird only one of those plugs for the xenon ballast had a boot. Thanks for posting the part number too.
  • Tbonem3
    A couple of little things...
    The front roundel is in surprising great shape, except for a spot at 7:30 that's badly worn. Can't cheap out now that the car is basically finished exterior-wise, so I ordered a new one.
    Click image for larger version  Name:	hoodroundel04.JPG Views:	0 Size:	82.1 KB ID:	145179
    Popped it off, and what do you know, more dirt.
    Click image for larger version  Name:	hoodroundel05.JPG Views:	0 Size:	40.3 KB ID:	145178
    Cleaned
    Click image for larger version  Name:	hoodroundel06.JPG Views:	0 Size:	35.4 KB ID:	145177
    New emblem and grommets
    Click image for larger version  Name:	hoodroundel07.JPG Views:	0 Size:	22.8 KB ID:	145176
    Fresh
    Click image for larger version  Name:	hoodroundel12.JPG Views:	0 Size:	40.1 KB ID:	145181
    Click image for larger version  Name:	hoodroundel13.JPG Views:	0 Size:	43.2 KB ID:	145180
    One of the xenon plug boots is missing, which seems to be a common issue. I think it's usually this left one, I think it's looser. Anyway, I happened to find a replacement while browsing realOEM, but I had to figure out how to replace it!
    Click image for larger version  Name:	xenonboot1.JPG Views:	0 Size:	91.9 KB ID:	145182
    I remembered another forum member saying that all our plugs can be disassembled (pin out?) so I fiddled with the plug and a small flat driver. Didn't take long, and I had it all apart:
    Click image for larger version  Name:	xenonboot3.JPG Views:	0 Size:	58.8 KB ID:	145183
    Click image for larger version  Name:	xenonboot4.JPG Views:	0 Size:	96.2 KB ID:	145184 Click image for larger version  Name:	xenonboot5.JPG Views:	0 Size:	117.1 KB ID:	145186
    et voila
    Click image for larger version  Name:	xenonboot6.JPG Views:	0 Size:	102.3 KB ID:	145185
  • Tbonem3
    Thank you very much
