Bran.Stum's first 'M' - 2002 M3
    Onto 2021 -
    One morning on my way to work, the M3 suffered a weird malfunction and left me dead in the water. At first it was chalked up to a failed fuel pump as we did not hear it prime when turning the key to position 2. Tried to pull codes, if any, but OBD would not communicate with a reader or laptop, more on that later. Since we figured it was a failed fuel pump, I replaced it with a known good lower mileage used unit, which of course did not fix my issue. It was discovered that my DME had actually bricked itself, which would explain no fuel pump priming or communication from the OBD port. Brett lent me a DME while mine was repaired.
    Here I am stranded on the side of the road.
    Being a broke college student, and fearing damage from a careless tow truck driver, I was hesitant to call one. My buddy and I had the BRIGHT idea to flat tow it to his apartment. Yeah didn't go to plan. A miscommunication led to me braking when I should not have, resulting in the tow hook ripping through my front bumper, damaging not only my bumper but also my bumper reinforcement and I lost my towhook cover. My other headlight washer cap also fell off later on.
    I replaced the bumper reinforcement, tow hook cover, and replaced the headlight trim with non-washer trim some time later.
    I broke and called a tow truck, which thankfully the driver was really understanding and careful with my car. To this day, this is the only time the M3 has ever been on a tow truck or left me stranded like this.
    After the M3 was back up and running, I ended up buying some used Status Gruppe Tuning catless headers.
    New hardware gaskets, and CPV.
    Can't even see them under the heatshield.
    Replaced the alternator with a reman Bosch unit. I've seen a lot of people have issues with these since then, but I'm happy to report that I seem to have missed out on that. Still working fine in 2026.
    Non headlight washer trim.
    Replaced all six fuel injectors with new Bosch.
    New mechanical fan assembly.
    Noticed some hotter than usual coolant temps on my way home one day. Poked around in my engine bay later that night, saw that the return line was leaking. Poked it and the whole connector broke off.
    I also chose to replace the original water pump with a new Saleri unit. (The Saleri unit ended up showing signs of premature failure only 9k miles later and replaced with new OE.) Radiator was replaced with new OE as well.
    Doing some bored cleaning. Plate bracket cleaned and ceramic coated. Paint underneath was cleaned and polished. Plate was also ceramic coated.
    Cleaning the wheel wells. Calipers and pad retaining clips were also refreshed.
    In September 2021 I decided to move to the bay area, Pleasanton to be exact, with my then girlfriend. Loaded up the M3 with my clothes and PC, drove down. Left it at our house and took Amtrak back and picked up a U-Haul to load up the rest of our stuff.
      Onto 2022 -
      New M sticker.
      AJ Hartman sunroof delete panel.
      Finally had the heavily pitted windshield replaced. New OE seal, glass, and windshield cowl.
      Cleaning underneath of course.
      Sent my steering wheel trim out to be refinished.
      Had the sunroof delete panel and roof rails painted.
      New clips for the roof rails.
      Cleaned both channels.
      Very nice.
      Replaced the trunk handle. New foam gasket, button, and plate lights.
      New OE hazards button.
      New F10 M5 shift knob.
      Power steering pump was on it's last legs. Replaced the pump, hardware, reservoir, all lines, and pulley. Bosch pump, everything else OE.
      Came out to head to work one day and found that my cluster was unresponsive. Sent it out to be repaired.
      Came out of work one day to discover that someone had stolen one of my kidney grills. I was surprised to say the least as I lived in a pretty nice side of town. Started parking in a gated lot after this.
      Thankfully my buddy Eric had a set for me.
      Unfortunately thing's didn't work out in the bay with my ex, so I moved home. Life was rough but I found great solace in working on the M3, no matter how big or small the project.
      Polished and ceramic coated the fading shadowline. This is a bandaid fix and only lasts a few years at a time.
      Replaced all sensors with new OE (cam sensors, crank sensor, knock sensors, TPS).
      Finally got my hands on a BlueBus unit.
      Bright side about coming home was that I had a lot more room for activities, like a seats out full interior detail day.
      Deleted the sticker on the Recaro.
      Cleaned under the door sills and sideskirts.
      Replaced the washer reservoir with a non headlight washer one.
        Onto 2023 -
        Replaced the two ICV hoses. Can't believe how expensive these are and that I paid that much for them.
        All trim removed and thoroughly washed for a full paint correction. Can't remember if this pic was before or after I finished up.
        Fresh ceramic coating.
        Glossy.
        New hood struts. Trunk struts were replaced as well.
        Ended up going back to a Dinan intake.
        New paint code sticker from Brett.
        And a high mileage, cheap, daily. 05 3.0i, Highland Green over Teracotta, and 294k miles.
        I put a good amount of work into this thing. Extensive detail, new tires, pads, rotors, shocks/struts, full cooling system, belts and pulleys, windshield & cowl, window regulators, LCI taillights, fresh window tint, roundels, center caps, sport steering wheel, all weather mats, and diff fluids. Spent way too much, but it cleaned up pretty well.
        Night drive through Yosemite where I realized I had a plate light out.
        Found a functioning Mk4 drive and 'oddments tray' in the junkyard.
        M splash screen and latest software installed.
        Also found a first aid cubby and warning triangle bracket. Cubby got cleaned up, ordered a new warning triangle. The newest PN for the triangle is much longer and skinnier than the previous versions, so it is too loose in the bracket.
          Onto 2024 -
          New Radium catch can.
          ZHP coupe ended up in the yard, it was a very rainy day so it was completely untouched still. Would've grabbed the black cube trim but it was way too beat. At least snagged the high gloss shadowline for a whopping $8.
          Seals were shot so those were replaced with a new set from Matthew Navis.
          Owned the X3 for about a year but sold it due to it not being fuel efficient enough for the hour commute that I had. Replaced it with a 12 X5 35d. Platinum over black sport package.
          First full day of ownership.
          Serving it's purpose.
          Anyway.
          Another valve cover gasket done.
          Got a house with my best friend, who is also responsible for getting me into BMWs. It all started when he took me for a ride in his mom's LMB/LMB E39 M5. Hooked ever since.
          My M3 and his 335i in our garage.
          Ordered a fan shroud for the M3. I use to have one but misplaced/broke pieces long ago, so it was nice to finally have a complete engine bay again.
          New push rivets.
          Decided it was a great time to finally do my sunroof delete. It was supposed to be a quick simple project, and it really escalated.
          Removing seats.
          Slicktop coat hanger brackets.
          Loosely fitted. Didn't have time to finish as I flew out to the east coast the next day.
          While I was in New Jersey, I rented a little 500 Abarth on Turo. I absolutely fell in love with the immense personality this car had. I really wanted one but just could not justify having three cars.
          Finally found a nice set of black cube trim in Lithuania of all places. Took about a month to arrive.
          Immediately disassembled them, shipped out the lower soft touch portions to be refinished, and refreshed the cube portion itself. Light misting of black paint covered any small scratches that were present. This was the perfect set for this as there was only minor wear present. No deep scratches or dents.
          Back together. Absolutely perfect looking.
          Door panels steam cleaned and armrests installed. Minty af.
            Onto 2025 -
            Picture heavy.
            Delete panel getting sealed up.
            With the interior still torn apart, I did some thorough cleaning.
            Seats steam cleaned.
            All trim pieces were cleaned and ceramic coated. Anything that was scratched, scuffed, or flawed was replaced with new trim from the dealer.
            New C pillar lights.
            Swapped nicer buttons over to my very nice homelink. Cleaned and ceramic coated.
            Removing the seven year old tint in preparation for fresh.
            Man fishbowl looks so good.
            New third brake light as the seal had torn on mine.
            Everything reupholstered in 9002 Alcantara. B/C pillars, parcel shelf, and headliner. The A pillars were sent out to another shop by themselves.
            Reinstalled the Recaro so I could have fresh tint applied. Felt like an absolute rocket with a stripped interior.
            Fresh 35% ceramic applied front and rear. Got some mixed input at the tint shop. Had one guy tell me he thought it had 20k miles, and the other asked if it was a drift car due to the stripped interior lol.
            Finally reassembling the interior. At this point the car has been torn apart for almost five months. Started on Nov. 2024 and reassembly began in Feb. 2025.
            With the fresh alcantara b pillars, the faded felt on the door seals just wasn't cutting it. These were ridiculously expensive.
            And not even the original ones according to this date code.
            Old.
            Vs. new.
            Found some small rust spots under the seals though.
            Sanded down, rust converter applied, and painted.
            Same with the small spot on the passenger side.
            Polished and ceramic coated this trim on both quarter windows.
            Was going through the yard one day and happend to come across not just one, but FOUR slicktop sedans in various configurations. One was a early (99-00) build with a 5spd, manual seats, armrest delete console, and zero options. On the other end of the spectrum was a facelift, mtech 1, grey over natural brown example complete with nav, xenons, HK, etc. This one just so happened to have the slicktop specific homelink trim.
            Cleaned up, ceramic coated, and installed. Finally homelink back in the M3.
            A E46 coupe in the yard had a pretty complete owners manual. Grabbed everything to supplement whatever may be missing from mine without realzing that mine was very complete as well. Only thing I needed was the CCA brochure, CEL pamphlet, and a safety tips sheet.
            Things just kept escalating lol. With the rest of the interior looking so nice, I replaced the entry sill trim, dead pedal, hood release lever, and pedal covers.
            Eventually I repalaced the climate controls with one out of a LCI car.
            New one torn apart and cleaned.
            The O'Reilly battery that was in the car began dying. Replaced with a new OE battery. Battery tray had some surface rust. Replaced the tray and hardware.
            New door handle gaskets on both sides.
            Headlights torn down to replace the pitted lenses and gaskets.
            New PPF on the foglights.
            Cleaning while the headlights are out.
            New Magneti Marelli indicators as well. PPF was applied to the headlights (not pictured).
            New cheapy CSL splitters.
            I did end up buying an Abarth. 2017 67k miles, clean title no accidents, manual, Rhino Grey/Cloth, slicktop.
            X5d did end up getting sold a long while after. Three cars was certainly a lot to juggle for an extended period of time.
              And onto the current year of 2026 -
              NOS OE 2015 nav dvds sourced.
              Pass. exhaust hanger replaced again.
              Diffuser had been sagging a while, finally fixed that. (No before pic unfortunately. It sagged on the driver side in between the tips).
              More new trim.
              (The screw cover).
              Registered the M3 for a euro show put on by the local BMW CCA.
              All cars got washed the night before.
              From left to right -
              C63s AMG, 911 Turbo, F30 335i, and my M3.
              Unfortunately I walked away with no prizes, but my buddy did win best Porsche.
              Bought a rear sunshade on eBay.
              Cleaned up and refreshed the trim.
              Only one side was still available from BMW, the other side got cleaned and ceramic coated.
              New filled out switch console.
              Really wish I had done this when the interior was torn apart last year.
