1M Carbon parts
    1M Carbon parts
    Well the 1M was needing a little Carbon just so i could feel at home
    :whistle:
    Radio and Aircon panel
    Got new trims from bmw as they are cheap and that way i can put the car back to standard if or when i sell it.
    Sanded the trims then the resin went on
    After the resin goes tacky around 4 hours the carbon is put on and then the parts are put in a vacuum bag for another 6 hours.
    Then they are taken out the vacuum bag.
      More coats for resin then trim the excess carbon sand the parts down and more resin.
        Another coat of resin then sand down again with 800grit wet and dry.
        (No finger prints left) :bigcry:
          Then its time for the 2k clear.
            Snading agin this time 1500 grit then 2000 grit and polish and install
            Just the ashtray gear surround and the cic trim :thumbs:
              Looking good mate :thumbs:
                +1 :thumbs:
                  Is it not slow enough without adding more weight :thumbs:
                    not that I don't approve of your handiwork, you've already helped me out once... but covering things in carbon to look like carbon and hence making them heavier kind of goes against the point of carbon does it not? I used to give the Noble guys hell when they had things dipped... I'd feel bad if I didn't at least mention it once.
                    Then again, it can't be that much extra weight just covering a bit of trim. Looks good :thumbs:
                      It want be as heavy as me getting in it :hahaha:
                      Not as slow as the CSL m8 430bhp with a chip and FMIC :thumbs:
                      Its for the look its not about saving waight it looks a lot better than black plastic:whistle:
                        Thats me finnished the ashtray and gear trims in carbon :smokin:
                          some better pixs taken outside.
                            Very nice Mark, looks well.
                            I forgot how good the alcantara gear stick gaitor looks on these.
                              Nick work Mark, looks very good with all the bits done :thumbs:
