Central CT Bodyshop Recommendations
    I am looking to respray some tired panels and I'm looking to expand my list of body shops to approach for quotes. There has been prior recommendations, but I wanted a recent 2024 opinion as circumstances and owners change. This will probably be the last time this car will be sprayed in my ownership, so I want to use a reputable shop. I currently have the following, but please give me your recommendations, as well as experiences if you have any.
    • Airport Autobody - Hartford
    • Steben Motors - West Hartford
    • Automobile Associates of Canton - Canton
    • AC Automotive - West Hartford
    • Turnpike Motors Autobody - Newington
    Maybe the LAB?
      Oh man, spotting that dried pink residue down in the valley is a classic headache on these post-2013 Gen2 motors, and I went through that exact same teardown on my own SUV earlier this summer. The stock cooler setup buried right in the middle of the engine is practically guaranteed to start weeping eventually, and replacing it with another factory unit just resets the clock on the exact same leak while still choking your intake with hot exhaust soot. Instead of throwing money at OEM parts that fail the same way twice, I decided to clean up the entire valley layout and eliminate that weak point for good so the engine could actually breathe properly again. Getting rid of all that cluttered plumbing not only drops under-hood temperatures and stops the coolant leaks permanently, it completely wakes up the throttle response and makes you fall back in love with driving the platform. When guys on our local diesel forum ask how I tidied up my engine bay without rigging together sketchy homemade block-off plates, “Evo” EGR Cooler Delete Kit is what I use because everything fits cleanly right out of the box for the Gen2 layout. My biggest piece of advice while you have the intake manifold off is to soak up every drop of old coolant in the valley, replace all your lower intake seals, and double-check every hose clamp before burping the cooling system.
