what kind of power supply do you use duiring flashing?
  • terra
    Realistically unless you're doing 1hour + flashing sessions, the car's battery is fine.
  • uberchris
    I built one of these bad boys: https://www.e90post.com/forums/showthread.php?t=1838716
    50ish amps for about the same price as a regular charger. Certainly overkill for the e46, but useful if you flash newer stuff, too.
  • Fresh1179
    I use this trickle charger and have for years! It is a little bit on the expensive side but it has saved many a battery and has the option for for 2A, 8A, 15A. It's great! $100
  • freezingair
    this, bought at Autozone
    Thank a lot!
  • maupineda
    Originally posted by freezingair View Post
    which one do you use?
  • freezingair
    I have used a 10A without issue
  • freezingair
    These chargers only do 6v/12v as far as I see, so I don't know where you're going to find the 13-14v. I think the person who wrote that suggested 13-14v because that's what the battery puts out when the car is running?
    Yes, that is also my question about this. I saw this one Amazon.com: CTEK (56-353) MULTI US 7002 12-Volt Battery Charger,Black : Automotive​ has power supply mode which can give out 13.6V and 7A. But not 10A.
  • freezingair
    I guess depends. Quick mssflasher to read/write a partial bin you should be fine (unless you know your battery is on it's last legs), updating full bin or modules which take time, could be a different story. As precaution, turn automatic lights off, radio off, fan/ac off.
    Are those flasher software all the same? I saw mssflasher and also MSS5x etc. Just get confused.
  • freezingair
    What are you flashing? A fully charged battery should get you through a few DME flashes no problem. Only takes a couple minutes to flash the DME. Yes, there's a chance of messing up the DME if the battery dips too low, but you'll notice before that happens (lights get dim, radio starts popping, etc.).
    I recently did a bunch of flashing/coding on mrgizmo04 's car without plugging it in and it was fine even on his teeny lithium ion battery.
    Just mentioning this to save you some money/time in case all you're trying to do is flash one tune onto your car. I think the reason the SMG flash thread mentions a charger is that that actually takes a long time (more on the order of a half hour than a couple min).
    Just got my M3 with a shark injector v2 tune. The owner wants to sell his device to me. I just don't want to spend this kind of money. So I'm trying to flash stock first and then CSL DME. I assume it may take longer than coding some parameters or tune.
  • mrgizmo04
  • heinzboehmer
  • maupineda
  • Tbonem3
  • freezingair
    Thanks, I just read it here and other websites mentioned 10A.
    DIY: Flashing your SMG module with CSL Software + CSL Rev Matching and Torque Maps - NA M3 Forums
    - An E46 M3 equipped with the SMG2 Transmission
    - BMW Standard Tools 2.5.0 or later (Should come with WinKFP 5.1.6 or newer)
    - Access to E46 data files (I recommend Ista/P V37 or later)
    - Some sort power supply that can stably supply 13-14V at 10A
    Unlike coding with NCS Expert, reflashing a module with WinKFP takes quite a bit of time and consumes quite a bit of power. A failure is almost guaranteed if you don’t use a good power supply. Make sure it isn’t one that’ll automatically turn off.​"
  • Tbonem3
    I didn't know 10amp was suggested. I thought even a trickle charger at lower, "maintenance" amperage like 4amp was sufficient. What's the likelihood of a batteyr to go bad if it's on a trickle charger?
    Perhaps you want a switchable charger that does maintence (lower amp) for when the car sits AND higher amp (10a) for flashing and recharging a low battery?
    Interested to see more responses, good question!
