Originally posted by karter16
As far as the spreadsheets, i modified them to fit the 18x12 format of the mss50 map LOADxRPM. Changed the formula to work with my setup that does not use VE values but lambda. Its works fine but the adaption part was the only sketch thing.
IM NOT SAYING DISABLING ADAPTIONS IS NOT GOOD FOR CSL 0401 GUYS BUT JUST POINTING OUT SOMETHING I NOTICED THAT WOULD BE A GOOD IDEA FOR EVERYONE TO KEEP AN EYE ON JUST IN CASE, GOD FORBID.
It makes sense though because if you disable adaptions the engine will run closer to 14.7 the more you tune it and that is going to run hotter. With adaptions on it will oscillate, at least thats what i saw in my data logs. IDK what caused that but when i turned adaptions on, the temp normalized.
