A quick and easy way to street tune your CSL conversion for drivability.
Just don’t touch the flap map and that should keep you in the safe zone. I run the flap as well. I edited the main map and the cold start maps only. The flap map is additive, so it doesn’t need a retune.Originally posted by Cubieman View PostI am running the flap, is there another parameter I need to be taking into account?
I'd like to try this method out but not sure if the flap is going to make things a bit more difficult for me as I don't fully grasp the whole tuning deal/programs generally speaking.
Going to at least take a few logs before the weather really turns.
I don't know is VE map is functional on idle, better to ask it from topicstarter
I have the same isle hunt with AC on for years lol. Running OE CSL intake and FlapOriginally posted by puma1824 View Post
Great thanks! Yeah currently I do have the active flap but I do not have CSL cams. What I am experiencing sometimes in low RPMs whether from a stop or even while running, there are some slight hesitations. Additionally sometime,s when first starting the car or when AC on the idle waves / goes up and down. So maybe all this tuning talk and suggestion will help. Problem is I've never tuned before. I don't even have any of the software mentioned. Where oh where to start lol.
Great thanks! Yeah currently I do have the active flap but I do not have CSL cams. What I am experiencing sometimes in low RPMs whether from a stop or even while running, there are some slight hesitations. Additionally sometime,s when first starting the car or when AC on the idle waves / goes up and down. So maybe all this tuning talk and suggestion will help. Problem is I've never tuned before. Other than Excel or Sheets, I don't even have any of the software mentioned. Where oh where to start lol.Originally posted by BMWfanz View PostThe reason is simple: 90% of CSL airbox swaps does not have a stock flap or CSL cams- setup is stock cams or tuned bigger angle cams, more than CSL ones. So most of tuners does not tune partial load maps- cause it is very long story and tune only WOT maps. So if you have CSL airbox setup with no flap or not CSL cams- car have some issues with driveability on partial loads. Its hestitates on low RPMS, struggle acceleration from low rpms etc. Often tuner will say- go downshift and rev it from 4k- but driveability is always what any driver wants. So what about this topic- just easy solving of partial load issues. Great method BTW.
I'm trying to learn and understand but still not clicking with me. I'm not sure if I need this or what issue it's trying to solve or what issues I should be looking for in my "CSL" build to determine if I need to go down this path. Is there a dummy version of what this is fixing and what issues I may or may not have to determine if I need to "fix" it? BTW I just got my conversion back a few weeks ago so I just started driving it BUT I think I am experiencing this what one had described in a previous post "....the engine behavior at very low throttle inputs, like when pulling away from a stop or changing gears. Before, the rpms would oscillate quite a bit and make things pretty jerky (sidenote: hadn't realized I was driving around this until now), but that is completely gone now. ...."Last edited by puma1824; 12-07-2023, 07:20 PM.
You can start from either one, although I’d suggest starting from your tune to keep the extra fuel at WOT. I started from a tune that I wasn’t happy with, then I backed off some of the timing at lower RPMs and returned some of the DME’s overall latitude to pull timing back if it detects pinging. None of the lauded tuner files I’ve seen have touched part throttle fuel, so you’re likely starting from a stock map either way.Originally posted by BMWfanz View Post
Just to clarify some details- If i'm not happy with my current tune- before start- i need to use stock CSL tune bin and then corretc VE table? My tuner changed ignition and WOT fuel trims- so as i see- i can go for stock WOT fuel map and just correct VE table, am i right?
Just to clarify some details- If i'm not happy with my current tune- before start- i need to use stock CSL tune bin and then corretc VE table? My tuner changed ignition and WOT fuel trims- so as i see- i can go for stock WOT fuel map and just correct VE table, am i right?Originally posted by Bry5on View PostFor the record, here’s the difference between the default CSL tune and the 5 runs in version using this method on my car. Super clever, thank you for sharing!
Throttle tip in is so much smoother and the motor seems much happier. I agree that a good amount of the rasp is gone in that mid-2k RPM range. Looks like those CSL cams and the SS headers really do make a difference. With these headers, I needed fuel almost everywhere, and particularly in two islands.
My motor is a 180k mile stock internal CSL conversion, with flap, SS v1 headers and matching catted section 1. This tuning was done with flap closed to the appropriate map.
Adaptations are now turned back on, so I’ll be watching what the motor does.
edit: I’d bet that the resonances and jitteriness in the 2k RPM range can be totally tuned by changing the interpolation motor RPMs. I did this for my WOT tune and was able to get a super flat AFR curve by targeting the resonant and nodal frequencies as the interpolation points.
Adaptations back on and they're at 1.01 and 1.00 after driving around for a bit. Nice.
- Likes 3
Alright, first warm up data log done after flashing the interpolated warm up table. Waited for the car to cool down fully (more than 24 hrs) and started logging immediately after start up. Still only got like 4 minutes of logs before the engine switched over to the hot map...
Here's the interpolated warm up table compared to the first iteration using the same lambda integrator method:
(I made sure to filter out any points >= 80 C in megalogviewer)
So, it's super close to the interpolated table. Considering this table only ever really gets used for a handful of minutes, I think this is my last iteration. Very happy with all this drivability tuning
Edit: Attached the megalogviewer warm up settings profile to this post if anyone wants it. Forum doesn't like the ".settings" extension, so just remove ".txt" from the filename and use like normal.Last edited by heinzboehmer; 12-01-2023, 12:09 PM.
Thanks a lot! Hope i understand all)))Originally posted by heinzboehmer View Post
Set "Lambda Adaptation_MINIMUM ENGINE TEMPERATURE (K_LAA_TMOT_MIN)" to some value above operating temp. I set mine to 210 F. The XDF linked in the video on the first post has this parameter identified.
Also, make sure to reset adaptations after flashing. Turns out that turning them off means that the DME won't update the stored value and not that the DME won't use the stored value in its VE calculations (ask me how I know...).
Now i need to wait some warm days) Because its too cold outside, just 0-1 celsius, and engine don't warm up correctly)
