Csl ecu conversion and software
  • maw1124
    heinzboehmer , thanks for the file!! High value contribution...
    Cheers,
    maw
  • heinzboehmer
    Originally posted by S54B32 View Post
    Sorry, that’s not correct. The MAP affects your fueling in CSL soft EVERYTIME as long as it is present, I must look again in dumb, but maybe under full throttle it‘s not relevant.
    fueling tables also scaled different in CSL soft than in normal HP.
    Oh cool learned something new, haven't really looked at the tune myself. My comment came from what this doc says on pages 29 and 30.
  • S54B32
    Maybe someone with more tuning experience can chime in here, but I don't see why you couldn't. I'm just not sure it's worth it at that point. Might as well just bite the bullet and get a dyno tune that's fully optimized for your specific setup.
    Edit: Thought about this a bit more. I don't think that copying the fuel tables from the HP over is a good idea. Those are made for less airflow, which means you'd probably end up running lean. Especially because the CSL tune runs in alpha-N mode most of the time and only really falls back to the MAP in extraordinary circumstances (TPS or pressure sensor in DME fail for instance).
    -edited- look at post #45.
  • liam821
    Ah, yeah, that makes sense. I would expect the car to have access to more air not having to suck through a MAF and all. I'll just go with a stock CSL map and then get it dyno tuned at some point. Thank you!
  • heinzboehmer
    Makes sense. Is there a way to copy the ignition and fuel tables from one tune to the other? i.e. copy the fuel & ignition tables from the HP map to the CSL map?
  • liam821
    Stock CSL tune runs perfectly fine in terms of driveability with just the cam offsets changed. However, your AFRs will be off in some places because the fuel maps are still setup for the CSL cams.
  • heinzboehmer
    I have a completely stock US-spec 2004 SMG to 6mt converted car with a MSS54HP. I'd like to convert to a CSL style airbox with map sensor, mostly for the sound. How well does the stock CSL tune run on stock US cars with only the CSL airbox? I assume I'd need to do the cam offsets which I think I can do with tunerpro.
    If it runs good, awesome, if it runs like meh is there a somewhat easy way to use a stock HP tune with the CSL program? Or is taking the car to a tuner required?
  • liam821
  • And1m3
    Better is at the headers so its 100% accurate because at the muffler maybe some gaskets is leaking so its change the afr.
    He can remote tune.
    I didn't went to the dyno I took logs with afr at the road with innovate lm2 so I have everything that you need from ecu plus afr so after 6 logs and 5 tune files my car runs 12.8-13.1.
    Hassan its amazing person and very professional you will be happy
  • Cubieman
    Originally posted by And1m3 View Post
    Buddy i know from now your afr...its 9.8....
    I fix my car with HTE PERFORMANCE.....THE GUY IS AMAZING AND ONLY IN 5 FILES THAT HE SEND ME ITS RUNNING 12.8 TO 13 afr.....if you want my opinion go with HTE PERFORMANCE
    If I test AFR it must be done pre-cat correct? I'd like to test for it up the tailpipe but thats post cat and I don't think it would give an accurate reading.
    Also, did hassan remote tune yours on a dyno or did he send you different tunes to try?
  • And1m3
    I need to get my AFR checked, I am running a Kassel Tune and the car smells like it runs rich as hell.
  • Cubieman
  • And1m3
    Originally posted by sc_tr0jan_m3 View Post
    the previous owner of my car had a kassel tune on and it blocked even the simplest of OBD readers. i had to send my DME out to get wiped and rebuilt. i'm in the processes of getting the CSL software added on to enable access to the MAP that's installed on the car.
    The same issues here plus the tune
  • sc_tr0jan_m3
  • ATB88
    UPDATE...
    After 10 tune files from kassel the car still runs 9.8afr and the guy told us that the car have problem...long story short he doesn't know to tune for sure...what a waste of time and moneyis that guy........anyways we went with another tuner and the car runs 13.2 without to change any part on the car....
    Yikes.
