MSS5x Binary Modification Tool Update
  • Martyn
    Originally posted by E46 Adam
    Hey, I’ve been using your software for a while now and whenever I enable "Burble / Pop on lift off" , I can’t seem to be able to turn it off, any fix coming soon for it?
    You'll just need to revert to a partial without it enabled unfortunately.
  • Martyn
    Hey Guys,
    So I've been having some trouble with the way my car is shifting... mods below
    2005 ZCP (Jet Black/Imola), 192k miles.
    Schrick 288/280 cam (regular lift)
    Schrick coated followers
    CSL airbox (Karbonius)
    CSL OEM snorkel (with working flap)
    CSL air rail/Map sensor combo (TTFS)
    SSV1 headers
    SSv1 section 1 (200 cell cats)
    OEM sec 2
    Scorza exhaust
    3.62 gears
    CSL ECU (H Bridge - to control flap)
    CSL SMG module update "255"
    CSL ECU update
    So I have a dyno tune and it's not shifting well. When I downshift, it goes straight to engine braking in S4-6 any any rpm. When I have it in S3 or below, the blips are perfect (but slow on both upshifts and downshifts). I go into MSSFlasher and "SMG Inertia Update", "CSL SMG Shifting/Rev Matching" are greyed out. Does anyone else have this issue? I can't even drive in faster shift levels because I get thrown into the windows, upon downshift. Is there any way to adjust the amount of blip (so that I can match my S3)? Also, during my dyno (DYNO JET) I only seemed to hit 306hp, 242tq... that seems kinda low for all of the mods I have listed. Any ideas?
    Thanks,
    x Spades x
    It's greyed out because CSL software already has the CSL shifting etc baked in
    Who tuned the car? Have you tried stock CSL software to see if it's tune related? Probably best to start a new thread if you haven't already.
  • x Spades x
    Hey Guys,
    SSV1 headers
    OEM sec 2
    Scorza exhaust
    3.62 gears
    CSL ECU update
    Thanks,
    x Spades x
  • Martyn
    Originally posted by tdott View Post
    I don't see the burble pop option enabled for my e39 m5 file.
    I'm looking in to this, it looks like some US files have different minimum ignition tables to the euro ones.
  • tdott
    New features include:
    • Burble & Pop added for the E39 M5.
  • r4dr
    Originally posted by C///M View Post
    You think it's good now, you need to load the "255" CSL firmware on your SMG DME. That's what they all should have come with.
    Sorry, I should have specified. I did both parts — flashing through 255 software onto my SMG DME as well as the parameters via the binary modification tool.
  • WOLFN8TR
    UPDATING THE SMG ECU TO RUN CSL ‘255’ SOFTWARE
    For a definitive guide on how to update your SMG DME / ECU to run CSL ‘255’ software for improved shifting click here!
  • C///M
    Just did a flash today with a binary modified with this tool. Worked perfectly, great program.
    No clue why the SMG didn't come from the factory like this.
  • r4dr
  • heinzboehmer
    Is MSSflash a valid option to make sure I don't end up with a brick due to reaching flash limit? I just got ECUworx BinMod registered and am very new to this kind of stuff.
    Yeah you can reset the flash counter with the paid version of MSSFlasher.
  • Cubieman
  • NaM3
    This is great to see as I have been wanting to up my idle speed just a tad bit since my exhaust heat shield rattles at idle.
  • George Hill
    Thanks Martyn, love this!
  • Arith2
    Appreciate the service. I definitely need the idle increase because I just put in a new lightweight flywheel. Perfect timing.
  • mrgizmo04
