For those who drive to the track and then change wheels, camber and/or brake pads — what do you use for a jack? I have the low profile Arcan one but it’s like 150 lbs, and I still have to drive onto some 2x10s under each wheel for clearance. Suggestions are appreciated …
Track jack
Youtube DIYs and more
I got the same one would recommend.Originally posted by mrgizmo04 View Post
You’ll still need to drive up onto wood depending how slammed your car is. But it’s small and light. I had to bleed the hydraulic cylinder when I got it though.
Lifting with this jack is great. But lowering is an on-off switch. The car falls quickly. I usually use a screwdriver through the handle end to get more precise control when turning it while lowering.
I think a lot of jacks are like that when new.Originally posted by eacmen View PostI had to bleed the hydraulic cylinder when I got it though.
One thing I do is change the fluid out of the box. On the older "widow maker" HF jacks, I'd see a bunch of tiny metal shavings come out with the fluid.
I recently bought a replacement HF jack and didn't much garbage. (Old one was 15 years old and it seemed to be tired). Maybe their quality control is getting better.
Waking up - anyone here use a low profile jack? I'm looking at HF Daytona vs. Schwaben, thoughts welcome and TIA.Interlagos 06 M3, Dinan Champion wheels, Autologic tune, Agency Power midpipes/exhaust, Fortune Auto coilovers, UUC SSK, Bluebus, Lightwerkz retrofit. MRegistry listing here
Aluminum HF here. I still need to bring the front section of my race ramps to get the car high enough to jack up the entire axle. I also need a wood board because the aluminum jack's tiny wheels don't roll particularly well on the often rough paddock surfaces, not to mention they don't distribute weight well and will sink into hot asphalt.
I bring 2 of the HF blue jacks. I can't get the car onto 2t stands with only 1.Originally posted by pMak26 View PostAt any given track day, that aluminum HF jack posted and the HF Daytona low profile jack are the two most common jacks in the paddock. I leave my heavy daytona at home and take the Al one with me to the track.
I use a 1.5 ton HF blue for the paddock. This place sells rebuild kits: https://www.hcrcnow.com/
At home I used a 2.5 ton HF blue, but it started leaking, and the rebuild kit is discontinued. I ordered a 2 ton aluminum Jegs to replace it with, because they sell a rebuild kit for ~$30.
At the track, where are you guys placing the jack stand if you're doing one corner at a time? I've got an E46.
I've got a Daytona 2 ton "racing" jack, which is a great, pretty lightweight, jack. But, it can't get to the front or rear central points, so I can't do that and place jackstands on the factory pads on each corner. I have a "Jack Rod" to use in lieu of a jack stand (https://agm-products.com/products/jack-rod-2-ton), but I don't know if I fully trust it, and you have to lift the car incredibly high for its minimum engagement point.
I drive up on some wood so that I can reach the central jack points.Originally posted by prostcfc View PostAt the track, where are you guys placing the jack stand if you're doing one corner at a time? I've got an E46.
