Hi all,
My E46 M3 experienced high coolant temp at AutoClub Speedway in Aug. I started noticing coolant gauge pass 3/4 dot and reaching the red dot in the second and third sessions. The ambient temp was high around 105 degrees. I had to short shift and ease off the throttle to avoid coolant gauge going into the red zone.
In terms of relevant mods, I'm running Turner Motorsport underdrive pulley set including the water pump pulley and CSF oil cooler. My oil temp seemed to be fine on track. The rest of the cooling system and fan setup is all stock. I'm curious outside of flushing coolant and switch to 60/40 water/coolant mix, whether hardware upgrades are called for. I've also been looking at electric fan conversion. I'm not sure if I should be concerned about my lightweight battery not being able to support the fan. Any input would be very much appreciated!
