EML Light - 2 years in a row at COTA
    Chin Track Days runs an event right after the F1 race at COTA. FYI...it is kind of a pain because they are dismantling all of the temp structures in the paddock at the same time.
    Two years in a row I get an EML light. Same code P126. In 2021, I replaced both TPS and the gas pedal. In 2022, again, 2nd day got an EML light. I run over a lot of curbs because I've got McLarens, Radicals, and MB race cars chasing me. Oh, forgot, GT3RSs too. Are the TPS and gas pedal that fragile?
    There's three TPSs total (including the gas pedal)-- did you replace all 3?
      Yes, right after the event last year
        Probably the throttle actuator in that case. I've had to replace all 4 in my car.
          I had the same issue. My tune had too aggressive of a throttle curve. Reduced the curve and the issue went away.
            bigjae46 - did you ever come to a conclusion on this EML issue with your car? I have a thread going over on the main forum, and made some headway with Karter16's DS2 Tool as a way to diagnose a failing sensor.
              Ended up replacing both TPS and the pedal. No issues since.
