Testing water: E46 M3 custom roll bar GTS style - you weld kit
    As some members from RIP M3forum.net might remember, 6-7 years ago I was selling roll bar kit for E46 M3 Coupe. I am located in Montreal, Quebec, Canada so I would ship pretty much all the kits I sold.
    I will start to make another batch soon, I should have 5 kits available by the end of May 2023.
    This is not your usual bolt-in roll bar btw so I am aware that a Kirk or Autopower sells for a lot less.
    I will sell my roll bar kit with all the tubing already notched and the plates bend. All you need to do is fit and weld it in your car.
    -Tubes are DOM 1.75’’x0.095’’
    -Base plates for main hoop and rear shock tower are 1/8’’ thick and have at least 20sq-in to respect most rule book
    -Rear subframe cover plates are made from 16 gauges plates​
    Pictures are just to show what's included. I can make some different variation depending if you have a street car or full dedicated track car, keep B-pillars fabric covers or not, headliner, … cause main hoop will be larger a bit if car fully gutted.
    Here is what's included in the kit:
    -1x main hoop
    -1x horizontal bar between rear shock tower
    -2x diagonal bars from main hoop to rear shock tower
    -2x diagonal bars from main hoop to front subframe reinforcement tie-in points
    -2x diagonal bars from rear shock tower to rear subframe reinforcement tie-in points
    -1x X-brace between rear subframe reinforcement tie-in points
    -4x bars for subframe reinforcement tie-in points
    -2x main hoop base plates
    -2x rear shock tower plates
    -4x covers for subframe reinforcement tie-in point holes
    -2x gussets from main hoop to B-pillars (chassis)
    Kit will come with an installation instruction guide and can also make it in PDF if you want.
    Price: $2000usd shipping included​
    You can see my kit in the Chicane Motorsport E46 M3 S62 shop car here:
    https://m.facebook.com/media/set/?se...UV1mRCl7Q3t6ss
    Or in this 1000whp Laguna Seca:
    https://www.fastcar.co.uk/cars/turbo...whp-powerhaus/​
      If you've ever notched tubes for a roll cage...you'll know that this is a deal.
        I was supposed to offer this back in the days but A-pillars are too big to ship with regular Shipper.
        But I can think about it
