Common wisdom - track wheels and tires
Thanks.
Is this more an issue of chasing absolute grip, rather than optimizing tire size for the rim? Does the increased heat tolerance of a physically larger tire figure in?
Trying to learn as much as possible before dropping a bunch of money on track wheels and tires.
If you are talking about the outer diameter, that affects tire temps. A smaller diameter tire sees more revolution at a given speed which generates more heat. Also changes the final gearing.
You'll be fine. I've done it before with 17" wheels
Originally posted by D-O View PostQuestion for the folks running 275 width NT01's on a 9.5" rim. According to Nitto, the tread width of the 275 in both 17 and 18 inch is 10.6". Are you guys having any issues with this rolling under? 10.6" seems too wide for a 9.5" rim.
What PSI are you running?
Originally posted by bigjae46 View PostAnd does the shop do a string alignment or a laser alignment.
Originally posted by bigjae46 View PostCould also be a bushing issue. Rotating tires makes it more difficult to pinpoint the problem. A spherical RTAB significantly improved my tire wear over a relatively young OEM RTAB with limiters.
Also from last weekend: Estoril let me borrow his contact pyrometer to take temps and the inside-center-outside temperature range was fairly tight. < 10 degrees variance from 12 different measurements when I drove and <5 degrees variance and 5 degrees lower when the more experienced instructor was in my car.
My conclusion from looking at other RE71RS users is that this wear pattern is common, even on instructor's cars. I'm not the only one that hasn't figured out a way to prevent it.
This thread might help - https://www.m3post.com/forums/showthread.php?t=1607489
The tires wear that way in front and rear posiition.
OK, maybe it's not abnormal. But I'm surprised by the odd wear pattern on the outer edge of the center tread. If I had to guess, that will be the first place on the tire that will be completely worn out.
Maybe that tread block should be more rigid than it is for track use? If it is user error due to tire pressure or alignment, then I'm surprised (but willing to learn). I take careful psi measurements after every session and I have a reputable race-shop-performed alignment.
Wear is an indication of excessive heat. That kind of looks like toe wear but also could be camber wear.
I run -3.8 F and -3.0 camber front and rear and target hot PSI is 30 hot, I'm OK with as low as 28. Cold target is 6 psi lower in the morning which gets me to about 28psi hot for the first session. I get even wear across the face of the tire. My car is also 2825-2875 with fuel and driver. Sounds like your car is heavier, might need to add more negative camber front and rear, probably more than me because your car is heavier. Then toe settings become more critical for wear. Really need to be at zero on the front axle. I target half the toe as the stock spec on the rear.
A starting point for most tires is psi every 100 lbs as driven. So a stock car with driver and fuel is around 36-38psi hot.
This thread might help - https://www.m3post.com/forums/showthread.php?t=1607489Last edited by Slideways; 09-13-2024, 11:58 AM.
Front or rear tire?
Either way, that isn't abnormal.
Maybe that tread block should be more rigid than it is for track use? If it is user error due to tire pressure or alignment, then I'm surprised (but willing to learn). I take careful psi measurements after every session and I have a reputable race-shop-performed alignment.Last edited by OldRanger; 09-13-2024, 09:01 AM.
