Is there a good solution for a tow loop/hook/strap for the E46? I've read that the factory hook attachment point is weak for those of us with the composite front crash beam. Is there one that uses the OE hole?
Tow loop/hook/strap solutions?
2007 GX470
build/journal
ig: @zzyzx85Tags: None
Wanted to bump this.
The Kevlar bumpers are not very robust so that has me looking into options so I don't get my front end ripped off in the event I need to be drug off track, lol.'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
Email to [email protected]
I've been towed a couple of times and hammered the aluminum plates flat. Usually the problem is the left side where the kevlar separates from the aluminum base plate. I'm making carbon fiber plates that bond/bolt to the kevlar crash beam - more as a repair than improving the durability.
I just fixed mine. I made the left side as a bolt through. It is a risk - carbon will shred instead of bend.
bigjae46 do you have any pics?
I've been staring at it and I just can't see how to attach it to the frame rail AND have it exit the bumper in the stock location AND without seriously chopping up the kevlar bar.
Part of me thinks I'm going to chop up the kevlar bar and it'll get sandwhiched between a metal plate that has the "hook" on it.'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
There is a nub on the aluminum plate and it is bonded to the bar. I assume the plate is pressed and glued on. The right side has a bolt through the entire assembly. The aluminum plate bends at the top and bottom. The left side just gets ripped off.Originally posted by George Hill View Postbigjae46 do you have any pics?
All that holds it on are 2 nuts and 2 bolts on each side. I've been brainstorming a way to improve the mounting. Getting tired of messing with it.Last edited by bigjae46; 09-11-2026, 08:19 AM.
Oh yes, I mean there's (2) failure modes IMO:- The threaded bung tears out of the Kevlar bar
- The Kevlar bar tears away from the mount
Part of me is thinking about lopping that hole mount off the kevlar bar. Build something that bolts to the horn and then has a surface the kevlar bar bolts to.'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
