No swaybar?
    No swaybar?
    Anybody not running swaybars at all? I've never run a rear one on my E46s I've tracked but now the M3 is getting the Bimmerworld d splitter and it won't fit with the ground control front swaybar. I've talked with bimmerworld about not running a bar and they recommended at a minimum my spring rates would need to increase by 100lbs. I'm currently running 750 front 900 rear on MCS 3 ways. I'm just curious if anyone has any experience with a barless setup? Ordering the bimmerworld front swaybar is an option however I'm currently leaning towards going without a front bar. I'm going to tack the car in a month without a bar at NCM and then have another discussion with Bimmerworld.
    Which splitter is that? I’ve never considered the sway bar getting in the way.
    I run no rear bar and I didn’t change spring rates. Also didn’t change spring rates much with aero. I increased the front spring rate by 50lbs to reduce splitter scraping.
    Let me know if you plan to sell your GC front sway bar.
      The bimmerworld front splitter that's always out of stock, so I don't think they've sold many of them. I was shocked they didn't warn me before purchase
      Will do on the swaybar.
