Howdy community.
Curious who has dealt with serious overheating issues on track and been able to solve them.
I have an '05 6MT 90k miles. Cooling system is all stock. Clutch fan was replaced around 25k miles ago. Water pump & thermostat were replaced around 30k ago. Radiator and oil cooler were cleaned out, fresh coolant with a 60/40 distilled water plus water wetter added and flushed properly and thoroughly. There was some residue in the old fluid that points to OEM rad starting to fail. Coolant temps creep up after a few laps, blowing heater on max helps for a lap or so, but then coolant temps creep up again, almost to the second dot & to the point where I had some boil over from the overflow. This is at altitude (HPR in Colorado) and in high heat 95-100 degrees. Car has performed flawlessly in identical conditions in previous years. Temp is never an issue on the street, even doing canyon runs in high heat with a/c on.
So to my question finally:
If you have had these issues, how did you solve them?
I know plenty of people who run the assorted aluminum rad options (CSF, Koyo, Mishi). If there were cooling issues before those "upgrades" they seem to persist even with install of the new radiators. I assume my stock radiator is on the way out, I would hate to pay money for a new system and still have the same issue, I see that happen all the time.
Is the Zionsville rad a sure-fire cure? Fluidyne?
CSF reviews seems hugely mixed, but it seems like a great product, triple pass etc.
Is an electric fan better than a clutch fan for pure cooling power?
Thanks, I know there are plenty of snippets around the web on this matter but I'm looking for someone who has had this happen and exactly how they were able to fix it. (Hopefully you're out there lol)
Grazie Mille.
Grazie Mille.
