Search in Track / AutoX only
Special Interests
Track / AutoX
Mk60 Can ID
///MontereyM3
Member
Jun 2020
Mk60 Can ID
02-12-2021, 04:28 PM
Hi, does anyone have the Mk60 Canbus ID/Protocol? Im trying to put info on the same channel as my ecu for my AIM PDM as the second Can line is used by the CAN keypad.
Thanks!
Martyn
Mar 2020
02-13-2021, 01:37 AM
0x1F0 will give individual wheel speeds
0 - Uint16 LSB - Front Left
2 - Uint16 LSB - Front Right
4 - Uint16 LSB - Rear Left
6 - Uint16 LSB - Rear Right
0x1F5 contains steering angle
1 - Int16 - LSB - Steering Angle
0x1F8 contains brake pressure
2 - Uint8 - Brake Pressure
///MontereyM3
Member
Jun 2020
02-13-2021, 08:38 AM
Perfect, thank you!
eacmen
Mar 2020
02-13-2021, 04:17 PM
Originally posted by
Martyn
View Post
I thought brake pressure was only on CAN on AWD cars.
