I'm still on my quest to get to 2470lbs (roll cage/empty tank) so every oz counts. I deleted the LCM, OE hall effect switch and all of wires going to the brake light switch (4 wires). Installed a momentary push button. Wired it through a standard SPDT relay to the brake lights.
I've been having an issue with the brakes locking on after driving for a 100 yard or so.
Figued out that the ABS and ECU are tied into the hall effect switch. See the attachment below, its pin 41. So crossing fingers I can get this working properly this weekend.
I thought this was interesting. I guess you don't need to wire the ABS/DSC into the ECU? Should make swaps easier. Also wondering if the brake booster delete can retain the ABS system. I guess it just needs a master with a front and rear output so you can use the pressure sensors.
