Need Advice: Crystalized Brake Fluid in Power Bleeder Line
    I screwed up and stored my Motive Power Bleeder with some (not much) brake fluid in the line. It crystalized while stored. I need to clean out the line using something that will dissolve the crystal plugs without leaving a problem residue that will sit in the line and contaminate new fluid flushed through it.
    Anyone have some well-informed ideas?
    In the future I'll blow the line out with compressed air.
    Denatured alcohol? I use it to clean my Motive bleeder and lines after a fluid flush. Not sure if it would dissolve the crystallized fluid.
      motive recommends cleaning it with denatured alcohol prior to storing it.
      2007 Imola Red Z4M Coupe
        Thanks guys. I'll give it a go.
