**SOLD** WTT/WTS Track/Street 04 CB M3
    **SOLD**
    BLUF: Looking to Trade or Sell my 2004 CB M3 in Clarksville, TN for $26,000 OBO. Purchased in 2010 with 45,XXX miles, now at 120,XXX miles. Well-maintained with OE and OE+ parts, street/track modified, weighing only 3k lbs. Changing life circumstances have prompted the trade/sale; looking to trade for an LCI E46 M3, Sedan, or Wagon (preferably Grey). Predominantly used as a daily driver with mostly freeway mileage, also tracked at Buttonwillow one time and only once before modification @85k. Meticulously maintained following E46 M3 maintenance standards.
    Cliffs:
    Every 5k or year -Oil change (including filter)
    Every OBC Inspection Interval (so every other OBC service interval reset):
    -Trans fluid
    -Diff fluid
    -Cabin Air Filter
    -Engine Air Filter
    -Fuel Filter
    -Power Steering Fluid (ATF)
    Every other OBC inspection interval:
    -Coolant (Valvoline ZEREX)
    -Spark Plugs
    -Belts
    Beyond the basic maintenance:
    Front Axle:
    CSL Rotors/Caliper Brackets @65k
    Bilstein PSS10 Coilovers @85k
    GC Streeet Camber/Caster Plates @85k
    AKG 95A FCAB @85k
    Wheel Bearings @95k
    Steering Coupler @95k
    Genuine BWM Belly Pan @110k
    Rear Axle:
    CSL Rotors @65k
    Diff Bushing AKG 95A @85k
    AKG Lower Control Arm (left and right) @85k
    AKG 95A RCAB @85k
    Wheel Bearings @95k
    Custom 2" Clevis @95k
    Rear Shock FCM Custom Bilstein HD w/eyelet shaft @112.5K
    GC Articulating 2.5” ID Spring Perch @112500
    850lb 7” H&R Spring @112.5k
    Engine:
    Electronic Throttle Assembly @55k
    Valve Adjustment @70k
    Full Beisan VANOS Rebuild @70k
    Beisan Oil Pump Disc @70k
    Exhaust Sprocket Hub @70k
    Valve Cover Gasket/Associated Bolt Gaskets @70k
    AGK 95A Engine Mounts @85k
    Water Pump @85k
    Thermostat @85k
    Coolant Hoses @85k
    Rod Bearings @95k (OE Micro Blue Coated)
    Oil Pan Gasket @95k
    SAP Delete/Plate @95k
    Constant Pressure Valve O-Ring @95k
    OE (NRF) Radiator @110
    Spark Plugs & Coils @117k
    Trans:
    Guibo @85k
    Driveshaft Center Support Bearing @85k
    Modifications:
    PAVLOV Racing Half Cage @85k (Painted Matte Black)
    PAVLOV Racing Rear Subframe Carrier Welded Bushing Plates @85k
    CSF Oil Cooler @85k
    Apex Arc 8 18/9.5 et22 (Matte Black)
    Karbonius CSL Center Console 2x2 Weave @95k
    CSL Center Console Window & Hazard/Door Lock Switches Relocated @95k
    RTD Raw Aluminum Short Shifter (Mini) w/BMW Performance Shift Knob @95k
    Chassis Wiring Harness Thinned/De-Pinned @95k
    PTG Carbon Fiber Naca Duct Roof 1x1 Weave @95k
    Five Star Bodies OE cut Rear Polycarbonate Window @95k
    Five Star Bodies OE cut Quarter Polycarbonate Windows @95k
    Cobra Suzuka Pro-Fit GT Seat w/Thicker Cushioning @95k
    Schroth Profi 5 Point Harness (Black/Yellow) @95k
    Pusher Fan/Aux Fan Delete for Electric SPAL Puller Fan @95k
    TrackSpec Hood Vents @105k
    Rogue Engineering Expansion Tank Line @110k
    OE Radio Delete Plate @110k
    Sunglass Tray @110k
    Uninstalled Parts:
    BW Engine Mounts
    RE Transmission Mounts
    PFC ZR45 BBK
    Car Condition and Notable Issues:
    The car is in good shape overall. While the current paint quality rates around 6/10 the front end needs new clear coat from rock chips, and the rest a basic paint correction could elevate it to 8/10. I've got nothing to hide and plan to address issues as they arise until sold.
    1. There are signs of normal wear and tear; chips, scratches, and dings from freeway driving.
    2. During the construction of the half cage, the welder's hose left numerous minor scratches on the car's rear quarter panel.
    3. Rear quarter panel 1" by 1/2" spot of clear coat chipped, not expanding and paint is ok.
    4. Front part of NACA duct clear coat cracked.
    5. The steering wheel could benefit from reupholstering.
    6. The center brushed aluminum dash trim doesn't sit flush; I glued the tab on the drivers side that always breaks.
    7. The matte finish on two of the Arc 8 wheels was scratched/chipped off during the last tire installation.
    8. The rear bumper has several large scratches from kids bumping toys into it.
    9. Front bumper needs to be replaced
    More photos
      ​​​​​ PXL_20240902_162706836.jpg PXL_20240902_162746179.jpg PXL_20240902_162734034.jpg PXL_20240902_162806378.jpg
        Location? Checked twice and didn’t see it.
        '04 ZHP | '04 325iT | '20 M2C | '18 Tesla M3P | '84 318i Zender
          Clarksville TN, my bad
            Wow. Incredible mods, wish this was listed when I was in the market. Looking forward to seeing pics.
            Curious what this thing weighs. Polycarbonate windows and a de-pinned harness are on my todo list. Who thinned the wiring harness?
              I'm down to almost 3k lbs.
              Depinned harness was by Performance Eurowerks
              cornerbalanced
                Added some photos for now. When weather permits I'll get some detailed pics, but I'm looking to get a paint correction done in a month or two.
                  Updated photos taken after a good wash and a ceramic spray on and rinse off application. Will add interior photos as soon as I can get around to detailing it.
                    Updated 26K OBO.
                      Wow this is a great deal! ummm...
                        Man, I've got an 06 Carbon-schwartz manual (was formerly SMG) with 92k miles I've been trying to sell for a while so I can get a cheaper one to prep for track duties...and you're only like 4 hrs away from me lol
                        What's been de-pinned/removed from harness? I assume no a/c?
                          Tempting…. Could be interested in a trade.
                            Interior pics added
                              **SOLD**
