Vincebar Vince Skinz RACP reinforcement plates, tools
    For sale is a brand new kit from practical performance.
    Comes with the following:
    - Vincebar, epoxy style with front gusset cups
    - tooling kit
    - Vince Skinz Gen2
    Asking $1100 shipped to US48
    From his FB Post: https://www.facebook.com/PPRnDnews/p...pAeg3iRSsUbz5l
    Essentially items 1.1, 1.11, 1.13, 1.15 totaling 1457 USD plus shipping. Save $$$
    Bump!
      This requires rivets and epoxy or just epoxy?
        im sure its both
          Bump.
            Bump!!! Nobody wants to reinforce their RACP!?
              Good deal for this kit. I just finished mine up with the same setup. Someone should scoop this out to avoid the really long wait time on getting the vinceskinz.
                Bump! I thought big 3 was the hype and this is a great kit stateside!?
                Nobody wants to reinforce?
                  Bump!
                    Bump
                      BUMP!!!! Track season is upon us, get your e46 reinforced!
                        Have you tried listing in the E46 M3 Facebook groups? I’ve had better success by listing my stuff in those groups since there’s a larger audience.
                        997.1 GT3 Carrara White/Black
                        C43 AMG Diamond Silver/Red​
                          Have you tried listing in the E46 M3 Facebook groups? I've had better success by listing my stuff in those groups since there's a larger audience.
                          I've tried. Nobody wants to reinforce with the best kit out there haha!
                            How much does the kit weight packed up?
                              18lbs
                              Also, more detail on what's in the boxes:
                              -VinceBar kit - Simplified, Epoxy/Rivet style with front gusset cup
                              -Rear bar, front gusset cups e/r style, front and rear extended subframe bolts, collar nuts and washers, patch plates, rivets
                              -Tooling kit for E/R VinceBar, std length 10,5 mm drill bit
                              -VinceSkinz Gen2
                              -Four VinceSkinz, two spacer plates and the required steel rivets
                              Subtotal Please note: 1. When installing the extended front subframe studs be sure to follow these instructions: https://www.facebook.com/72205743465...6480005215839/ 2. If you are installing the rear bar, and/or the gusset cups, using the epoxy and rivet method, you will need to purchase epoxy in addition to this kit. I highly recommend 50ml cartridges of Araldite 2014 along with an applicator gun.
